How can I visualize an impulse switch in WebFront? Let me try to explain. My garage door uses a remote control with a single button, where the same button is used for open and close.
My Eltako FSR61-230V impulse switch triggers the garage door. In WebFront I see two variables, OFF/ON. Only the ON variable triggers an action.
ON → Garage door opens
OFF–> No action (But I have to trigger OFF in WebFront, otherwise I can’t trigger ON again)
ON again → Garage door stops
ON again → Garage door closes
This isn’t very user friendly, has someone made a workaround for this? Thanks!
While this script looks simple enough, and executing the script works as expected, I’m not sure how to implement it. I thought I would just use the script as a custom action, but that creates an infinite loop. I’m having trouble finding the fault in my logic.
I edited the script as suggested, and it removes the loop. But it doesn’t seem to execute any action at all. (I’ve configured the script as custom action)
Sorry , i don’t considered, that the default action no more exist.
Now you must use the instance functions.
I’m not sure if the following command is correct because i don’t have this Eltako device
Can you try this:
Is there some IPS script/command reference for dummies or something like that? I think I would learn a lot from a simple „How to“.
Now I only need to get rid of the „Off“ button in WebFront.
sorry for my mistakes, fortunately you already got help. Thanks Ralf.
SetValue set it for the integer variable, because it is the trigger for this script.
The other (boolen) is still set automatically by the device instance as an result of the SwitchMode command.
