@paresy
Die Homekit Bridge Instanz zeigt mir beim Aufruf folgendes:
Warning: Variable #44159 existiert nicht in C:\ProgramData\Symcon\modules.store\de.paresy.homekit\HomeKitBridge\accessories\thermostat.php on line 192
Warning: Trying to access array offset on value of type bool in C:\ProgramData\Symcon\modules.store\de.paresy.homekit\HomeKitBridge\accessories\thermostat.php on line 194
Warning: Variable #21714 existiert nicht in C:\ProgramData\Symcon\modules.store\de.paresy.homekit\HomeKitBridge\accessories\thermostat.php on line 192
Warning: Variable #44159 existiert nicht in C:\ProgramData\Symcon\modules\.store\de.paresy.homekit\HomeKitBridge\accessories\thermostat.php on line 192
Warning: Trying to access array offset on value of type bool in C:\ProgramData\Symcon\modules\.store\de.paresy.homekit\HomeKitBridge\accessories\thermostat.php on line 194
Warning: Variable #21714 existiert nicht in C:\ProgramData\Symcon\modules\.store\de.paresy.homekit\HomeKitBridge\accessories\thermostat.php on line 192
{"elements":[{"type":"RowLayout","items":[{"type":"Button","label":"Request setup code!","onClick":"echo HK_RestartPairing($id);"},{"type":"Label","label":"Press the button to start the pairing process. Code is valid for at most 5 minutes."}]},{"type":"Label","label":""},{"type":"Label","label":"You can add new items for each accessory type"},{"type":"ExpansionPanel","caption":"Lightbulb (Switch)","items":[{"type":"List","name":"AccessoryLightbulbSwitch","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Lightbulb (Dimmer)","items":[{"type":"List","name":"AccessoryLightbulbDimmer","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Lightbulb (Color)","items":[{"type":"List","name":"AccessoryLightbulbColor","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Motion Sensor","items":[{"type":"List","name":"AccessoryMotionSensor","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"Variable missing"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Window (Up\/Down)","items":[{"type":"List","name":"AccessoryWindowUpDown","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[]}]},{"type":"ExpansionPanel","caption":"Window (Position)","items":[{"type":"List","name":"AccessoryWindowPosition","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Humidity Sensor","items":[{"type":"List","name":"AccessoryHumiditySensor","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Garage Door Opener","items":[{"type":"List","name":"AccessoryGarageDoorOpener","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Light Sensor","items":[{"type":"List","name":"AccessoryLightSensor","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"Variable missing"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Carbon Dioxide Sensor","items":[{"type":"List","name":"AccessoryCarbonDioxideSensor","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[]}]},{"type":"ExpansionPanel","caption":"Carbon Monoxide Sensor","items":[{"type":"List","name":"AccessoryCarbonMonoxideSensor","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[]}]},{"type":"ExpansionPanel","caption":"Contact Sensor","items":[{"type":"List","name":"AccessoryContactSensor","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Speaker","items":[{"type":"List","name":"AccessorySpeaker","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"MuteID","name":"MuteID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"VolumeID","name":"VolumeID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[]}]},{"type":"ExpansionPanel","caption":"Leak Sensor","items":[{"type":"List","name":"AccessoryLeakSensor","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Air Quality Sensor","items":[{"type":"List","name":"AccessoryAirQualitySensor","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[]}]},{"type":"ExpansionPanel","caption":"Fan","items":[{"type":"List","name":"AccessoryFan","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[]}]},{"type":"ExpansionPanel","caption":"Smoke Sensor","items":[{"type":"List","name":"AccessorySmokeSensor","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Window Covering (Up\/Down)","items":[{"type":"List","name":"AccessoryWindowCoveringUpDown","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Window Covering (Position)","items":[{"type":"List","name":"AccessoryWindowCoveringPosition","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Temperature Sensor","items":[{"type":"List","name":"AccessoryTemperatureSensor","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Thermostat","items":[{"type":"List","name":"AccessoryThermostat","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"TargetHeatingCoolingStateID","name":"TargetHeatingCoolingStateID","width":"150px","add":0,"edit":{"type":"SelectVariable"}},{"label":"CurrentTemperatureID","name":"CurrentTemperatureID","width":"150px","add":0,"edit":{"type":"SelectVariable"}},{"label":"TargetTemperatureID","name":"TargetTemperatureID","width":"150px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"TargetTemperatureID: Float required"},{"Status":"TargetTemperatureID: Float required"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Switch","items":[{"type":"List","name":"AccessorySwitch","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"},{"Status":"OK"}]}]},{"type":"ExpansionPanel","caption":"Stateless Programmable Switch","items":[{"type":"List","name":"AccessoryStatelessProgrammableSwitch","rowCount":10,"add":true,"delete":true,"sort":{"column":"Name","direction":"ascending"},"columns":[{"label":"ID","name":"ID","width":"35px","add":0,"save":true},{"label":"Name","name":"Name","width":"auto","add":"","edit":{"type":"ValidationTextBox"}},{"label":"VariableID","name":"VariableID","width":"250px","add":0,"edit":{"type":"SelectVariable"}},{"label":"Status","name":"Status","width":"150px","add":"-"}],"values":[{"Status":"OK"}]}]},{"type":"PopupButton","caption":"Expert options","popup":{"caption":"Expert options","items":[{"type":"Label","label":"These options are for experts only! Do not touch!"},{"type":"Label","label":"After changing the name please delete the old entry in the DNS-SD control"},{"type":"ValidationTextBox","caption":"Name","name":"BridgeName"},{"type":"ValidationTextBox","caption":"ID","name":"BridgeID"},{"type":"NumberSpinner","caption":"Port","name":"BridgePort"}]}}],"translations":{"de":{"Name":"Name","ID":"ID","Port":"Port","Name is required to consist only of letters and numbers!":"Name darf nur aus Buchstaben und Zahlen bestehen!","ID is not a valid MAC style address!":"ID muss wie eine MAC Adresse aussehen!","OK!":"OK!","Press the button to start the pairing process. Code is valid for at most 5 minutes.":"Hier dr\u00fccken, um das Verkn\u00fcpfen zu Starten. Der Code ist f\u00fcr maximal 5 Minuten g\u00fcltig.","Request setup code!":"Code anfordern!","You can add new items for each accessory type":"Pro Ger\u00e4tetyp k\u00f6nnen Eintr\u00e4ge hinzugef\u00fcgt werden","These options are for experts only! Do not touch!":"Diese Einstellungen sind nur f\u00fcr Experten. Nicht anfassen!","Expert options":"Expertenoptionen","After changing the name please delete the old entry in the DNS-SD control":"Nach einer Namens\u00e4nderung muss der alte Eintrag im DNS-SD Control manuell gel\u00f6scht werden","Our parent instance (ServerSocket) is not active!":"Die \u00fcbergeordnete Instanz (ServerSocket) ist nicht aktiv!","Lightbulb (Switch)":"Lampe (Schaltbar)","VariableID":"VariablenID","Variable missing":"Variable fehlt","Bool required":"Bool ben\u00f6tigt","Action required":"Aktion ben\u00f6tigt","OK":"OK","Lightbulb (Dimmer)":"Lampe (Dimmbar)","Int\/Float required":"Int\/Float ben\u00f6tigt","Profile required":"Profil ben\u00f6tigt","Lightbulb (Color)":"Lampe (Farbig)","Int required":"Int ben\u00f6tigt","HexColor required":"HexColor ben\u00f6tigt","Motion Sensor":"Bewegungsmelder","Window (Up\/Down)":"Fenster (Hoch\/Runter)","Unsupported Profile":"Falsches Profil","Window (Position)":"Fenster (Position)","Humidity Sensor":"Feuchtigkeitssensor","Garage Door Opener":"Garagentor","Light Sensor":"Helligkeitssensor","Carbon Dioxide Sensor":"Kohlendioxid Sensor","Carbon Monoxide Sensor":"Kohlenmonoxid Sensor","Contact Sensor":"Kontaktsensor","Speaker":"Lautsprecher","MuteID":"MuteID","VolumeID":"VolumeID","Leak Sensor":"Leckagesensor","Air Quality Sensor":"Luftg\u00fctesensor","Fan":"L\u00fcfter","Smoke Sensor":"Rauchmelder","Window Covering (Up\/Down)":"Rollladen\/Jalousie (Hoch\/Runter)","Window Covering (Position)":"Rollladen\/Jalousie (Position)","Temperature Sensor":"Temperatursensor","Thermostat":"Thermostat","CurrentHeatingCoolingStateID":"CurrentHeatingCoolingStateID","TargetHeatingCoolingStateID":"TargetHeatingCoolingStateID","CurrentTemperatureID":"CurrentTemperatureID","Variable CurrentTemperatureID missing":"Variable CurrentTemperatureID fehlt","TargetHeatingCoolingStateID: Int required":"TargetHeatingCoolingStateID: Int ben\u00f6tigt","TargetHeatingCoolingStateID: Action required":"TargetHeatingCoolingStateID: Aktion ben\u00f6tigt","TargetTemperatureID: Action required":"TargetTemperatureID: Aktion ben\u00f6tigt","CurrentTemperatureID: Float required":"CurrentTemperatureID: Float ben\u00f6tigt","TargetTemperatureID: Float required":"TargetTemperatureID: Float ben\u00f6tigt","Switch":"Zwischenstecker","Stateless Programmable Switch":"Zustandsloser programmierbarer Schalter"}}} (Code: -32603)
Es scheint mit dem Austausch zweier Thermostate zusammenzuhängen, aber ich finde aktuell keinen Weg auf eine Konfig zuzugreifen, um diese beiden Variablen zu eliminieren, die dort immer wieder in das Skript übergeben werden sollen.
In welcher Datei liegen die bei der Konfiguration angelegten Daten für die Homekit Integration ?
- Neuinstallation Modul habe ich bereits versucht.
- Neustart Dienst ebenfalls
- Thermostat.php arbeitet ja nur das ab, was Ihr zugeführt wird und somit muss ich wohl an die Quelle ran.
- Technisch funktioniert das Modul noch und die Instanzen sind noch im Homekit, nur konfigurieren lässt sich nichts mehr
Gibt es eine Rettung für diese Instanz, da ich über 120 Geräte ins Homekit rüber schiebe.
Danke für die Hilfe
B71
