Heute morgen habe ich die CCU2 auf die neueste version 2.29.18 updated.
Aug 5 06:59:20 homematic-ccu2 user.info logger: Updating RF Lan Gateway Coprocessor Firmware
Aug 5 06:59:21 homematic-ccu2 user.debug update-coprocessor: firmware filename is: coprocessor_update_hm_only.eq3
Aug 5 06:59:21 homematic-ccu2 user.info logger: Updating RF Lan Gateway Firmware
Aug 5 06:59:21 homematic-ccu2 user.info update-lgw-firmware: No gateway found in config file /etc/config/rfd.conf
Aug 5 06:59:21 homematic-ccu2 user.info logger: Updating Wired Lan Gateway Firmware
Aug 5 06:59:21 homematic-ccu2 user.info update-lgw-firmware: No gateway found in config file /etc/config/hs485d.conf
Aug 5 08:59:27 homematic-ccu2 user.info update-coprocessor: Version: 2.8.3
Aug 5 08:59:27 homematic-ccu2 user.info update-coprocessor: Update necessary, installed: 2.8.3, avaiable 2.8.5
Aug 5 08:59:35 homematic-ccu2 user.info update-coprocessor: Firmwareupdate successfull
Aug 5 08:59:36 homematic-ccu2 user.info kernel: [ 30.940000] eq3loop: created slave ttyS0
Aug 5 08:59:36 homematic-ccu2 user.info kernel: [ 30.950000] eq3loop: created slave mmd_bidcos
Aug 5 08:59:39 homematic-ccu2 user.info kernel: [ 33.370000] eq3loop: eq3loop_open_slave() mmd_bidcos
Aug 5 09:00:17 homematic-ccu2 user.debug setclock: Try to get time from ntp.homematic.com
Aug 5 09:00:18 homematic-ccu2 user.debug setclock: Sat Aug 5 09:00:18 CEST 2017
Aug 5 09:01:17 homematic-ccu2 user.info kernel: [ 130.970000] eq3loop: eq3loop_open_slave() ttyS0
Aug 5 09:01:17 homematic-ccu2 user.info kernel: [ 130.980000] eq3loop: eq3loop_close_slave() ttyS0
Aug 5 09:01:17 homematic-ccu2 user.info kernel: [ 131.090000] eq3loop: eq3loop_open_slave() ttyS0
Aug 5 09:01:17 homematic-ccu2 user.info kernel: [ 131.090000] eq3loop: eq3loop_close_slave() ttyS0
Aug 5 09:01:17 homematic-ccu2 user.info kernel: [ 131.300000] eq3loop: eq3loop_open_slave() ttyS0
Aug 5 09:01:17 homematic-ccu2 user.notice kernel: [ 131.330000] eq3loop: eq3loop_ioctl_slave() ttyS0: unhandled ioctl 0x5459
Aug 5 09:01:17 homematic-ccu2 user.notice kernel: [ 131.330000] eq3loop: eq3loop_ioctl_slave() ttyS0: unhandled ioctl 0x545D
Aug 5 09:01:32 homematic-ccu2 user.err rfd: XmlRpc transport error calling system.listMethods({„IPS“}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:02:36 homematic-ccu2 user.err rfd: XmlRpc transport error calling listDevices({„IPS“}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:02:56 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,418292.100000}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,"P
Aug 5 09:02:56 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:02:59 homematic-ccu2 user.info : hss_lcd: Programm initialisiert.
Aug 5 07:02:59 homematic-ccu2 daemon.info init: starting pid 505, tty ‚/dev/ttyAMA0‘: '/sbin/getty -L ttyAMA0 115200 vt100 ’
Aug 5 07:02:59 homematic-ccu2 daemon.info init: starting pid 506, tty ‚/dev/ttyGS0‘: '/sbin/getty -L ttyGS0 115200 vt100 ’
Aug 5 09:03:08 homematic-ccu2 user.err rfd: XmlRpc transport error calling system.listMethods({„1009“}) on binary://127.0.0.1:1999/RPC2:
Aug 5 09:03:26 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:1“,„STATE“,false}],[methodName:„event“,params:{„IPS“,„OEQ0571907:1“,„WORKING“,false}]}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:03:26 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:03:46 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,418292.100000}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,"P
Aug 5 09:03:46 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:04:07 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:1“,„STATE“,true}]}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:04:07 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:04:27 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:1“,„WORKING“,false}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,
Aug 5 09:04:27 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:04:47 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„NEQ1381103:1“,„TEMPERATURE“,17.700000}],[methodName:„event“,params:{„IPS“,„NEQ1381103:1“,„HUMIDITY“,67}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,
Aug 5 09:04:47 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:06:42 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„NEQ1381103:1“,„TEMPERATURE“,17.700000}],[methodName:„event“,params:{„IPS“,„NEQ1381103:1“,„HUMIDITY“,67}]}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:06:42 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:07:02 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,418300.400000}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,"P
Aug 5 09:07:02 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:07:22 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,418300.900000}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,"P
Aug 5 09:07:22 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:07:42 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,418306.600000}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,"P
Aug 5 09:07:42 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:08:02 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,418313.900000}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,"P
Aug 5 09:08:02 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:18:35 homematic-ccu2 user.err rfd: XmlRpc transport error calling system.listMethods({„IPS“}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:19:38 homematic-ccu2 user.err rfd: XmlRpc transport error calling listDevices({„IPS“}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:19:58 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,418606.800000}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,"P
Aug 5 09:19:58 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:20:18 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:1“,„STATE“,true}],[methodName:„event“,params:{„IPS“,„OEQ0571907:1“,„WORKING“,false}]}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:20:18 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:22:17 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}]}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:22:17 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:22:37 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,418686.400000}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„POWER“,1587.700000}],[methodName:„event“,params:{„IPS“,"OEQ05719
Aug 5 09:22:37 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:24:47 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„NEQ1381103:1“,„TEMPERATURE“,17.900000}],[methodName:„event“,params:{„IPS“,„NEQ1381103:1“,„HUMIDITY“,66}]}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:24:47 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:25:07 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,418759.500000}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,"P
Aug 5 09:25:07 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:27:01 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„NEQ1381103:1“,„TEMPERATURE“,18.000000}],[methodName:„event“,params:{„IPS“,„NEQ1381103:1“,„HUMIDITY“,66}]}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:27:01 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:27:34 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,418826.500000}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,"P
Aug 5 09:27:34 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:29:52 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,true}]}) on http://192.168.0.8:5545/RPC2:
Aug 5 09:29:52 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 09:30:12 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„ENERGY_COUNTER“,418886.800000}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„POWER“,1583.280000}],[methodName:„event“,params:{„IPS“,"OEQ05719
Aug 5 09:30:12 homematic-ccu2 user.err rfd: XmlRpc transport error
Aug 5 10:55:41 homematic-ccu2 user.err rfd: XmlRpc transport error calling system.listMethods({„IPS“}) on http://192.168.0.8:5545/RPC2:
Aug 5 10:56:45 homematic-ccu2 user.err rfd: XmlRpc transport error calling listDevices({„IPS“}) on http://192.168.0.8:5545/RPC2:
Aug 5 10:57:05 homematic-ccu2 user.err rfd: XmlRpcClient error calling event({[methodName:„event“,params:{„IPS“,„NEQ1381103:1“,„TEMPERATURE“,18.700000}],[methodName:„event“,params:{„IPS“,„NEQ1381103:1“,„HUMIDITY“,59}],[methodName:„event“,params:{„IPS“,„OEQ0571907:2“,„BOOT“,
Aug 5 10:57:05 homematic-ccu2 user.err rfd: XmlRpc transport error
