How can I hide a value from WebFront Visualization? If I want to hide one value from an integer variable with 5 possible values from WebFront Visualization, how should I configure this integer variable in IP-Symcon?
Or should I create two different integer variables, both using a custom profile, one with 5 possible values and one with 4 possible values. But then how do I keep both variables in sync?
Cheers,
Dennis.
