Hallo Fabian,
habe die Zeile auskommentiert - nun gibt es keine Fehlermeldungen mehr.
Hier das Script:
IP-SYNCOM Event Scripting
//File: sFHTs.ips.php PUBLIC : 0.70 date 08/11/06
//File: sFHTs.ips.php BETA VERSION : 0.69 date 04/11/06 '7' settings in .ini weekend bad interpret bug by Prof
//File: sFHTs.ips.php BETA VERSION : 0.68 date 01/11/06 flank-detection problem due to TimerEvent and RunScript
//File: sFHTs.ips.php BETA VERSION : 0.67 date 29/10/06 flank-detection doesn't work in S regime. bug by Torsteng
//File: sFHTs.ips.php BETA VERSION : 0.66 date 18/06/06 Back to basic - no good
//File: sFHTs.ips.php BETA VERSION : 0.65 date 18/06/06 semaphore test
//File: sFHTs.ips.php BETA VERSION : 0.64 date 17/06/06 debug switch
//File: sFHTs.ips.php PUBLIC : 0.63 date 23/01/06
//Events : __imhome, __imaway, __party and all FHT_status-intervention variables
Copyright rules applie under GNU-regulations
rest of copyright text ToDo
// Variablen
$V_IMHOME = 18357 /*[OG\Zimmer 1\Heizung\Variablen\__imhome]*/ ;
$V_IMAWAY = 18351 /*[OG\Zimmer 1\Heizung\Variablen\__imaway]*/ ;
$V_PARTY = 48393 /*[OG\Zimmer 1\Heizung\Variablen\__party]*/ ;
$V_INHIBIT = 13117 /*[OG\Zimmer 1\Heizung\Variablen\__fht_inhibit]*/ ;
$V_DEBUG = 41022 /*[OG\Zimmer 1\Heizung\Variablen\__debug]*/;
include("GlobalDefines.ips.php");
/* variables needed in GlobalDefines.ips.php !!
see "tempsettings.ini" and modifie to your environment /*
/********** USER SETTINGS ***********************************************/
$tempfilepath=__myhome."tempsettings.ini"; //default: 'tempsettings.ini'
// |---> defined in GlobalDefines.ips.php
$use_imhome = true;
// Note : A IPS variabele '__iamhome' should exist !!
/* use this switch to overrule general settings
the effect is that if IPS-variable "__imhome" = true
the HOLIDAY temperature is sent as the result of
this function
!! ATTENTION BETA WORK !!
19/11/2005 : I am not happy with how this implemented but it's a start
$use_imaway = true;
// Note : A IPS variabele '__iamaway' should exist !!
the effect is that if IPS-variable "__imaway" = true
the AWAY temperature is sent as the result of
this function
$use_party = true;
// Note : A IPS variabele '__party' should exist !!
/* For all the party people out there ;-)
Do YOU Like the Way YOU Feel when YOU Shake
the effect is that if IPS-variable "__party" = true
the party settings applie without checking days or dates.
So starting on a Saturday will set party temperatures until
you set __party=false on the Wednesday. (Oh my God what a party)
/********** END OF USER SETTINGS ****************************************/
/********** ADAPTATION TO YOUR ENVIROMENT *******************************
Every FHT has to have 2 variables with the names hereunder
v(your-name)_soll : f.i. "vliv_temp_soll" = FHT soll temp in livingroom
o(your-name) : f.i. "oliv_temp" = device ID of the
FHT instance (set in GlobalDefines.ips.php)
*********** END ADAPTATION **********************************************/
/********** DEBUG SWITCHES **********************************************/
$softswitch = true; /* Send the temp-settings to FHT or not
If you're debugging set it to false
so FHZ won't be overbuffered */
$use_sollwert = false;
$sollwert = "19"; //is 'use_sollwert' = true then take this value
// if you want a master-debug switch : create an IPS variabele "__debug"
if (IPS_VariableExists($V_DEBUG)){
$debug = GetValueBoolean($V_DEBUG);
} else {
$debug = true; // set to true if you want to enable echo-output
/* logfilepath since we are dealing with variables which cannot be show in
the direct output window. */
$logfilepath=__mylogs."Heizung/tempSENT.txt";
// $IPS_SENDER = "TimerEvent";
/********** END DEBUG ***************************************************/
if ($IPS_SENDER == "Designer"){
//do not run when event is triggered by designer
return;
if (IPS_VariableExists($V_INHIBIT)){
if (GetValueBoolean($V_INHIBIT)){
if($debug) echo("INHIBITED by '__fht_inhibit'");
return;
if ($IPS_SENDER == "Variable"){
/* Switch ONLY when __imaway becomes true or __imhome becomes true
die if false -> script will be triggered in max 30 minutes.
if settings change from imhome -> imaway, then FHZ buffer get's
overbuffered because script did run 2 times
imhome -> false, imaway -> true x 5 FHT-devices = buffer overrun */
if ($IPS_VARIABLE == "__imaway" && !GetValueBoolean($V_IMAWAY)) die;
// die when imhome = false
if ($IPS_VARIABLE == "__imhome" && !GetValueBoolean($V_IMAHOME)) die;
if ($IPS_VARIABLE == "__party" && !GetValueBoolean($V_PARTY)) die;
//$lastrun=IPS_GetLastRun("GetTemp");
if (!file_exists("$tempfilepath")) {
echo("
******* ERROR: Please install '$tempfilepath'
die;
echo("
die;
$handle=fopen("$tempfilepath", "r");
if (!$handle){
// error cannot open file
echo("******* ERROR: Cannot open file '$tempfilepath'
//init variable
$aktor = array();
$now = getdate();
$isholiday = false;
$isparty = false;
$holiday="";
$season = "";
$today="";
$alldays="";
$weekend="";
$imhome=false;
$party=false;
$temp_rule="";
if ($use_imhome && IPS_VariableExists($V_IMHOME)){
$imhome = GetValueBoolean($V_IMHOME);
} elseif ($use_imhome) {
echo("
******* NOTICE: Variabele '__imhome' not found as a valid IPS variabele
$imhome = false;
} else {
$imhome = false;
if ($use_imaway && IPS_VariableExists($V_IMAWAY)){
$imaway = GetValueBoolean($V_IMAWAY);
} elseif ($use_imaway) {
echo("
******* NOTICE: Variabele '__imaway' not found as a valid IPS variabele
$imaway = false;
} else {
$imaway = false;
if ($use_party && IPS_VariableExists($V_PARTY)){
$party = GetValueBoolean($V_PARTY);
} elseif ($use_party) {
echo("
******* NOTICE: Variabele '__party' not found as a valid IPS variabele
$party = false;
} else {
$party = false;
// the serious work start with settin' the inhibit switch
SetValueBoolean($V_INHIBIT,true);
// end modifie
while(!feof($handle)) {
$buffer = fgets($handle);
Switch (substr($buffer,0,1)) {
case "@":
//general settings
if (substr($buffer,1,7) == "season=") {
$season = substr($buffer,8,1);
if (substr($buffer,1,1) == "H") {
if ((sprintf("%02d",$now["mon"])."/".sprintf("%02d",$now["mday"]) == substr($buffer,2,5)) or (sprintf("%02d",$now["mon"])."/".sprintf("%02d",$now["mday"])."/".$now["year"] == substr($buffer,2,10))) {
$isholiday = true;
$temp_rule = substr($buffer,strpos($buffer,"#")+1,strlen($buffer)-strpos($buffer,"#")-3);
if ($debug) echo "temp rule : $temp_rule";
break;
case "D":
//DEFAULT lines
if (substr($buffer,1,1) == "$season" && chop(substr($buffer,4,14))=="default"){
// get default default or default room
// aktor("default" -> $default OR "room" -> $default)
$default = substr($buffer,27,48);
} elseif (substr($buffer,1,1) == "$season") {
$aktor[chop(substr($buffer,4,14))]["default"] = substr($buffer,27,48);
break;
case "H":
//HOLIDAY table entries
if ($isholiday) {
// NOTE THEM DOWN IN array[aktor,["holiday"]
if (substr($buffer,1,1) == "$season") $aktor[chop(substr($buffer,4,14))]["holiday"]= substr($buffer,27,48);
} else {
if (substr($buffer,1,1) == "$season") $aktor[chop(substr($buffer,4,14))]["iamhome"]= substr($buffer,27,48);
break;
case "I":
//Table entries
// GET RID OF THIS INSTRUCTION GET THEM ALLL ;-)
// array[substr(....),alldays, weekends, thisday]
// ???? Should we apply precendence RULE here ??
// WE SHOULD HAVE ALL INFO --> see tempfile.ini
// SO HERE WE DEPEND THE RULE TO APPLY
// WHAT IF NOT ?? NO APPLICABLE ENTRY ?? THEREFORE ALL THESE IF INSTRUCTIONS
if ((substr($buffer,1,1) == "$season") and (substr($buffer,2,1) == "9")) $aktor[chop(substr($buffer,4,14))]["alldays"] = substr($buffer,27,48);
if ((substr($buffer,1,1) == "$season") and (substr($buffer,2,1) == "7") and (($now["wday"] == 0) or ($now["wday"] == 6))) $aktor[chop(substr($buffer,4,14))]["weekend"] = substr($buffer,27,48);
if ((substr($buffer,1,1) == "$season") and (substr($buffer,2,1) == $now["wday"])) $aktor[chop(substr($buffer,4,14))]["today"]= substr($buffer,27,48);
break;
case "W":
// IamAway settings
if ($imaway) $default = substr($buffer,27,48);
break;
case "P":
// PaAaRtY settings
// no date-jump will occure !!
// tryout 26/11/2005
if (substr($buffer,1,1) == "$season") $aktor[chop(substr($buffer,4,14))]["party"]= substr($buffer,27,48);
break;
default:
//only thing to expect are comments '#' and temp settings
// PUT IN ARRAY !!! WE NEED THEM LATER
// USE array[sign => value]
if (substr($buffer,0,1) <> "#") {
$temp[substr($buffer,0,1)] = substr($buffer,1,5);
$temp["0"]=false;
$temp["1"]=true;
fclose($handle);
if ($debug) {
foreach($aktor as $key => $value){
$thisday = $now["wday"];
if ($debug) echo("
RESULT for '$key'
if ($debug) echo(" now :'". $now["hours"] .":". $now["minutes"] . "'
if ($debug) echo(" today is nr# : $thisday
if ($debug) echo(" season : $season
if ($debug) echo(" Is it a holiday : $isholiday
if ($debug) echo(" Check precendence hereunder
if ($debug) echo(" Am I home ? : $imhome
if(array_key_exists("iamhome",$value) && $debug)echo(" IAmHome : ".$aktor[$key]["iamhome"]."
if ($debug) echo(" Am I away ? : $imaway
if(array_key_exists("iamaway",$value) && $debug)echo(" IAmAway : ".$aktor[$key]["iamaway"]."
if(array_key_exists("holiday",$value) && $debug)echo(" holiday : ".$aktor[$key]["holiday"]."
if ($debug) echo(" Paaaartyy ? : $party
if(array_key_exists("party",$value) && $debug)echo(" Party : ".$aktor[$key]["party"]."
if(array_key_exists("today",$value) && $debug)echo(" today : ".$aktor[$key]["today"]."
if(array_key_exists("weekend",$value) && $debug)echo(" weekends : ".$value["weekend"]."
if(array_key_exists("alldays",$value) && $debug)echo(" alldays : ".$aktor[$key]["alldays"]."
if(array_key_exists("default",$value) && $debug)echo(" default rule : ".$aktor[$key]["default"]."
if ($debug) echo(" def. def. rule: $default
if ($debug) echo("--------------------------------------------------
} //for
} //if
/* precendence rules
ON ALL ELEMENTS OF ARRAY = Aktors
VARIABLES = FIELDS OF ARRAY ("AKTOR" [ROOMDEFAULT, HRule, DayRULE, RESULT, soll)
NEGATIVE LOGIC Variables are filled in IF applicable */
if ($debug) echo"
if (!array_key_exists("holiday", $value)) {
if (!array_key_exists("today", $value)) {
if (!array_key_exists("weekend", $value)) {
if (!array_key_exists("alldays", $value)) {
if (!array_key_exists("default", $value)) {
$aktor[$key]["result"] = $default;
if ($debug) echo "res = def. def";
} else {
$aktor[$key]["result"] = $value["default"];
if ($debug) echo "res = default";
} // if
} else {
$aktor[$key]["result"] = $value["alldays"];
if ($debug) echo "res = alldays";
} else {
$aktor[$key]["result"] = $value["weekend"];
if ($debug) echo "res = weekend";
} else {
$aktor[$key]["result"] = $value["today"];
if ($debug) echo "res = today";
} else {
$aktor[$key]["result"] = $value["holiday"];
if ($debug) echo "res = holiday";
// attempt to set IAmHome rule !!
if ($use_imhome and $imhome) {
if (array_key_exists("iamhome", $value)){
$aktor[$key]["result"] = $value["iamhome"];
echo "
OVERRULED RESULT set to HOLIDAY because I AM HOME
// attemp to set Away-rule
if ($use_imaway and $imaway) {
if ($debug) echo ("
OVERRULED RESULT set to AWAY
// attempt to set Party rule !!
if ($use_party and $party) {
if (array_key_exists("party", $value)){
$aktor[$key]["result"] = $value["party"];
echo "
OVERRULED RESULT set to PaAaRrTYyyyy
if ($debug) echo("
For '$key' I did choose : '".$aktor[$key]["result"]."'
// here we get the temperature out of string
// USE ARRAY["AKTOR", "soll"]
// change 11/10/2005 'floor' into 'round' because otherwise allways back to ??h00 instead of ??h00 or ??h30
$pos = $now["hours"]*2 + round($now["minutes"]/30);
$prevpos = $pos - 1;
if ($debug) echo("hours: " . $now["hours"] . " hours *2 = " . $now["hours"]*2 . "round($now[minutes]/30) = " . (round($now["minutes"]/30) . "
if ($debug) echo "pos = '$pos' (check midnight !!
// end change
$aktor[$key]["soll"] = $temp[substr($value["result"],$pos,1)];
if ($debug) echo "res : '" . $value["result"]."'
if ($debug) echo "time : '12345678901234567890123456789012345678'
if ($debug) echo "temp = '" . $aktor[$key]["soll"]."'
// and now deal with the state-event.
// detect flanks
//if ($temp[substr($value["result"],$pos,1)] <> $temp[substr($value["result"],$pos,1)]){
// 11/10/2005 This is still a burdon !! damn boy ... where do you wanne drive the MIN-TEMP to ? and MAX-TEMP ?
//if ($use_imhome and $imhome) {
// $soll = $temp["+"];
// $status = "OVERRULED set to";
//} elseif ($use_imhome) {
// $soll = $temp["-"];
//} else {
// $status = substr($result,$pos,1)." : ";
// 19/11/2005 : decided when 'I am Home' is selected to choose 'holiday'-rule
$handle = fopen("$logfilepath","a");
$neg = "NOT (SSw)";
if ($softswitch) $neg = "";
// GET ALL AKTORS OUT OF ARRAY["AKTOR","SOLL"] = nice result of all the -above- work
// loop here : for every aktor in array : setTemp(Aktor, argument);
$junk = 1;
if ($use_sollwert) {
echo("OVERRULED BY use_sollwert");
$value["soll"]= $sollwert;
SetValueFloat($key."_soll",floatval($value["soll"]));
if ($debug) echo("FHT temp for '$key"."_soll' set to '".$value["soll"]."' !!
// as the result of the function set aktors to soll
$thisinstance = "o" . substr($key,1);
if (!defined($thisinstance)) {
echo("
******* NOTICE: FHT-ID ($thisinstance) not defined in GlobalDefines.ips.php
} elseif (!IPS_InstanceExists(constant($thisinstance))) {
echo("
******* NOTICE: FHT with ID '". constant($thisinstance) . "' is not a valid instance in IPS.
} else {
if ($IPS_SENDER == "Variable") {
if ($IPS_VARIABLE == "__imhome" || $IPS_VARIABLE == "__imaway" || $IPS_VARIABLE == "__party"){
if ($softswitch) FHT_SetTemperature(constant($thisinstance),floatval($value["soll"]));
if ($debug) echo("FHT_SetTemp for $thisinstance $neg SENT due to '$IPS_VARIABLE'-trigger
if ($debug) fwrite($handle, date("d.m.y")." ". date("H:i:s")." $IPS_SENDER - FHT_SetTemp for $thisinstance $neg SENT due to '$IPS_VARIABLE'-trigger
} else {
if ($debug) fwrite($handle, date("d.m.y")." ". date("H:i:s")." $IPS_SENDER - $thisinstance is set EXTERNALLY to " . GetValueFloat($key."_state") . "°C due to '$IPS_VARIABLE'-trigger (no value sent... logging only)
} elseif ($IPS_SENDER == "RunScript") {
// only set soll-temp if there are changes required (flank-detection) to reset manual intervention
if ($debug) echo("Trigger : timerevent, Is '" . $temp[substr($value["result"],$pos,1)] . "' = '" . $temp[substr($value["result"],$prevpos,1)] . "' ?
if ($temp[substr($value["result"],$pos,1)] <> $temp[substr($value["result"],$prevpos,1)]){
//flank detected
if ($debug) echo("FHT_SetTemp for $thisinstance $neg SENT due to change of setting (flank detection).
if ($debug) fwrite($handle, date("d.m.y")." ". date("H:i:s")." $IPS_SENDER - FHT_SetTemp for $thisinstance $neg SENT due to change of setting (flank detection).
} else {
if ($debug) fwrite($handle, date("d.m.y")." ". date("H:i:s")." $IPS_SENDER - No flank detected for $thisinstance.
} else {
//manual exec.
if ($debug) echo("FHT_SetTemp for $thisinstance $neg SENT due to manual-exec.
if ($debug) fwrite($handle, date("d.m.y")." ". date("H:i:s")." $IPS_SENDER/MANUAL - FHT_SetTemp for $thisinstance $neg SENT due to manual-exec.
// ugly way to handle FHZ buffer issues
// should be done by multiple passes so max 6 commands every 6 minutes
// multiple passes ToDo
// Paresy talked about a FHT1000 buffer; maybe there is a way to deal with this??
// removed in version: 0.66 FHT-buffer now in place
//if (bcmod($junk, 6) == 0) IPS_Sleep(1000*10); // wait 10 seconds FHZbuffer !!;
//$junk += 1;
// 2006/05/30 modifie due to multi-hreads
SetValueBoolean($V_INHIBIT,false);
// 2006/05/30 end modifie
if ($debug) echo("Finished
if ($debug) fclose($handle);
Ich vermute, dass ich nur falsche Trigger oder falsche Variablen gesetzt habe…
Gruß,
Christoph
