Ich habe das script von Dr. Niels (siehe oben) laufen lassen mit den folgenden Fehlermeldungen
Warning: Use of undefined constant ‚DeviceSceneSimple‘ - assumed ‚‚DeviceSceneSimple‘‘ (this will throw an Error in a future version of PHP) in C:\ProgramData\Symcon\scripts\49596.ips.php on line 4
Warning: Use of undefined constant ‚objects‘ - assumed ‚‚objects‘‘ (this will throw an Error in a future version of PHP) in C:\ProgramData\Symcon\scripts\49596.ips.php on line 4
Warning: Use of undefined constant ‚ID25800‘ - assumed ‚‚ID25800‘‘ (this will throw an Error in a future version of PHP) in C:\ProgramData\Symcon\scripts\49596.ips.php on line 4
Warning: Use of undefined constant ‚data‘ - assumed ‚‚data‘‘ (this will throw an Error in a future version of PHP) in C:\ProgramData\Symcon\scripts\49596.ips.php on line 4
Warning: Use of undefined constant ‚configuration‘ - assumed ‚‚configuration‘‘ (this will throw an Error in a future version of PHP) in C:\ProgramData\Symcon\scripts\49596.ips.php on line 4
Notice: Undefined index: ‚objects‘ in C:\ProgramData\Symcon\scripts\49596.ips.php on line 4
Notice: Trying to access array offset on value of type null in C:\ProgramData\Symcon\scripts\49596.ips.php on line 4
Warning: InstanceInterface is not available in C:\ProgramData\Symcon\scripts\49596.ips.php on line 4
Warning: InstanceInterface is not available in C:\ProgramData\Symcon\scripts\49596.ips.php on line 5
Wenn ich Google Home öffnen will kommt diese Fehlermeldung
Löschen und Neuinstallieren bringt keine veränderung
