I’ve added two new routines to Google Assistent today. After a sync they’ve been added and I’m able to use them. However, ALL previously configured and added routines are not working anymore. I get the dreaded „Sorry, not able to connect to IP Symcon“ for every one of them.
All ‚standard‘ light commands and the 2 new routines work as expected.
What can I do to get the previously configured routines working again?
I’m using IP-Symcon 6.1, Windows (amd64), 01/03/2022, bdfbb2708d22. I didn’t update the Google Assistant module to the beta version. Is that something I should/could try?
I don’t think this will help. Just to clarify: The other routines are stillt configured and available in IP-Symcon? And the configuration says „OK“ in the Status column?
