Am I correct in thinking that you can’t use the Google Assistant module in conjunction with the Scene Control module? If not, that could be an usefull feature.
Best regards,
Dennis.
Best regards,
Dennis.
That is not possible. Google is thinking in single „devices“ and not as a full scene. But you might be able to call a scene through Assistant: Szenen — IP-Symcon :: Automatisierungssoftware
(You will need to map the a script to the scene for now)
That’s what I did. I’ve created a (very) simple script calling the scene.
Thanks for the comfirmation!
Dennis.
