WIIPS Beta lÀuft bisher stabil
Aber eine Frage habe ich, ich habe nur Multi-Grafiken die alle 60min. erstellt werden sollen. Bei mir werden die Grafiken aber trotzdem in kurzen AbstÀnden erstellt.
Hier mal ein StĂŒck aus dem Log-File:
19.01.2006 21:31:00 | DEBUG | EventScripter | [Queued,Size=0] | Script: TimerEvent | Sender: TimerEvent
19.01.2006 21:31:00 | DEBUG | ScriptThread | Executing Script: TimerEvent ~ Sender: TimerEvent #
19.01.2006 21:31:00 | DEBUG | EventScripter | Including Script: RRD_DataPoller
19.01.2006 21:31:00 | CUSTOM | RRD_DataPoller | 0 Database(s) updated.
19.01.2006 21:31:00 | DEBUG | EventScripter | Including Script: RRD_GraphBuilder
19.01.2006 21:31:00 | DEBUG | VariableManager | Variable: LastTimer (Integer), Value: 1137702660
19.01.2006 21:31:00 | DEBUG | ScriptThread | Executed Script: TimerEvent ~ Sender: TimerEvent #
19.01.2006 21:31:00 | DEBUG | EventScripter | # PHP Result ~ Script: TimerEvent ~ Sender: TimerEvent #
19.01.2006 21:31:00 | DEBUG | EventScripter | Timer [RRD_DataPoller] Triggered Timer [RRD_GraphBuilder] Triggered
19.01.2006 21:31:00 | DEBUG | EventScripter | # END #
19.01.2006 21:31:45 | DEBUG | VariableManager | Variable: Stellantrieb_Wohn (Float), Value: 75,78125
19.01.2006 21:32:00 | DEBUG | EventScripter | [Queued,Size=0] | Script: TimerEvent | Sender: TimerEvent
19.01.2006 21:32:00 | DEBUG | ScriptThread | Executing Script: TimerEvent ~ Sender: TimerEvent #
19.01.2006 21:32:00 | DEBUG | EventScripter | Including Script: RRD_DataPoller
19.01.2006 21:32:00 | CUSTOM | RRD_DataPoller | 0 Database(s) updated.
19.01.2006 21:32:00 | DEBUG | EventScripter | Including Script: RRD_GraphBuilder
19.01.2006 21:32:00 | DEBUG | VariableManager | Variable: LastTimer (Integer), Value: 1137702720
19.01.2006 21:32:01 | DEBUG | ScriptThread | Executed Script: TimerEvent ~ Sender: TimerEvent #
19.01.2006 21:32:01 | DEBUG | EventScripter | # PHP Result ~ Script: TimerEvent ~ Sender: TimerEvent #
19.01.2006 21:32:01 | DEBUG | EventScripter | Timer [RRD_DataPoller] Triggered Timer [RRD_GraphBuilder] Triggered
19.01.2006 21:32:01 | DEBUG | EventScripter | # END #
19.01.2006 21:33:00 | DEBUG | EventScripter | [Queued,Size=0] | Script: TimerEvent | Sender: TimerEvent
19.01.2006 21:33:00 | DEBUG | ScriptThread | Executing Script: TimerEvent ~ Sender: TimerEvent #
19.01.2006 21:33:00 | DEBUG | EventScripter | Including Script: RRD_DataPoller
19.01.2006 21:33:00 | CUSTOM | RRD_DataPoller | 0 Database(s) updated.
19.01.2006 21:33:00 | DEBUG | EventScripter | Including Script: RRD_GraphBuilder
19.01.2006 21:33:00 | DEBUG | VariableManager | Variable: LastTimer (Integer), Value: 1137702780
19.01.2006 21:33:00 | DEBUG | ScriptThread | Executed Script: TimerEvent ~ Sender: TimerEvent #
19.01.2006 21:33:00 | DEBUG | EventScripter | # PHP Result ~ Script: TimerEvent ~ Sender: TimerEvent #
19.01.2006 21:33:00 | DEBUG | EventScripter | Timer [RRD_DataPoller] Triggered Timer [RRD_GraphBuilder] Triggered
19.01.2006 21:33:00 | DEBUG | EventScripter | # END #
Ist das ein Fehler von mir, oder ein Bug ?
