ich habe die Vermutung, dass es an der Datei …\web\base\language.ips liegen könnte, denn die verweist auf den Wert „undefined language“.
Hier ist meine language.ips:
(c) 2005 by Torro / paresy
* This library is free software; you can redistribute it and/or modify it
* under the terms of the GNU Library General Public License as published by
* the Free Software Foundation; either version 2 of the License, or (at your
* option) any later version.
* This library is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU Library General Public
* License for more details.
* You should have received a copy of the GNU Library General Public License
* along with this library; if not, write to the Free Software Foundation,
$version = 'V0.70';
$vtext = 'Language Class';
// Version: 0.70 (25.11.2005) (paresy)
// - Erste Version
class IPS_LanguageSystem {
private $languagepath;
private $defaultlanguage = "en"; //Use if $language string is not set
private $currentlanguage;
private $currentmodule;
private $currenttemplate;
* Constructor
public function __construct( $languagepath="./languages", $language="de" )
$this->languagepath=$languagepath;
if ( isset($_SESSION['_language']) ) {
$this->currentlanguage = $_SESSION['_language'];
} else {
$this->currentlanguage = $language;
$this->langarray=Array();
$this->loadfiles();
* Setzt die Sprache nach Anmeldung
public function setlanguage($userlanguage) {
$this->currentlanguage=$userlanguage;
* Gibt einen String zurück
private function getstring($strname) {
if(isset($this->langarray[$this->currentmodule][$this->currentlanguage][$this->currenttemplate])
&& array_key_exists($strname[1], $this->langarray[$this->currentmodule][$this->currentlanguage][$this->currenttemplate])) {
return $this->langarray[$this->currentmodule][$this->currentlanguage][$this->currenttemplate][$strname[1]];
} elseif(isset($this->langarray[$this->currentmodule][$this->defaultlanguage][$this->currenttemplate])
&& array_key_exists($strname[1], $this->langarray[$this->currentmodule][$this->defaultlanguage][$this->currenttemplate])) {
return $this->langarray[$this->currentmodule][$this->defaultlanguage][$this->currenttemplate][$strname[1]];
} else {
return "UNDEFINED LANGUAGE STRING {".$strname[1]."}";
* Gibt einen String zurück unterangabe vom Modul
public function getmodulestring($strname, $strmodule, $strtemplate) {
$this->currentmodule=$strmodule;
$this->currenttemplate=$strtemplate;
return $this->getstring(Array("", $strname));
* Lädt Sprachdateien
public function loadfiles() {
if ($handle = opendir($this->languagepath)) {
while (false !== ($file = readdir($handle))) {
if($file!="." && $file!="..") {
if ( substr($file,-8) == ".ips.php" ) {
require_once($this->languagepath."/".$file);
if($lnglang==$this->currentlanguage || $lnglang == $this->defaultlanguage) {
$this->langarray=array_merge_recursive($this->langarray, $lngarray);
closedir($handle);
* Parst Inhalt
public function parse($content, $modulename, $templatename) {
$this->currentmodule=$modulename;
$this->currenttemplate=$templatename;
return preg_replace_callback("/s*{(\w+)}s*/", Array(&$this, "getstring"), $content);
ja, ich weiss. Ich arbeite das an der Stelle nochmal um, damit es auch mit den Sprachen / Modulen klappt. Dauert allerdings etwas laenger als das Sortierungs Problem…
