…hier der entsprechende Teil:
public function GetConfigurationForm()
$arrayStatus = array();
$arrayStatus = array(„code“ => 101, „icon“ => „inactive“, „caption“ => „Instanz wird erstellt“);
$arrayStatus = array(„code“ => 102, „icon“ => „active“, „caption“ => „Instanz ist aktiv“);
$arrayStatus = array(„code“ => 104, „icon“ => „inactive“, „caption“ => „Instanz ist inaktiv“);
$arrayStatus = array(„code“ => 202, „icon“ => „error“, „caption“ => „Kommunikationfehler!“);
$arrayElements = array();
$arrayElements[] = array("type" => "Label", "caption" => "UNVOLLSTÄNDIGE FUNKTION!");
$arrayElements[] = array("type" => "SelectCategory", "name" => "Category", "caption" => "Zielkategorie");
$arrayElements[] = array("type" => "Label", "label" => "_____________________________________________________________________________________________________");
// Tabelle für die gefundenen I²C-Devices
$arraySort = array();
$arraySort = array("column" => "DeviceTyp", "direction" => "ascending");
$arrayColumns = array();
$arrayColumns[] = array("caption" => "Typ", "name" => "DeviceTyp", "width" => "200px", "add" => "");
$arrayColumns[] = array("caption" => "Adresse", "name" => "DeviceAddress", "width" => "100px", "add" => "");
$arrayColumns[] = array("caption" => "Bus", "name" => "DeviceBus", "width" => "auto", "add" => "");
$Category = $this->ReadPropertyInteger("Category");
$RootNames = [];
$RootId = $Category;
while ($RootId != 0) {
if ($RootId != 0) {
$RootNames[] = IPS_GetName($RootId);
$RootId = IPS_GetParent($RootId);
$RootNames = array_reverse($RootNames);
$DeviceArray = array();
If ($this->HasActiveParent() == true) {
$DeviceArray = unserialize($this->GetData());
$TypeArray = array("AS3935" => "{BC292F9B-7CAB-4195-A85D-A6228B521E08}", "S.USV" => "{E6955943-F7F1-48CD-979D-45EEDCF91629}", "PCF8574" => "{E1E9F012-A15A-4C05-834E-7893DFE34526}",
"PCF8591" => "{A2E052CE-055C-4249-A536-7082B233B583}", "PCF8583" => "{95276FA0-4847-411E-B700-2E5F1866A7F6}", "GeCoS PWM16Out" => "{2ED6393D-E9A6-4C68-824C-90530EDDCE5C}",
"GeCoS RGBW" => "{3AB26B93-0DD1-4F5C-AFC8-1C3A855F7D14}", "iAQ" => "{1ABC9D19-31BF-4482-8FE0-6D3843D1D77A}", "BH1750" => "{C3884BB9-1D68-4AF7-B73E-357D810042A7}",
"EZO ORP" => "{51401510-EBA1-2C99-5B39-3C0C9C9758B6}", "EZO PH" => "{4D846905-0066-AB5D-F997-DC01CB1D975E}", "MCP3424" => "{0EBA825C-47AD-4BC6-AC0D-1ADF9CD55AB2}",
"BME280" => "{64E6464A-664C-46DE-B49F-8629497ED56F}", "BME680" => "{54EBA6FB-A557-4CB9-B384-933D6F5155B6}", "BMP180" => "{9D970308-36E7-428D-8AC0-D8C1496DDCCA}");
$BusArray = array("I²C-Bus 0", "I²C-Bus 1", "MUX I²C-Bus 0", "MUX I²C-Bus 1", "MUX I²C-Bus 2", "MUX I²C-Bus 3", "MUX I²C-Bus 4", "MUX I²C-Bus 5", "MUX I²C-Bus 6", "MUX I²C-Bus 7",);
$arrayValues = array();
for ($i = 0; $i < Count($DeviceArray); $i++) {
If (array_key_exists($DeviceArray[$i]["Typ"], $TypeArray)) {
$arrayCreate = array();
$GUID = $TypeArray[$DeviceArray[$i]["Typ"]];
$Bus = array_search($DeviceArray[$i]["Bus"], $BusArray);
$arrayCreate[] = array("moduleID" => $GUID, "location" => $RootNames,
"configuration" => array("DeviceAddress" => $DeviceArray[$i]["Adresse"], "DeviceBus" => $Bus));
$arrayValues[] = array("DeviceTyp" => $DeviceArray[$i]["Typ"], "DeviceAddress" => $DeviceArray[$i]["Adresse"], "DeviceBus" => $DeviceArray[$i]["Bus"],
"instanceID" => $DeviceArray[$i]["InstanceID"], "create" => $arrayCreate);
else {
"instanceID" => $DeviceArray[$i]["InstanceID"]);
$arrayElements[] = array("type" => "Configurator", "name" => "I2CDevices", "caption" => "I2C Devices", "rowCount" => 10, "delete" => false, "sort" => $arraySort, "columns" => $arrayColumns, "values" => $arrayValues);
return JSON_encode(array("status" => $arrayStatus, "elements" => $arrayElements));
