Axel37
11. November 2017 um 09:37
1
Moin
@paresy
bekomme heute morgen häufig Fehler 500 und:
Class 'vB_Phrase' not found on line 120 in /var/www/forum/vb/vb.php
#0 /var/www/forum/includes/class_bootstrap_framework.php(101): vB::init(false)
#1 /var/www/forum/includes/functions.php(7723): vB_Bootstrap_Framework::init()
#2 /var/www/forum/includes/init.php(890): bootstrap_framework()
#3 /var/www/forum/includes/class_bootstrap.php(101): require_once('/var/www/forum/...')
#4 /var/www/forum/includes/class_bootstrap.php(72): vB_Bootstrap->init()
#5 /var/www/forum/global.php(26): vB_Bootstrap->bootstrap()
#6 /var/www/forum/search.php(89): require_once('/var/www/forum/...')
#7 {main}
Gruss Axel
1007
11. November 2017 um 09:48
2
Bei mir ab und zu:
Class 'vB_Types' not found on line 1322 in /var/www/forum/packages/vbattach/attach.php
#0 /var/www/forum/showthread.php(964): vB_Attach_Display_Content->__construct(Object(vB_Registry), 'vBForum_Post')
#1 {main}
tommi
11. November 2017 um 10:06
3
nach dem 3. Refresh geht es meistens, beim 2. Refresh kommt ein HTTP 500
Class 'vB_Cache_Observer_Db' not found on line 131 in /var/www/forum/vb/cache.php
#0 /var/www/forum/vb/types.php(151): vB_Cache::instance()
#1 /var/www/forum/vb/types.php(120): vB_Types->loadTypes()
#2 /var/www/forum/vb/types.php(136): vB_Types->__construct()
#3 /var/www/forum/packages/vbattach/attach.php(1322): vB_Types::instance()
#4 /var/www/forum/includes/class_postbit.php(529): vB_Attach_Display_Content->__construct(Object(vB_Registry), 'vBForum_Post')
#5 /var/www/forum/includes/class_postbit.php(331): vB_Postbit->process_attachments()
#6 /var/www/forum/showthread.php(1097): vB_Postbit->construct_postbit(Array)
#7 {main}
11. November 2017 um 10:35
4
Danke für den Hinweis. Das Problem sollte gelöst sein! Falls noch etwas nicht rund läuft bitte bescheid sagen - dann schaue ich noch mal
