FlowHandler | Could not forward data to instance #11860: Received unsupported Device data AD
FlowHandler | Could not forward data to instance #11860: Received unsupported Device data E6
FlowHandler | Could not forward data to instance #11860: Received unsupported Device data 76
FlowHandler | Could not forward data to instance #11860: Received unsupported Device data 03
FlowHandler | Could not forward data to instance #11860: Received unsupported Device data 49
How I can I troubleshoot this error message? (#11860 = EnOcean Gateway)
I think those must be false-positives when the EnOcean module is receiving some garbage. As i have seem various reports of this problem, that never could be tracked down as a real error i will disable those errors and move them to the Debug section. Symcon will just drop those invalid packets.
I don’t think I have any issues. If there’s nothing I or others can do to troubleshoot this problem, it might be better to hide the error and move it to the debug section. It’s possible that these issues began after resolving the warning in the following thread:
Another one, but now with debug log:
TXT: 10-02-2025, 22:19:52 | TRANSMIT | U<NUL><SOH><NUL><ENQ>p'
HEX: 10-02-2025, 22:19:52 | TRANSMIT | 55 00 01 00 05 70 27 F5
TXT: 10-02-2025, 22:19:52 | Parse Buffer | U<NUL>
HEX: 10-02-2025, 22:19:52 | Parse Buffer | 55 00
TXT: 10-02-2025, 22:19:52 | Chunk Incomplete |
HEX: 10-02-2025, 22:19:52 | Chunk Incomplete |
TXT: 10-02-2025, 22:19:52 | Parse Buffer | U<NUL><ETX>
HEX: 10-02-2025, 22:19:52 | Parse Buffer | 55 00 03
TXT: 10-02-2025, 22:19:52 | Parse Buffer | U<NUL><ETX><NUL>
HEX: 10-02-2025, 22:19:52 | Parse Buffer | 55 00 03 00
TXT: 10-02-2025, 22:19:52 | Parse Buffer | U<NUL><ETX><NUL><STX>
HEX: 10-02-2025, 22:19:52 | Parse Buffer | 55 00 03 00 02
HEX: 10-02-2025, 22:19:52 | Parse Buffer | 55 00 03 00 02 B3
TXT: 10-02-2025, 22:19:52 | Parse Buffer | U<NUL><ETX><NUL><STX> <NUL>
HEX: 10-02-2025, 22:19:52 | Parse Buffer | 55 00 03 00 02 B3 00
HEX: 10-02-2025, 22:19:52 | Parse Buffer | 55 00 03 00 02 B3 00 DC
TXT: 10-02-2025, 22:19:52 | Parse Buffer | U<NUL><ETX><NUL><STX> <NUL> <DLE>
HEX: 10-02-2025, 22:19:52 | Parse Buffer | 55 00 03 00 02 B3 00 DC 10
TXT: 10-02-2025, 22:19:52 | Parse Buffer | U<NUL><ETX><NUL><STX> <NUL> <DLE>6
HEX: 10-02-2025, 22:19:52 | Parse Buffer | 55 00 03 00 02 B3 00 DC 10 36
TXT: 10-02-2025, 22:19:52 | Parse Data: 02 | <NUL> <DLE>
HEX: 10-02-2025, 22:19:52 | Parse Data: 02 | 00 DC 10
TXT: 10-02-2025, 22:19:52 | RESULT | <NUL> <DLE>
HEX: 10-02-2025, 22:19:52 | RESULT | 00 DC 10
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00
TXT: 10-02-2025, 22:19:53 | Chunk Incomplete |
HEX: 10-02-2025, 22:19:53 | Chunk Incomplete |
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><LF>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><LF><BEL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><LF><BEL><SOH>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><LF><BEL><SOH> <NUL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><LF><BEL><SOH> <NUL>[<BEL><CAN><SOH>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><LF><BEL><SOH> <NUL>[<BEL><CAN><SOH><ETX>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01 03
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01 03 88
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01 03 88 97
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><LF><BEL><SOH> <NUL>[<BEL><CAN><SOH><ETX> <NUL><SOH>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01 03 88 97 00 01
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01 03 88 97 00 01 FF
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01 03 88 97 00 01 FF FF
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01 03 88 97 00 01 FF FF FF
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01 03 88 97 00 01 FF FF FF FF
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><LF><BEL><SOH> <NUL>[<BEL><CAN><SOH><ETX> <NUL><SOH> S
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01 03 88 97 00 01 FF FF FF FF 53
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><LF><BEL><SOH> <NUL>[<BEL><CAN><SOH><ETX> <NUL><SOH> S<NUL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01 03 88 97 00 01 FF FF FF FF 53 00
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 0A 07 01 EB A5 00 5B 07 18 01 03 88 97 00 01 FF FF FF FF 53 00 FB
TXT: 10-02-2025, 22:19:53 | Parse Data: 01 | <NUL>[<BEL><CAN><SOH><ETX> <NUL>
HEX: 10-02-2025, 22:19:53 | Parse Data: 01 | A5 00 5B 07 18 01 03 88 97 00
TXT: 10-02-2025, 22:19:53 | Parse Data (Opt) | <SOH> S<NUL>
HEX: 10-02-2025, 22:19:53 | Parse Data (Opt) | 01 FF FF FF FF 53 00
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z <NUL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80 00
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z <NUL><NUL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80 00 00
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z <NUL><NUL><DLE>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80 00 00 10
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z <NUL><NUL><DLE>8
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80 00 00 10 38
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z <NUL><NUL><DLE>8<NUL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80 00 00 10 38 00
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z <NUL><NUL><DLE>8<NUL><SOH>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80 00 00 10 38 00 01 FF
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80 00 00 10 38 00 01 FF FF
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80 00 00 10 38 00 01 FF FF FF FF
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z <NUL><NUL><DLE>8<NUL><SOH> Q
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80 00 00 10 38 00 01 FF FF FF FF 51
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z <NUL><NUL><DLE>8<NUL><SOH> Q<NUL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80 00 00 10 38 00 01 FF FF FF FF 51 00
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z <NUL><NUL><DLE>8<NUL><SOH> Q<NUL>h
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 80 00 00 10 38 00 01 FF FF FF FF 51 00 68
TXT: 10-02-2025, 22:19:53 | Parse Data: 01 | <NUL><NUL><DLE>8<NUL>
HEX: 10-02-2025, 22:19:53 | Parse Data: 01 | F6 80 00 00 10 38 00
TXT: 10-02-2025, 22:19:53 | Parse Data (Opt) | <SOH> Q<NUL>
HEX: 10-02-2025, 22:19:53 | Parse Data (Opt) | 01 FF FF FF FF 51 00
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z P
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z P<NUL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z P<NUL><NUL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z P<NUL><NUL><ENQ>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00 05
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00 05 B0
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z P<NUL><NUL><ENQ> <DLE>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00 05 B0 10
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z P<NUL><NUL><ENQ> <DLE><SOH>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00 05 B0 10 01
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00 05 B0 10 01 FF
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00 05 B0 10 01 FF FF
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00 05 B0 10 01 FF FF FF
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00 05 B0 10 01 FF FF FF FF
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z P<NUL><NUL><ENQ> <DLE><SOH> ;
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00 05 B0 10 01 FF FF FF FF 3B
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z P<NUL><NUL><ENQ> <DLE><SOH> ;<NUL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00 05 B0 10 01 FF FF FF FF 3B 00
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A F6 50 00 00 05 B0 10 01 FF FF FF FF 3B 00 F5
TXT: 10-02-2025, 22:19:53 | Parse Data: 01 | P<NUL><NUL><ENQ> <DLE>
HEX: 10-02-2025, 22:19:53 | Parse Data: 01 | F6 50 00 00 05 B0 10
TXT: 10-02-2025, 22:19:53 | Parse Data (Opt) | <SOH> ;<NUL>
HEX: 10-02-2025, 22:19:53 | Parse Data (Opt) | 01 FF FF FF FF 3B 00
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z<BEL>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z<BEL><CAN>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07 18
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z<BEL><CAN><SOH>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07 18 01
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z<BEL><CAN><SOH><ETX>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07 18 01 03
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07 18 01 03 88
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07 18 01 03 88 97
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z<BEL><CAN><SOH><ETX> <SOH>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07 18 01 03 88 97 01
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z<BEL><CAN><SOH><ETX> <SOH><SOH>
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07 18 01 03 88 97 01 01
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07 18 01 03 88 97 01 01 FF
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07 18 01 03 88 97 01 01 FF FF
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07 18 01 03 88 97 01 01 FF FF FF
TXT: 10-02-2025, 22:19:53 | Parse Buffer | U<NUL><BEL><BEL><SOH>z<BEL><CAN><SOH><ETX> <SOH><SOH> 7<NUL>$
HEX: 10-02-2025, 22:19:53 | Parse Buffer | 55 00 07 07 01 7A 07 18 01 03 88 97 01 01 FF FF FF FF 37 00 24
TXT: 10-02-2025, 22:19:53 | Parse Data: 01 | <BEL><CAN><SOH><ETX> <SOH>
HEX: 10-02-2025, 22:19:53 | Parse Data: 01 | 07 18 01 03 88 97 01
TXT: 10-02-2025, 22:19:53 | Parse Data (Opt) | <SOH> 7<NUL>
HEX: 10-02-2025, 22:19:53 | Parse Data (Opt) | 01 FF FF FF FF 37 00
