Hier noch ein Auszug aus dem culesa.log File
=>Dev 011E (5CCA:): Tot:118, Cur: 1 Ticks: 23
Sun, 01 Sep 2013 18:49:04 +0200 S3D5CCA011E000000760000000000001744
=>Dev 011E (5CCA:): Tot:118, Cur: 0 Ticks: 23
Sun, 01 Sep 2013 18:49:04 +0200 SBD5CCA011E000000760000000000001743
Sun, 01 Sep 2013 18:51:23 +0200 S3E5CCA011E000000770001000000001744
=>Dev 011E (5CCA:): Tot:119, Cur: 1 Ticks: 23
Sun, 01 Sep 2013 18:53:29 +0200 S3F5CCA011E000000770000000000001742
=>Dev 011E (5CCA:): Tot:119, Cur: 0 Ticks: 23
Sun, 01 Sep 2013 18:54:56 +0200 S705E69011E0006A0CE000100000000C836
=>Dev 011E (5E69:): Tot:434382, Cur: 1 Ticks: 200
Sun, 01 Sep 2013 18:54:56 +0200 SF05E69011E0006A0CE000100000000C835
Sun, 01 Sep 2013 18:56:24 +0200 SC05CCA011E0000007B0004000000001742
=>Dev 011E (5CCA:): Tot:123, Cur: 4 Ticks: 23
Sun, 01 Sep 2013 18:57:58 +0200 SF15E69011E0006A0CF000100000000C835
=>Dev 011E (5E69:): Tot:434383, Cur: 1 Ticks: 200
Sun, 01 Sep 2013 18:59:05 +0200 S415CCA011E0000007F0004000000001742
=>Dev 011E (5CCA:): Tot:127, Cur: 4 Ticks: 23
Sun, 01 Sep 2013 18:59:06 +0200 SC15CCA011E0000007F0004000000001743
Sun, 01 Sep 2013 19:00:43 +0200 S725E69011E0006A0D0000100000000C836
=>Dev 011E (5E69:): Tot:434384, Cur: 1 Ticks: 200
Sun, 01 Sep 2013 19:01:31 +0200 S425CCA011E000000830004000000001742
=>Dev 011E (5CCA:): Tot:131, Cur: 4 Ticks: 23
Sun, 01 Sep 2013 19:05:33 +0200 S745E69011E0006A0D2000200000000C832
=>Dev 011E (5E69:): Tot:434386, Cur: 2 Ticks: 200
Sun, 01 Sep 2013 19:06:44 +0200 S445CCA011E000000890004000000001743
=>Dev 011E (5CCA:): Tot:137, Cur: 4 Ticks: 23
Sun, 01 Sep 2013 19:06:44 +0200 SC45CCA011E000000890004000000001743
Sun, 01 Sep 2013 19:07:37 +0200 S755E69011E0006A0D2000000000000C834
=>Dev 011E (5E69:): Tot:434386, Cur: 0 Ticks: 200
Sun, 01 Sep 2013 19:09:31 +0200 S455CCA011E0000008C0003000000001743
=>Dev 011E (5CCA:): Tot:140, Cur: 3 Ticks: 23
Sun, 01 Sep 2013 19:10:30 +0200 SF65E69011E0006A0D3000100000000C834
=>Dev 011E (5E69:): Tot:434387, Cur: 1 Ticks: 200
Sun, 01 Sep 2013 19:12:04 +0200 SC65CCA011E0000008F0003000000001742
=>Dev 011E (5CCA:): Tot:143, Cur: 3 Ticks: 23
Sun, 01 Sep 2013 19:13:08 +0200 S775E69011E0006A0D4000100000000C835
=>Dev 011E (5E69:): Tot:434388, Cur: 1 Ticks: 200
Sun, 01 Sep 2013 19:13:09 +0200 SF75E69011E0006A0D4000100000000C834
Sun, 01 Sep 2013 19:14:23 +0200 SC75CCA011E000000910002000000001742
=>Dev 011E (5CCA:): Tot:145, Cur: 2 Ticks: 23
Sun, 01 Sep 2013 19:15:32 +0200 S785E69011E0006A0D5000100000000C835
=>Dev 011E (5E69:): Tot:434389, Cur: 1 Ticks: 200
Sun, 01 Sep 2013 19:15:33 +0200 SF85E69011E0006A0D5000100000000C835
Sun, 01 Sep 2013 19:19:20 +0200 SC95CCA011E000000950002000000001742
=>Dev 011E (5CCA:): Tot:149, Cur: 2 Ticks: 23
Sun, 01 Sep 2013 19:21:58 +0200 S4A5CCA011E000000970002000000001743
=>Dev 011E (5CCA:)
So wie ich das sehe ist das erkannte Device 011E scheinbar abwechselnd 5cca, und 5e69. Diese beiden IDs kleben auch auf den beiden WZ Stromzählern.
Wie bekomme ich diese beiden Werte auseinander?
