Bei meiner Installation sind gerade folgende Fehlermeldungen im logfile aufgetaucht:
12:18:11 | 22195 | ERROR | FlowHandler | Could not forward data to instance #22195: boost::bad_format_string: format-string is ill-formed
12:18:11 | 22622 | ERROR | FlowHandler | Could not forward data to instance #22622: boost::bad_format_string: format-string is ill-formed
12:18:11 | 18049 | ERROR | FlowHandler | Could not forward data to instance #18049: boost::bad_format_string: format-string is ill-formed
12:18:11 | 40422 | ERROR | FlowHandler | Could not forward data to instance #40422: boost::bad_format_string: format-string is ill-formed
12:18:21 | 22195 | ERROR | FlowHandler | Could not forward data to instance #22195: boost::bad_format_string: format-string is ill-formed
12:18:21 | 22622 | ERROR | FlowHandler | Could not forward data to instance #22622: boost::bad_format_string: format-string is ill-formed
12:18:21 | 18049 | ERROR | FlowHandler | Could not forward data to instance #18049: boost::bad_format_string: format-string is ill-formed
12:18:21 | 40422 | ERROR | FlowHandler | Could not forward data to instance #40422: boost::bad_format_string: format-string is ill-formed
12:18:31 | 14626 | ERROR | FlowHandler | Could not forward data to instance #14626: boost::bad_format_string: format-string is ill-formed
12:18:31 | 18049 | ERROR | FlowHandler | Could not forward data to instance #18049: boost::bad_format_string: format-string is ill-formed
12:18:31 | 40422 | ERROR | FlowHandler | Could not forward data to instance #40422: boost::bad_format_string: format-string is ill-formed
Interessanterweise scheint ein Neustart des symcon Dienstes auch etwas komische Logeinträge zu produzieren (siehe rote _alue woe eigentlich Value stehen sollte):
15:59:30 | 55592 | MESSAGE | VariableManager | [Systemdaten, Wetter, Datum und Uhrzeit\Datum & Uhrzeit\Uhrzeit\[b]_alue[/b]] = 155930
15:59:30 | 51312 | MESSAGE | VariableManager | [Systemdaten, Wetter, Datum und Uhrzeit\Datum & Uhrzeit\Datum\[b]_alue[/b]] = 20150613
Das _alue betrifft alle Logeinträge wo Value stehen sollte.
Erst ein kompletter Neustart des Raspberry Pi (2) erzeugt wieder den Normalzustand:
16:04:30 | 42351 | MESSAGE | VariableManager | [Systemdaten, Wetter, Datum und Uhrzeit\Datum & Uhrzeit\Uhrzeit\Value] = 160430
Das ganze ist schon einmal nach ca. 1 Woche Betrieb passiert, wobei damals viele eingebaute Profile komische Sonderzeichen enthielten. Neustart des Dienstes brachte auch damals nichts. Nur ein kompletter Neustart des Raspi brachte Abhilfe.
