ich wollte gerade noch mal ein update des Raspberry machen und da erschien bei mir folgende Fehlermeldung. Kann mir jemand sagen, was das zu bedeuten hat?
Vielleicht muss ich dazu sagen, dass ich seit 3 Tagen einen neuen Router habe (Telekom LTE Hybrid) ggf. hängt das damit zusammen…?
Vielen Dank!
pi@raspberrypi:~ $ sudo apt-get update
Err http://apt.ip-symcon.de stable InRelease
Err http://apt.symcon.de stable InRelease
Err http://mirrordirector.raspbian.org jessie InRelease
Err http://apt.ip-symcon.de stable Release.gpg
Could not resolve 'apt.ip-symcon.de'
Err http://mirrordirector.raspbian.org jessie Release.gpg
Could not resolve 'mirrordirector.raspbian.org'
Err http://archive.raspberrypi.org jessie InRelease
Err http://apt.symcon.de stable Release.gpg
Could not resolve 'apt.symcon.de'
Err http://archive.raspberrypi.org jessie Release.gpg
Could not resolve 'archive.raspberrypi.org'
Reading package lists... Done
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/InRe lease
W: Failed to fetch http://apt.ip-symcon.de/dists/stable/InRelease
W: Failed to fetch http://apt.symcon.de/dists/stable/InRelease
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/InRelease
W: Failed to fetch http://apt.ip-symcon.de/dists/stable/Release.gpg Could not r esolve 'apt.ip-symcon.de'
W: Failed to fetch http://apt.symcon.de/dists/stable/Release.gpg Could not reso lve 'apt.symcon.de'
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/Rele ase.gpg Could not resolve 'mirrordirector.raspbian.org'
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/Release.gp g Could not resolve 'archive.raspberrypi.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
pi@raspberrypi:~ $
Upgrade befehl sieht folgendermaßen aus:
pi@raspberrypi:~ $ sudo apt-get upgrade
Building dependency tree
Reading state information... Done
Calculating upgrade... The following packages were automatically installed and are no longer required:
libasn1-8-heimdal libgssapi3-heimdal libhcrypto4-heimdal libheimbase1-heimdal libheimntlm0-heimdal libhx509-5-heimdal libkrb5-26-heimdal
libroken18-heimdal libwind0-heimdal libxfce4ui-1-0 xfce-keyboard-shortcuts
Use 'apt-get autoremove' to remove them.
Done
The following packages have been kept back:
gstreamer1.0-plugins-bad libgl1-mesa-dri libgstreamer-plugins-bad1.0-0 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 lxpanel
lxpanel-data nuscratch plymouth pypy-upstream raspberrypi-bootloader raspberrypi-sys-mods raspberrypi-ui-mods sonic-pi
0 upgraded, 0 newly installed, 0 to remove and 16 not upgraded.
… und dabei so:
pi@raspberrypi:~ $ sudo ps x | grep symcon
464 ? Ssl 93:39 /usr/bin/symcon service
