nachdem ich schon einige Male das IPS auf dem Raspi installiert, ging es nun 3mal schief. Der Dienst startet zwar, läßt jedoch keinen Zugriff per Konsole (Socketfehler #10061) als auch per Webfront (beides auf Port 3777) zu. Firewall ist deaktiviert, mehrere Neustarts halfen bisher auch nicht.
Deinstallation:
root@rasp2:~# apt-get purge symcon
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
libc-client2007e libonig2 libqdbm14 lsof mlock php5-cli php5-common
php5-curl php5-gd php5-imap
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED:
symcon*
0 upgraded, 0 newly installed, 1 to remove and 22 not upgraded.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 75010 files and directories currently installed.)
Removing symcon ...
IP-Symcon is not running.
Processing triggers for man-db ...
Dann Installation:
root@rasp2:~# wget -qO - http://apt.ip-symcon.de/symcon.key | sudo apt-key add -
OK
root@rasp2:~# sudo apt-get install symcon
The following NEW packages will be installed:
symcon
0 upgraded, 1 newly installed, 0 to remove and 22 not upgraded.
Need to get 0 B/5995 kB of archives.
WARNING: The following packages cannot be authenticated!
symcon
Install these packages without verification [y/N]? y
Selecting previously unselected package symcon.
(Reading database ... 74574 files and directories currently installed.)
Unpacking symcon (from .../symcon_0.1-183_armhf.deb) ...
Setting up symcon (0.1-183) ...
Starting...
/usr/bin/symcon: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3 .4.18' not found (required by /usr/bin/symcon)
/usr/bin/symcon: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3 .4.19' not found (required by /usr/bin/symcon)
IP-Symcon started with PID
root@rasp2:~#
Das hier hilft nicht: https://www.symcon.de/forum/threads/26731-FS20_SetIntensity-geht-nicht?p=249322#post249322
Dei letzten Zeilen machen mir etwas Sorge. Was kann das sein?
