Bei IQLWW_Update kommt folgender Fehler
<br />
<b>Fatal error</b>: Uncaught exception 'Exception' with message 'String could not be parsed as XML' in /mnt/data/symcon/modules/IQLWetterWarnungen/IQLWetterWarnungen/module.php:152
Stack trace:
#0 /mnt/data/symcon/modules/IQLWetterWarnungen/IQLWetterWarnungen/module.php(152): SimpleXMLElement->__construct('')
#1 /mnt/data/symcon/modules/IQLWetterWarnungen/IQLWetterWarnungen/module.php(330): IQLWetterWarnungen->GetLocalWarnings()
#2 /mnt/data/symcon/scripts/__generated.inc.php(35): IQLWetterWarnungen->Update()
#3 /mnt/data/symcon/scripts/10634.ips.php(4): IQLWW_Update(50406)
#4 {main}
thrown in <b>/mnt/data/symcon/modules/IQLWetterWarnungen/IQLWetterWarnungen/module.php</b> on line <b>152</b><br />
Abort Processing during Fatal-Error: Uncaught exception 'Exception' with message 'String could not be parsed as XML' in /mnt/data/symcon/modules/IQLWetterWarnungen/IQLWetterWarnungen/module.php:152
Stack trace:
#4 {main}
thrown
Error in Script /mnt/data/symcon/modules/IQLWetterWarnungen/IQLWetterWarnungen/module.php on Line 152
