Kann bitte auch einer hier nach schauen.
https://www.symcon.de/wiki/DemoInstallation
Das Script bricht hier mit folgender Meldung ab:
IPSModuleManager-Log-IPSModuleManager 2015-09-17 13:14:32.05 Module Download Ini File doesnt exists -> Load Ini File "Repository[]=https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini"
IPSModuleManager-Log-IPSFileHandler 2015-09-17 13:14:32.05 Copy Repository[]=https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini --> D:/SERVER/IP-Symcon/scripts/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini
Fatal error: Uncaught exception 'IPSFileHandlerException' with message 'Error while copy File Repository[]=https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini to D:/SERVER/IP-Symcon/scripts/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini' in D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php:193
Stack trace:
#0 D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php(233): IPSFileHandler->CopyFile('Repository[]=ht...', 'D:\SERVER\IP-Sy...', true)
#1 D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php(251): IPSFileHandler->CopyFiles(Array, Array)
#2 D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSModuleManager.class.php(112): IPSFileHandler->LoadFiles(Array, Array)
#3 D:\SERVER\IP-Symcon\scripts\29473.ips.php(36): IPSModuleManager->__construct('IPSTwilight', 'Repository[]=ht... in D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php on line 193
Abort Processing during Error: Uncaught exception 'IPSFileHandlerException' with message 'Error while copy File Repository[]=https://raw.github.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini to D:/SERVER/IP-Symcon/scripts/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini' in D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php:193
Stack trace:
Error in Script D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php on Line 193
Falsches github, richtig siehe baseloader-Skript
Bruno
Leider auch nix.
Bei folgender Zeile
$defaultRepository = 'Repository[]=https://raw.githubusercontent.com/brownson/IPSLibrary/Development/';
bekomme ich diese Meldungen
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:25:36.60 Create Directory D:\SERVER\IP-Symcon\backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0825/IPSLibrary/install/DownloadListFiles
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:25:36.60 Copy D:\SERVER\IP-Symcon\scripts/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini --> D:/SERVER/IP-Symcon/backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0825/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:25:36.61 Copy Repository[]=https://raw.githubusercontent.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini --> D:/SERVER/IP-Symcon/scripts/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini
Fatal error: Uncaught exception 'IPSFileHandlerException' with message 'Error while copy File Repository[]=https://raw.githubusercontent.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini to D:/SERVER/IP-Symcon/scripts/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini' in D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php:193
Stack trace:
#2 D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSModuleManager.class.php(613): IPSFileHandler->LoadFiles(Array, Array)
#3 D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSModuleManager.class.php(634): IPS in D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php on line 193
Abort Processing during Error: Uncaught exception 'IPSFileHandlerException' with message 'Error while copy File Repository[]=https://raw.githubusercontent.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini to D:/SERVER/IP-Symcon/scripts/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini' in D:\SERVER\IP-Symcon\scripts\IPSLibrary\install\IPSModuleManager\IPSFileHandler\IPSFileHandler.class.php:193
Stack trace:
Und bei folgender Zeile
$defaultRepository = 'https://raw.githubusercontent.com/brownson/IPSLibrary/Development/';
diese Meldungen
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:04.93 Create Directory D:\SERVER\IP-Symcon\backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0826/IPSLibrary/install/DownloadListFiles
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:04.94 Copy D:\SERVER\IP-Symcon\scripts/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini --> D:/SERVER/IP-Symcon/backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0826/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:04.94 Copy https://raw.githubusercontent.com/brownson/IPSLibrary/Development/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini ---> D:/SERVER/IP-Symcon/scripts/IPSLibrary/install/DownloadListFiles/IPSTwilight_FileList.ini
IPSModuleManager-Log-IPSFileVersionHandle2015-09-18 08:26:05.14 Set Version IPSTwilight=2.50.6 (Loading)
IPSModuleManager-Log-IPSFileVersionHandle2015-09-18 08:26:05.15 Set Repository IPSTwilight=https://raw.githubusercontent.com/brownson/IPSLibrary/Development/
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.15 Create Directory D:\SERVER\IP-Symcon\backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0826/IPSLibrary/install/InstallationScripts
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.15 Copy D:\SERVER\IP-Symcon\scripts/IPSLibrary/install/InstallationScripts/IPSTwilight_Installation.ips.php --> D:/SERVER/IP-Symcon/backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0826/IPSLibrary/install/InstallationScripts/IPSTwilight_Installation.ips.php
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.15 Copy https://raw.githubusercontent.com/brownson/IPSLibrary/Development/IPSLibrary/install/InstallationScripts/IPSTwilight_Installation.ips.php ---> D:/SERVER/IP-Symcon/scripts/IPSLibrary/install/InstallationScripts/IPSTwilight_Installation.ips.php
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.35 Create Directory D:\SERVER\IP-Symcon\backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0826/IPSLibrary/install/InitializationFiles/Default
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.36 Copy D:\SERVER\IP-Symcon\scripts/IPSLibrary/install/InitializationFiles/Default/IPSTwilight.ini --> D:/SERVER/IP-Symcon/backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0826/IPSLibrary/install/InitializationFiles/Default/IPSTwilight.ini
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.36 Copy https://raw.githubusercontent.com/brownson/IPSLibrary/Development/IPSLibrary/install/InitializationFiles/Default/IPSTwilight.ini ---> D:/SERVER/IP-Symcon/scripts/IPSLibrary/install/InitializationFiles/Default/IPSTwilight.ini
IPSModuleManager-Log-IPSScriptHandler 2015-09-18 08:26:05.55 Register Script IPSTwilight.ini in Program.IPSLibrary.install.InitializationFiles (File=D:\SERVER\IP-Symcon\scripts/IPSLibrary/install/InitializationFiles/IPSTwilight.ini)
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.55 Create Directory D:\SERVER\IP-Symcon\backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0826/IPSLibrary/app/modules/Weather/IPSTwilight
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.56 Copy D:\SERVER\IP-Symcon\scripts/IPSLibrary/app/modules/Weather/IPSTwilight/IPSTwilight.ips.php --> D:/SERVER/IP-Symcon/backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0826/IPSLibrary/app/modules/Weather/IPSTwilight/IPSTwilight.ips.php
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.56 Copy https://raw.githubusercontent.com/brownson/IPSLibrary/Development/IPSLibrary/app/modules/Weather/IPSTwilight/IPSTwilight.ips.php ---> D:/SERVER/IP-Symcon/scripts/IPSLibrary/app/modules/Weather/IPSTwilight/IPSTwilight.ips.php
IPSModuleManager-Log-IPSScriptHandler 2015-09-18 08:26:05.78 Register Script IPSTwilight in Program.IPSLibrary.app.modules.Weather.IPSTwilight (File=D:\SERVER\IP-Symcon\scripts/IPSLibrary/app/modules/Weather/IPSTwilight/IPSTwilight.ips.php)
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.78 Create Directory D:\SERVER\IP-Symcon\backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0826/IPSLibrary/config/modules/Weather/IPSTwilight/Default
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.79 Copy D:\SERVER\IP-Symcon\scripts/IPSLibrary/config/modules/Weather/IPSTwilight/Default/IPSTwilight_Configuration.inc.php --> D:/SERVER/IP-Symcon/backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0826/IPSLibrary/config/modules/Weather/IPSTwilight/Default/IPSTwilight_Configuration.inc.php
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.80 Copy D:\SERVER\IP-Symcon\scripts/IPSLibrary/config/modules/Weather/IPSTwilight/Default/IPSTwilight_Custom.inc.php --> D:/SERVER/IP-Symcon/backup/IPSLibrary_Load/IPSLibrary_2015-09-18_0826/IPSLibrary/config/modules/Weather/IPSTwilight/Default/IPSTwilight_Custom.inc.php
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.80 Copy https://raw.githubusercontent.com/brownson/IPSLibrary/Development/IPSLibrary/config/modules/Weather/IPSTwilight/Default/IPSTwilight_Configuration.inc.php ---> D:/SERVER/IP-Symcon/scripts/IPSLibrary/config/modules/Weather/IPSTwilight/Default/IPSTwilight_Configuration.inc.php
IPSModuleManager-Log-IPSFileHandler 2015-09-18 08:26:05.99 Copy https://raw.githubusercontent.com/brownson/IPSLibrary/Development/IPSLibrary/config/modules/Weather/IPSTwilight/Default/IPSTwilight_Custom.inc.php ---> D:/SERVER/IP-Symcon/scripts/IPSLibrary/config/modules/Weather/IPSTwilight/Default/IPSTwilight_Custom.inc.php
IPSModuleManager-Log-IPSScriptHandler 2015-09-18 08:26:06.18 Register Script IPSTwilight_Configuration in Program.IPSLibrary.config.modules.Weather.IPSTwilight (File=D:\SERVER\IP-Symcon\scripts/IPSLibrary/config/modules/Weather/IPSTwilight/IPSTwilight_Configuration.inc.php)
IPSModuleManager-Log-IPSScriptHandler 2015-09-18 08:26:06.19 Register Script IPSTwilight_Custom in Program.IPSLibrary.config.modules.Weather.IPSTwilight (File=D:\SERVER\IP-Symcon\scripts/IPSLibrary/config/modules/Weather/IPSTwilight/IPSTwilight_Custom.inc.php)
IPSModuleManager-Log-IPSFileVersionHandle2015-09-18 08:26:06.19 Set Version IPSTwilight=2.50.6 (Loaded)
IPSModuleManager-Log-IPSScriptHandler 2015-09-18 08:26:06.19 Script IPSTwilight_DemoInstallation NOT registered (Filepath)
Fatal error: Uncaught exception 'IPSUtilException' with message '"Demo" could NOT be found while searching for Path Program.IPSLibrary.install.Demo.IPSTwilight_DemoInstallation' in D:\SERVER\IP-Symcon\scripts\IPSLibrary\app\core\IPSUtils\IPSUtils.inc.php:70
Stack trace:
#0 D:\SERVER\IP-Symcon\scripts\29473.ips.php(49): IPSUtil_ObjectIDByPath('Program.IPSLibr...')
#1 D:\SERVER\IP-Symcon\scripts\29473.ips.php(8): InstallModule('IPSTwilight', '', '', 'https://raw.git...')
#2 {main}
thrown in D:\SERVER\IP-Symcon\scripts\IPSLibrary\app\core\IPSUtils\IPSUtils.inc.php on line 70
Abort Processing during Error: Uncaught exception 'IPSUtilException' with message '"Demo" could NOT be found while searching for Path Program.IPSLibrary.install.Demo.IPSTwilight_DemoInstallation' in D:\SERVER\IP-Symcon\scripts\IPSLibrary\app\core\IPSUtils\IPSUtils.inc.php:70
Stack trace:
#2 {main}
thrown
Error in Script D:\SERVER\IP-Symcon\scripts\IPSLibrary\app\core\IPSUtils\IPSUtils.inc.php on Line 70
Hat vielleicht jemand noch eine Idee?
Dann muss doch Andreas ran.
Die normale Library müsste doch laufen, oder ? Baseloader brachte keine Fehlermeldung. Lass doch das Demo-Zeug weg (habe das noch nie installiert) und lad Dir die richtigen Module per GUI runter.
Hab das Demo Script angepasst - sollte jetzt wieder laufen …
Hat super Funktioniert. Vielen Dank Andreas.
Und für mich als Anfänger ist die Demo-Installation schon sehr sehr hilfreich.
Gruß Eduard
kks2109
24. Oktober 2015 um 10:33
7
Hallo bin ein wenig ratlos,
wenn ich den Baseloader durchlaufen lasse, bekomme ich immer folgende Fehlermeldung
Download of ModuleManager
Load File https://raw.githubusercontent.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSInstaller/IPSInstaller.inc.php
Fatal error: Uncaught exception ‚Exception‘ with message ‚Download of File https://raw.githubusercontent.com/brownson/IPSLibrary/Development/IPSLibrary/install/IPSInstaller/IPSInstaller.inc.php failed !!!‘ in C:\IPS\IP-Symcon\scripts\IPSLibrary_BaseLoader.ips.php:58
Stack trace:
#0 C:\IPS\IP-Symcon\scripts\IPSLibrary_BaseLoader.ips.php(30): LoadFile(‚https://raw.git …‘, ‚C:\IPS\IP-Symco…‘)
#1 C:\IPS\IP-Symcon\scripts\23085.ips.php(26): include(‚C:\IPS\IP-Symco…‘)
#2 {main}
thrown in C:\IPS\IP-Symcon\scripts\IPSLibrary_BaseLoader.ips.php on line 58
kann jemand helfen?
kks2109
24. Oktober 2015 um 11:26
8
nach mehrmaligem manuellen verbinden und überprüfen der links, aber ohne das ich etwas geändert hätte…funktioniert es. Nicht zu erklären aber ok.
