I was working with my module it was running well. I could see the registered variables but after a short change in the number of iterations, i tried to relaod and it showed fatal error cannot redeclare i2gdsp_ update previously declared in ip symcom / genereated inc.
Can anyone help ?
Does restarting the IPS service Fix the issue?
presy
Yes fortunately tried it in the morning and it worked. Now i cannot see the same error.
Thank you
