$FadingSeconds = 1;
$Channel = 1;
$DMX_Instance_ID = 12345;
//Dezimalwert in Hex wandeln
$RGB = dechex($_IPS["VALUE"]);
//Mit führenden Nullen auf 6 Stellen auffüllen
$RGB = str_pad($RGB, 6 ,'0', STR_PAD_LEFT);
//die Einzelnen Farbanteile berechnen
$R = hexdec(substr($RGB,0,2));
$G = hexdec(substr($RGB,2,2));
$B = hexdec(substr($RGB,4,2));
print_r("Rot: ".$R." Grün: ".$G." Blau: ".$B);
//DMX Werte setzen
DMX_Fade($DMX_Instance_ID,$Channel,$R,$FadingSeconds);
DMX_Fade($DMX_Instance_ID,$Channel+1,$G,$FadingSeconds);
DMX_Fade($DMX_Instance_ID,$Channel+2,$B,$FadingSeconds);
