Hallo WIIPSler,
wer kann mal die nachfolgenden Texte ins Deutsche umsetzen?
$item=&$lngarray[$lngmodule][$lnglang]['rrd_conf_extended_edit'];
$item=Array(
"confedit"=>"Configuration - Extended Graph Setup",
"gline"=>"Graph Line Art",
"prop"=>$lngarray[$lngmodule][$lnglang]['rrd.config_add']['prop'],
"val"=>$lngarray[$lngmodule][$lnglang]['rrd.config_add']['val'],
"graphfor"=>"Graph Configuration for:",
"widthtext"=>"The width and height of the canvas (the part of the graph with the actual data and such).<br>
This defaults to 500 pixels by 200 pixels.",
"gwidth"=>"Graph Width:",
"gheight"=>"Graph Height:",
"period"=>"Time Period for Graph Building.",
"daily"=>"Graph Dayly Period:",
"weekly"=>"Graph Weekly Period:",
"monthly"=>"Graph Monthly Period:",
"yearly"=>"Graph Yearly Period:",
"putdata"=>"DataPoller put Data in the RRD DB inner min and max Value",
"minmeasured"=>"Graph min measured value:",
"maxmeasured"=>"Graph max measured value:",
"limittext"=>"You can change this behaviour by explicitly setting the limits. The displayed y-axis will then range at least from lower-limit to upper-limit. Autoscaling will still permit those boundaries to be stretched unless the rigid option is set.",
"yupper"=>"Graph y upper limit:",
"ylower"=>"Graph y lower limit:",
"grigid"=>"Graph rigid:",
"rpntext"=>"If you have ever used a traditional HP calculator you already know RPN. The idea behind RPN is that you have a stack and push your data onto this stack. Whenever you execute an operation, it takes as many elements from the stack as needed. Pushing is done implicitly, so whenever you specify a number or a variable, it gets pushed onto the stack automatically.",
"rpnunit"=>"Graph RPN Unit",
"w1"=>" Wert 1",
"w2"=>" Wert 2",
"w3"=>" Wert 3",
"interlaced"=>"If images are interlaced they become visible on browsers more quickly.",
"ginterlaced"=>"Graph interlaced:",
"colortext"=>"Override the default colors for the standard elements of the graph. GRID for the major grid. Optionally you may add another hexadecimal number specifying the transparency (FF is solid).",
"ggrid"=>"Graph grid:",
"alpha"=>"Alpha:",
"mgridtext"=>"Override the default colors for the standard elements of the graph. MGRID for the major mgrid. Optionally you may add another hexadecimal number specifying the transparency (FF is solid).",
"mgrid"=>"Graph mgrid:",
"shadeatext"=>"Override the default colors for the standard elements of the graph. SHADEA for the left and top border. Optionally you may add another hexadecimal number specifying the transparency (FF is solid).",
"shadea"=>"Graph shade a:",
"shadebtext"=>"Override the default colors for the standard elements of the graph. SHADEB for the left and top border. Optionally you may add another hexadecimal number specifying the transparency (FF is solid).",
"shadeb"=>"Graph shade b:",
"axistext"=>"Override the default colors for the standard elements of the graph. AXIS for the left and top border. Optionally you may add another hexadecimal number specifying the transparency (FF is solid).",
"axis"=>"Graph Axis:",
"canvastext"=>"Override the default colors for the standard elements of the graph. CANVAS for the left and top border. Optionally you may add another hexadecimal number specifying the transparency (FF is solid).",
"canvas"=>"Graph Canvas:",
Gruss Torro
