Hello all,
I used Eltako PCT14 tool to scan the FAM14 for all actors and device addresses. Can I use this to import this information in IP-Symcon? Thanks!
Dennis.
Hello all,
Dennis.
Unfortunately no - but you can create the instances manually und copy the obtained information in the DeviceID + ReturnID fields. That is a lot faster than scanning for the ReturnID each time.
