So langsam komme ich weiter - USB0 und USB1 sind nun getrennt und laufen.
Den ebusd habe ich installiert mit „wget https://github.com/john30/ebusd/releases/download/v22.1/ebusd-22.1_armv7-bullseye_mqtt1.deb“ installiert.
Die Vaillant AUROCOMPACT VSC S 196/3-5 200 R3 hängt auch dran.
Config File sieht somit so aus:
EBUSD_OPTS="–device=/dev/ttyUSB1 --scanconfig --configpath=/home/raspberry.dirk/ebusd-configurationebusd-2.1.x/de"
Nun kommt aber ein Fehler:
„error reading config files from /home/raspberry.user/ebusd-configurationebusd-2.1.x/de: ERR: element not found, last error:“
Ganze LOG file:
2022-02-28 14:40:03.347 [main notice] ebusd 22.1.28da22c started with auto scan on device /dev/ttyUSB1
2022-02-28 14:40:03.347 [main error] error reading config files from /home/raspberry.dirk/ebusd-configurationebusd-2.1.x/de: ERR: element not found, last error:
2022-02-28 14:40:03.356 [bus notice] bus started with own address 31/36
2022-02-28 14:40:03.380 [bus notice] signal acquired
2022-02-28 14:40:07.098 [bus notice] new master 10, master count 2
2022-02-28 14:40:07.166 [bus notice] new master 03, master count 3
2022-02-28 14:40:07.166 [update notice] received unknown MS cmd: 1008b5110101 / 09404090054e640000ff
2022-02-28 14:40:09.170 [update notice] received unknown BC cmd: 10feb516080018020901010510
2022-02-28 14:40:09.431 [update notice] received unknown MS cmd: 1008b512020064 / 00
2022-02-28 14:40:11.196 [update notice] received unknown MS cmd: 1008b5100900004a78ffff000000 / 0101
2022-02-28 14:40:17.206 [update notice] received unknown MS cmd: 1008b5110101 / 09404090054e640000ff
2022-02-28 14:40:19.249 [update notice] received unknown MS cmd: 1008b5040100 / 0a00350214ffffffff9005
2022-02-28 14:40:19.516 [update notice] received unknown MS cmd: 1008b5110102 / 05033c64506e
2022-02-28 14:40:21.152 [main error] scan config 08: ERR: arbitration lost
2022-02-28 14:40:21.249 [update notice] received unknown MS cmd: 1008b5100900004a78ffff000000 / 0101
2022-02-28 14:40:27.245 [update notice] received unknown MS cmd: 1008b5110101 / 094042d0054e640000ff
2022-02-28 14:40:29.276 [update notice] received unknown MS cmd: 1008b5110100 / 081002100007080083
2022-02-28 14:40:29.499 [update notice] received unknown BC cmd: 10feb51603019005
2022-02-28 14:40:31.180 [main error] scan config 15: ERR: arbitration lost
2022-02-28 14:40:31.279 [update notice] received unknown MS cmd: 1008b5100900004a78ffff000000 / 0101
2022-02-28 14:40:37.296 [update notice] received unknown MS cmd: 1008b5110101 / 094242d0054e640000ff
2022-02-28 14:40:39.267 [update notice] received unknown MS cmd: 1008b5110102 / 05033c64506e
2022-02-28 14:40:41.305 [update notice] received unknown MS cmd: 1008b5100900004a78ffff000000 / 0101
2022-02-28 14:40:47.338 [update notice] received unknown MS cmd: 1008b5110101 / 094242d0054e640000ff
2022-02-28 14:40:49.336 [update notice] received unknown MS cmd: 1008b5040100 / 0a00060314ffffffffd005
2022-02-28 14:40:51.381 [update notice] received unknown MS cmd: 1008b5100900004a78ffff000000 / 0101
2022-02-28 14:40:57.278 [main error] scan config 08: ERR: arbitration lost
2022-02-28 14:40:57.375 [update notice] received unknown MS cmd: 1008b5110101 / 094242d0054e640000ff
2022-02-28 14:40:59.347 [update notice] received unknown MS cmd: 1008b5100305ff01 / 00
d.h. da kommt auch was an - sieht man auch an der flackernden LED des ESERA Moduls.
Aber wie stelle ich den Fehler „error reading config files from /home/raspberry.user/ebusd-configurationebusd-2.1.x/de: ERR: element not found, last error:“
ab?
Muss ich das Poti noch etwas drehen um die „2022-02-28 14:40:31.180 [main error] scan config 15: ERR: arbitration lost“ heraus zu bekommen?
