Ds2438
ist es geplant den DS2438 mit dem 1-wire modul zu unterstützen?
mfg
Torsten
Ich glaube wir haben davon sogar 2 Stück da. Mir hatte sich nur noch nicht erschlossen, wo der Vorteil gegenüber dem normalen Counter ist, der bereits geht!?
Quelle Maxim
The DS2438 smart battery monitor provides several functions that are desirable to carry in a battery pack: a means of tagging a battery pack with a unique serial number, a direct-to-digital temperature sensor which eliminates the need for thermistors in the battery pack, an A/D converter which measures the battery voltage and current, an integrated current accumulator which keeps a running total of all current going into and out of the battery, an elapsed time meter, and 40 bytes of nonvolatile EEPROM memory for storage of important parameters such as battery chemistry, battery capacity, charging methodology and assembly date. Information is sent to/from the DS2438 over a 1-Wire® interface, so that only one wire (and ground) needs to be connected from a central microprocessor to a DS2438. This means that battery packs need only have three output connectors: battery power, ground, and the 1-Wire interface.
Because each DS2438 contains a unique silicon serial number, multiple DS2438s can exist on the same 1-Wire bus. This allows multiple battery packs to be charged or used in the system simultaneously.
Applications for the smart battery monitor include portable computers, portable/cellular telephones, and handheld instrumentation battery packs in which it is critical to monitor real-time battery performance. Used in conjunction with a microcontroller in the host system, the DS2438 provides a complete smart battery pack solution that is fully chemistry-independent. The customization for a particular battery chemistry and capacity is realized in the code programmed into the microcontroller and DS2438 EEPROM, and only a software revision is necessary should a designer wish to change battery pack chemistry.
Hab auch zwei davon liegen :wink:
Für sowas zum Beispiel:
http://www.maxim-ic.com/products/ibutton/weather/humsensor.pdf
wollte halt mal Basteln, schade nur das der Schaltplan so undeutlich ist.
mfg
Torsten
Hallo Torsten,
hast Du eine Quelle fuer den Honeywell Feuchtesensor? Die meisten Anbieter verkaufen diesen fuer > 25 Euro :smiley:
Gruss Torro
Das wäre dann der Haken an der Sache, ich sehe du kennst das gute Stück! Hab schon ein paar Leute aus der Firma in Arbeit gesetzt :smiley: mal sehen was draus wird :slight_smile:
grüsse
Torsten
Hallo Torsten,
deshalb gibts das bei uns auch noch nicht als Modul. Und andere Feuchtesensoren gehen nicht von 0…100 Prozent bzw. sind nicht betauungsfaehig oder wie das heisst.
Gruss Torro
Mir war hiervor noch keiner feucht sensor bekannt die 0…100% anzeigt !
Danke fuer den tip
Die meiste arbeiten nur in sommer … 40-60% gut, +10% drunter, und niks mehr bei 20<x<85%
Sauna lösung zusammen mit pt100 und 2x 1-wire 16bit DA :cool:
Hallo Fredtje,
Sauna geht aber mit dem hier auch direkt, da braucht man keinen pt100. Der ELV Feuchtesensor geht leider auch nur von 20 bis eta 90, mal von der Genauigkeit und Betauung abgesehen.
Gruss Torro
