Is it possible to disable all MQTT Client Devices in IP-Symcon when a MQTT will message has been received from the MQTT broker?
I want to prevent error messages in IP-Symcon when the MQTT broker is offline.
I added a ‚Further condition‘ to the Flow Script attached to all MQTT Client Devices that checks the MQTT ‚birth‘ (or ‚will‘) message . This prevents the Flow Script from being triggered when the MQTT server is offline.
