Hallo Paresy,
könntest du dir mal bitte diesen Plug von Devolo anschauen? Hier läuft was grundlegend falsch, so wie es ausschaut.
Wenn der Switch mit Verbraucher eingeschalten wird, springt der Verbrauchswert (kWh) wild hin und her, also hoch und runter, was für einen Zählerwert extrem schlecht ist (IPS-Powercontrol).
Die anderen Werte (außer Leistung) werden überhaupt nicht mehr aktualisiert.
Stefan
Symcon: b09a21da24bb
z-wave_switch_dump.txt (8.06 KB)
{"NodeClasses":"[37,39,43,44,50,89,90,94,112,113,114,115,117,122,133,134]","NodeControlClasses":"[]","NodeSecureClasses":"[]","NodeSecureControlClasses":"[]","NodeVersions":"{}","NodeFailed":false,"NodeFailedCounter":0,"NodeFailedReason":"","NodePacketSend":76,"NodePacketReceived":1036449,"NodePacketFailed":18,"NodePacketLastSend":1584904936,"NodePacketLastReceived":1584905296,"NodePacketLastFailed":1584904939,"NodeRSSI":190,"NodeSecurityKey":0,"ManufacturerID":"0175","ProductType":"0001","ProductID":"0012","SerialNumber":"01070002010401090900000000040404","PseudoRandom":"D85904384DE21FC7","AssociationCount":1,"AssociationGroups":"{\"1\":{\"MaxNodes\":1,\"Nodes\":[1]}}","SwitchMultilevelPrimary":0,"SwitchMultilevelSecondary":0,"SensorBinarySupported":"[]","SensorMultilevelSupported":"[]","SensorMultilevelScales":"[]","MeterSupportedType":1,"MeterSupportedRate":3,"MeterSupportedScale":1023,"MeterSupportsReset":true,"ColorCapability":0,"ThermostatSupportedMode":0,"ThermostatSupportedSetPoint":0,"ThermostatSupportedFanMode":0,"AssociationGroupInfos":"{\"1\":{\"Commands\":[],\"Name\":\"Lifeline\",\"Profile\":-1}}","PlusInfoVersion":1,"PlusInfoRoleType":5,"PlusInfoNodeType":0,"PlusInfoInstallerIconType":1792,"PlusInfoUserIconType":1792,"MultiChannelCount":0,"MultiChannelClasses":"[]","MultiChannelControlClasses":"[]","UserCodes":"{}","ConfigurationList":"{}","ConfigurationValues":"{}","NotificationSupportsAlarm":true,"NotificationSupported":"[]","ProtectionTimeout":false,"ProtectionExclusive":true,"ProtectionSupported":7,"ProtectionRFSupported":7,"WakeUpInterval":-1,"WakeUpIntervalMin":-1,"WakeUpIntervalMax":-1,"WakeUpIntervalStep":-1,"WakeUpIntervalDefault":-1,"WakeUpNodeID":0,"VersionLibraryType":3,"VersionProtocol":"4.34","VersionApplication":"1.14","VersionHardware":1,"VersionFirmware":"[]","MultiChannelAssociationCount":0,"MultiChannelAssociationGroups":"{}","SensorAlarmSupported":"[]"}
