// by Edd Dumbill (C) 1999-2002
// <edd@usefulinc.com>
// $Id: xmlrpc.inc,v 1.174 2009/03/16 19:36:38 ggiunta Exp $
// Copyright (c) 1999,2000,2002 Edd Dumbill.
// All rights reserved.
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// * Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// * Redistributions in binary form must reproduce the above
// copyright notice, this list of conditions and the following
// disclaimer in the documentation and/or other materials provided
// with the distribution.
// * Neither the name of the "XML-RPC for PHP" nor the names of its
// contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
// FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
// REGENTS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
// INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
// (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
// SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
// HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
// STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
// ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
// OF THE POSSIBILITY OF SUCH DAMAGE.
if(!function_exists('xml_parser_create'))
// For PHP 4 onward, XML functionality is always compiled-in on windows:
// no more need to dl-open it. It might have been compiled out on *nix...
if(strtoupper(substr(PHP_OS, 0, 3) != 'WIN'))
dl('xml.so');
// G. Giunta 2005/01/29: declare global these variables,
// so that xmlrpc.inc will work even if included from within a function
// Milosch: 2005/08/07 - explicitly request these via $GLOBALS where used.
$GLOBALS['xmlrpcI4']='i4';
$GLOBALS['xmlrpcInt']='int';
$GLOBALS['xmlrpcBoolean']='boolean';
$GLOBALS['xmlrpcDouble']='double';
$GLOBALS['xmlrpcString']='string';
$GLOBALS['xmlrpcDateTime']='dateTime.iso8601';
$GLOBALS['xmlrpcBase64']='base64';
$GLOBALS['xmlrpcArray']='array';
$GLOBALS['xmlrpcStruct']='struct';
$GLOBALS['xmlrpcValue']='undefined';
$GLOBALS['xmlrpcTypes']=array(
$GLOBALS['xmlrpcI4'] => 1,
$GLOBALS['xmlrpcInt'] => 1,
$GLOBALS['xmlrpcBoolean'] => 1,
$GLOBALS['xmlrpcString'] => 1,
$GLOBALS['xmlrpcDouble'] => 1,
$GLOBALS['xmlrpcDateTime'] => 1,
$GLOBALS['xmlrpcBase64'] => 1,
$GLOBALS['xmlrpcArray'] => 2,
$GLOBALS['xmlrpcStruct'] => 3
$GLOBALS['xmlrpc_valid_parents'] = array(
'VALUE' => array('MEMBER', 'DATA', 'PARAM', 'FAULT'),
'BOOLEAN' => array('VALUE'),
'I4' => array('VALUE'),
'INT' => array('VALUE'),
'STRING' => array('VALUE'),
'DOUBLE' => array('VALUE'),
'DATETIME.ISO8601' => array('VALUE'),
'BASE64' => array('VALUE'),
'MEMBER' => array('STRUCT'),
'NAME' => array('MEMBER'),
'DATA' => array('ARRAY'),
'ARRAY' => array('VALUE'),
'STRUCT' => array('VALUE'),
'PARAM' => array('PARAMS'),
'METHODNAME' => array('METHODCALL'),
'PARAMS' => array('METHODCALL', 'METHODRESPONSE'),
'FAULT' => array('METHODRESPONSE'),
'NIL' => array('VALUE'), // only used when extension activated
'EX:NIL' => array('VALUE') // only used when extension activated
// define extra types for supporting NULL (useful for json or <NIL/>)
$GLOBALS['xmlrpcNull']='null';
$GLOBALS['xmlrpcTypes']['null']=1;
// Not in use anymore since 2.0. Shall we remove it?
/// @deprecated
$GLOBALS['xmlEntities']=array(
'amp' => '&',
'quot' => '"',
'lt' => '<',
'gt' => '>',
'apos' => "'"
// tables used for transcoding different charsets into us-ascii xml
$GLOBALS['xml_iso88591_Entities']=array();
$GLOBALS['xml_iso88591_Entities']['in'] = array();
$GLOBALS['xml_iso88591_Entities']['out'] = array();
for ($i = 0; $i < 32; $i++)
$GLOBALS['xml_iso88591_Entities']['in'][] = chr($i);
$GLOBALS['xml_iso88591_Entities']['out'][] = '&#'.$i.';';
for ($i = 160; $i < 256; $i++)
/// @todo add to iso table the characters from cp_1252 range, i.e. 128 to 159?
/// These will NOT be present in true ISO-8859-1, but will save the unwary
/// windows user from sending junk (though no luck when reciving them...)
$GLOBALS['xml_cp1252_Entities']=array();
for ($i = 128; $i < 160; $i++)
$GLOBALS['xml_cp1252_Entities']['in'][] = chr($i);
$GLOBALS['xml_cp1252_Entities']['out'] = array(
'€', '?', '‚', 'ƒ',
'ˆ', '‰', 'Š', '‹',
'Œ', '?', 'Ž', '?',
'˜', '™', 'š', '›',
'œ', '?', 'ž', 'Ÿ'
$GLOBALS['xmlrpcerr'] = array(
'unknown_method'=>1,
'invalid_return'=>2,
'incorrect_params'=>3,
'introspect_unknown'=>4,
'http_error'=>5,
'no_data'=>6,
'no_ssl'=>7,
'curl_fail'=>8,
'invalid_request'=>15,
'no_curl'=>16,
'server_error'=>17,
'multicall_error'=>18,
'multicall_notstruct'=>9,
'multicall_nomethod'=>10,
'multicall_notstring'=>11,
'multicall_recursion'=>12,
'multicall_noparams'=>13,
'multicall_notarray'=>14,
'cannot_decompress'=>103,
'decompress_fail'=>104,
'dechunk_fail'=>105,
'server_cannot_decompress'=>106,
'server_decompress_fail'=>107
$GLOBALS['xmlrpcstr'] = array(
'unknown_method'=>'Unknown method',
'invalid_return'=>'Invalid return payload: enable debugging to examine incoming payload',
'incorrect_params'=>'Incorrect parameters passed to method',
'introspect_unknown'=>"Can't introspect: method unknown",
'http_error'=>"Didn't receive 200 OK from remote server.",
'no_data'=>'No data received from server.',
'no_ssl'=>'No SSL support compiled in.',
'curl_fail'=>'CURL error',
'invalid_request'=>'Invalid request payload',
'no_curl'=>'No CURL support compiled in.',
'server_error'=>'Internal server error',
'multicall_error'=>'Received from server invalid multicall response',
'multicall_notstruct'=>'system.multicall expected struct',
'multicall_nomethod'=>'missing methodName',
'multicall_notstring'=>'methodName is not a string',
'multicall_recursion'=>'recursive system.multicall forbidden',
'multicall_noparams'=>'missing params',
'multicall_notarray'=>'params is not an array',
'cannot_decompress'=>'Received from server compressed HTTP and cannot decompress',
'decompress_fail'=>'Received from server invalid compressed HTTP',
'dechunk_fail'=>'Received from server invalid chunked HTTP',
'server_cannot_decompress'=>'Received from client compressed HTTP request and cannot decompress',
'server_decompress_fail'=>'Received from client invalid compressed HTTP request'
// The charset encoding used by the server for received messages and
// by the client for received responses when received charset cannot be determined
// or is not supported
$GLOBALS['xmlrpc_defencoding']='UTF-8';
// The encoding used internally by PHP.
// String values received as xml will be converted to this, and php strings will be converted to xml
// as if having been coded with this
$GLOBALS['xmlrpc_internalencoding']='ISO-8859-1';
$GLOBALS['xmlrpcName']='XML-RPC for PHP';
$GLOBALS['xmlrpcVersion']='3.0.0.beta';
// let user errors start at 800
$GLOBALS['xmlrpcerruser']=800;
// let XML parse errors start at 100
$GLOBALS['xmlrpcerrxml']=100;
// formulate backslashes for escaping regexp
/// @deprecated
$GLOBALS['xmlrpc_backslash']=chr(92).chr(92);
// set to TRUE to enable correct decoding of <NIL/> and <EX:NIL/> values
$GLOBALS['xmlrpc_null_extension']=false;
// set to TRUE to enable encoding of php NULL values to <EX:NIL/> instead of <NIL/>
$GLOBALS['xmlrpc_null_apache_encoding']=false;
// used to store state during parsing
// quick explanation of components:
// ac - used to accumulate values
// isf - used to indicate a parsing fault (2) or xmlrpcresp fault (1)
// isf_reason - used for storing xmlrpcresp fault string
// lv - used to indicate "looking for a value": implements
// the logic to allow values with no types to be strings
// params - used to store parameters in method calls
// method - used to store method name
// stack - array with genealogy of xml elements names:
// used to validate nesting of xmlrpc elements
$GLOBALS['_xh']=null;
* Convert a string to the correct XML representation in a target charset
* To help correct communication of non-ascii chars inside strings, regardless
* of the charset used when sending requests, parsing them, sending responses
* and parsing responses, an option is to convert all non-ascii chars present in the message
* into their equivalent 'charset entity'. Charset entities enumerated this way
* are independent of the charset encoding used to transmit them, and all XML
* parsers are bound to understand them.
* Note that in the std case we are not sending a charset encoding mime type
* along with http headers, so we are bound by RFC 3023 to emit strict us-ascii.
* @todo do a bit of basic benchmarking (strtr vs. str_replace)
* @todo make usage of iconv() or recode_string() or mb_string() where available
function xmlrpc_encode_entitites($data, $src_encoding='', $dest_encoding='')
if ($src_encoding == '')
// lame, but we know no better...
$src_encoding = $GLOBALS['xmlrpc_internalencoding'];
switch(strtoupper($src_encoding.'_'.$dest_encoding))
case 'ISO-8859-1_':
case 'ISO-8859-1_US-ASCII':
$escaped_data = str_replace(array('&', '"', "'", '<', '>'), array('&', '"', ''', '<', '>'), $data);
$escaped_data = str_replace($GLOBALS['xml_iso88591_Entities']['in'], $GLOBALS['xml_iso88591_Entities']['out'], $escaped_data);
break;
case 'ISO-8859-1_UTF-8':
$escaped_data = utf8_encode($escaped_data);
break;
case 'ISO-8859-1_ISO-8859-1':
case 'US-ASCII_US-ASCII':
case 'US-ASCII_UTF-8':
case 'US-ASCII_':
case 'US-ASCII_ISO-8859-1':
case 'UTF-8_UTF-8':
//case 'CP1252_CP1252':
break;
case 'UTF-8_':
case 'UTF-8_US-ASCII':
case 'UTF-8_ISO-8859-1':
// NB: this will choke on invalid UTF-8, going most likely beyond EOF
$escaped_data = '';
// be kind to users creating string xmlrpcvals out of different php types
$data = (string) $data;
$ns = strlen ($data);
for ($nn = 0; $nn < $ns; $nn++)
$ch = $data[$nn];
$ii = ord($ch);
//1 7 0bbbbbbb (127)
if ($ii < 128)
/// @todo shall we replace this with a (supposedly) faster str_replace?
switch($ii){
case 34:
$escaped_data .= '"';
break;
case 38:
$escaped_data .= '&';
break;
case 39:
$escaped_data .= ''';
break;
case 60:
$escaped_data .= '<';
break;
case 62:
$escaped_data .= '>';
break;
default:
$escaped_data .= $ch;
} // switch
//2 11 110bbbbb 10bbbbbb (2047)
else if ($ii>>5 == 6)
$b1 = ($ii & 31);
$ii = ord($data[$nn+1]);
$b2 = ($ii & 63);
$ii = ($b1 * 64) + $b2;
$ent = sprintf ('&#%d;', $ii);
$escaped_data .= $ent;
$nn += 1;
//3 16 1110bbbb 10bbbbbb 10bbbbbb
else if ($ii>>4 == 14)
$b1 = ($ii & 15);
$b2 = ($ii & 63);
$ii = ord($data[$nn+2]);
$b3 = ($ii & 63);
$ii = ((($b1 * 64) + $b2) * 64) + $b3;
$nn += 2;
//4 21 11110bbb 10bbbbbb 10bbbbbb 10bbbbbb
else if ($ii>>3 == 30)
$b1 = ($ii & 7);
$b2 = ($ii & 63);
$b3 = ($ii & 63);
$ii = ord($data[$nn+3]);
$b4 = ($ii & 63);
$ii = ((((($b1 * 64) + $b2) * 64) + $b3) * 64) + $b4;
$nn += 3;
break;
case 'CP1252_':
case 'CP1252_US-ASCII':
$escaped_data = str_replace($GLOBALS['xml_cp1252_Entities']['in'], $GLOBALS['xml_cp1252_Entities']['out'], $escaped_data);
break;
case 'CP1252_UTF-8':
/// @todo we could use real UTF8 chars here instead of xml entities... (note that utf_8 encode all allone will NOT convert them)
break;
case 'CP1252_ISO-8859-1':
// we might as well replave all funky chars with a '?' here, but we are kind and leave it to the receiving application layer to decide what to do with these weird entities...
break;
default:
$escaped_data = '';
error_log("Converting from $src_encoding to $dest_encoding: not supported...");
return $escaped_data;
/// xml parser handler function for opening element tags
function xmlrpc_se($parser, $name, $attrs, $accept_single_vals=false)
// if invalid xmlrpc already detected, skip all processing
if ($GLOBALS['_xh']['isf'] < 2)
// check for correct element nesting
// top level element can only be of 2 types
/// @todo optimization creep: save this check into a bool variable, instead of using count() every time:
/// there is only a single top level element in xml anyway
if (count($GLOBALS['_xh']['stack']) == 0)
if ($name != 'METHODRESPONSE' && $name != 'METHODCALL' && (
$name != 'VALUE' && !$accept_single_vals))
$GLOBALS['_xh']['isf'] = 2;
$GLOBALS['_xh']['isf_reason'] = 'missing top level xmlrpc element';
return;
else
$GLOBALS['_xh']['rt'] = strtolower($name);
else
// not top level element: see if parent is OK
$parent = end($GLOBALS['_xh']['stack']);
if (!array_key_exists($name, $GLOBALS['xmlrpc_valid_parents']) || !in_array($parent, $GLOBALS['xmlrpc_valid_parents'][$name]))
$GLOBALS['_xh']['isf_reason'] = "xmlrpc element $name cannot be child of $parent";
return;
switch($name)
// optimize for speed switch cases: most common cases first
case 'VALUE':
/// @todo we could check for 2 VALUE elements inside a MEMBER or PARAM element
$GLOBALS['_xh']['vt']='value'; // indicator: no value found yet
$GLOBALS['_xh']['ac']='';
$GLOBALS['_xh']['lv']=1;
$GLOBALS['_xh']['php_class']=null;
break;
case 'I4':
case 'INT':
case 'STRING':
case 'BOOLEAN':
case 'DOUBLE':
case 'DATETIME.ISO8601':
case 'BASE64':
if ($GLOBALS['_xh']['vt']!='value')
//two data elements inside a value: an error occurred!
$GLOBALS['_xh']['isf_reason'] = "$name element following a {$GLOBALS['_xh']['vt']} element inside a single value";
return;
$GLOBALS['_xh']['ac']=''; // reset the accumulator
break;
case 'STRUCT':
case 'ARRAY':
return;
// create an empty array to hold child values, and push it onto appropriate stack
$cur_val = array();
$cur_val['values'] = array();
$cur_val['type'] = $name;
// check for out-of-band information to rebuild php objs
// and in case it is found, save it
if (@isset($attrs['PHP_CLASS']))
$cur_val['php_class'] = $attrs['PHP_CLASS'];
$GLOBALS['_xh']['valuestack'][] = $cur_val;
$GLOBALS['_xh']['vt']='data'; // be prepared for a data element next
break;
case 'DATA':
if ($GLOBALS['_xh']['vt']!='data')
$GLOBALS['_xh']['isf_reason'] = "found two data elements inside an array element";
return;
case 'METHODCALL':
case 'METHODRESPONSE':
case 'PARAMS':
// valid elements that add little to processing
break;
case 'METHODNAME':
case 'NAME':
/// @todo we could check for 2 NAME elements inside a MEMBER element
break;
case 'FAULT':
$GLOBALS['_xh']['isf']=1;
break;
case 'MEMBER':
$GLOBALS['_xh']['valuestack'][count($GLOBALS['_xh']['valuestack'])-1]['name']=''; // set member name to null, in case we do not find in the xml later on
//$GLOBALS['_xh']['ac']='';
// Drop trough intentionally
case 'PARAM':
// clear value type, so we can check later if no value has been passed for this param/member
$GLOBALS['_xh']['vt']=null;
break;
case 'NIL':
case 'EX:NIL':
if ($GLOBALS['xmlrpc_null_extension'])
return;
break;
// we do not support the <NIL/> extension, so
// drop through intentionally
default:
/// INVALID ELEMENT: RAISE ISF so that it is later recognized!!!
$GLOBALS['_xh']['isf_reason'] = "found not-xmlrpc xml element $name";
break;
// Save current element name to stack, to validate nesting
$GLOBALS['_xh']['stack'][] = $name;
/// @todo optimization creep: move this inside the big switch() above
if($name!='VALUE')
$GLOBALS['_xh']['lv']=0;
/// Used in decoding xml chunks that might represent single xmlrpc values
function xmlrpc_se_any($parser, $name, $attrs)
xmlrpc_se($parser, $name, $attrs, true);
/// xml parser handler function for close element tags
function xmlrpc_ee($parser, $name, $rebuild_xmlrpcvals = true)
// push this element name from stack
// NB: if XML validates, correct opening/closing is guaranteed and
// we do not have to check for $name == $curr_elem.
// we also checked for proper nesting at start of elements...
$curr_elem = array_pop($GLOBALS['_xh']['stack']);
switch($name)
case 'VALUE':
// This if() detects if no scalar was inside <VALUE></VALUE>
if ($GLOBALS['_xh']['vt']=='value')
$GLOBALS['_xh']['value']=$GLOBALS['_xh']['ac'];
$GLOBALS['_xh']['vt']=$GLOBALS['xmlrpcString'];
if ($rebuild_xmlrpcvals)
// build the xmlrpc val out of the data received, and substitute it
$temp = new xmlrpcval($GLOBALS['_xh']['value'], $GLOBALS['_xh']['vt']);
// in case we got info about underlying php class, save it
// in the object we're rebuilding
if (isset($GLOBALS['_xh']['php_class']))
$temp->_php_class = $GLOBALS['_xh']['php_class'];
// check if we are inside an array or struct:
// if value just built is inside an array, let's move it into array on the stack
$vscount = count($GLOBALS['_xh']['valuestack']);
if ($vscount && $GLOBALS['_xh']['valuestack'][$vscount-1]['type']=='ARRAY')
$GLOBALS['_xh']['valuestack'][$vscount-1]['values'][] = $temp;
else
$GLOBALS['_xh']['value'] = $temp;
else
/// @todo this needs to treat correctly php-serialized objects,
/// since std deserializing is done by php_xmlrpc_decode,
/// which we will not be calling...
$GLOBALS['_xh']['valuestack'][$vscount-1]['values'][] = $GLOBALS['_xh']['value'];
break;
case 'BOOLEAN':
case 'I4':
case 'INT':
case 'STRING':
case 'DOUBLE':
case 'BASE64':
$GLOBALS['_xh']['vt']=strtolower($name);
/// @todo: optimization creep - remove the if/elseif cycle below
/// since the case() in which we are already did that
if ($name=='STRING')
elseif ($name=='DATETIME.ISO8601')
if (!preg_match('/^[0-9]{8}T[0-9]{2}:[0-9]{2}:[0-9]{2}$/', $GLOBALS['_xh']['ac']))
error_log('XML-RPC: invalid value received in DATETIME: '.$GLOBALS['_xh']['ac']);
$GLOBALS['_xh']['vt']=$GLOBALS['xmlrpcDateTime'];
elseif ($name=='BASE64')
/// @todo check for failure of base64 decoding / catch warnings
$GLOBALS['_xh']['value']=base64_decode($GLOBALS['_xh']['ac']);
elseif ($name=='BOOLEAN')
// special case here: we translate boolean 1 or 0 into PHP
// constants true or false.
// Strings 'true' and 'false' are accepted, even though the
// spec never mentions them (see eg. Blogger api docs)
// NB: this simple checks helps a lot sanitizing input, ie no
// security problems around here
if ($GLOBALS['_xh']['ac']=='1' || strcasecmp($GLOBALS['_xh']['ac'], 'true') == 0)
$GLOBALS['_xh']['value']=true;
else
// log if receiveing something strange, even though we set the value to false anyway
if ($GLOBALS['_xh']['ac']!='0' && strcasecmp($GLOBALS['_xh']['ac'], 'false') != 0)
error_log('XML-RPC: invalid value received in BOOLEAN: '.$GLOBALS['_xh']['ac']);
$GLOBALS['_xh']['value']=false;
elseif ($name=='DOUBLE')
// we have a DOUBLE
// we must check that only 0123456789-.<space> are characters here
// NOTE: regexp could be much stricter than this...
if (!preg_match('/^[+-eE0123456789 .]+$/', $GLOBALS['_xh']['ac']))
/// @todo: find a better way of throwing an error than this!
error_log('XML-RPC: non numeric value received in DOUBLE: '.$GLOBALS['_xh']['ac']);
$GLOBALS['_xh']['value']='ERROR_NON_NUMERIC_FOUND';
else
// it's ok, add it on
$GLOBALS['_xh']['value']=(double)$GLOBALS['_xh']['ac'];
else
// we have an I4/INT
// we must check that only 0123456789-<space> are characters here
if (!preg_match('/^[+-]?[0123456789 ]+$/', $GLOBALS['_xh']['ac']))
/// @todo find a better way of throwing an error than this!
error_log('XML-RPC: non numeric value received in INT: '.$GLOBALS['_xh']['ac']);
else
$GLOBALS['_xh']['value']=(int)$GLOBALS['_xh']['ac'];
//$GLOBALS['_xh']['ac']=''; // is this necessary?
$GLOBALS['_xh']['lv']=3; // indicate we've found a value
break;
case 'NAME':
$GLOBALS['_xh']['valuestack'][count($GLOBALS['_xh']['valuestack'])-1]['name'] = $GLOBALS['_xh']['ac'];
break;
case 'MEMBER':
// add to array in the stack the last element built,
// unless no VALUE was found
if ($GLOBALS['_xh']['vt'])
$GLOBALS['_xh']['valuestack'][$vscount-1]['values'][$GLOBALS['_xh']['valuestack'][$vscount-1]['name']] = $GLOBALS['_xh']['value'];
} else
error_log('XML-RPC: missing VALUE inside STRUCT in received xml');
break;
case 'DATA':
$GLOBALS['_xh']['vt']=null; // reset this to check for 2 data elements in a row - even if they're empty
break;
case 'STRUCT':
case 'ARRAY':
// fetch out of stack array of values, and promote it to current value
$curr_val = array_pop($GLOBALS['_xh']['valuestack']);
$GLOBALS['_xh']['value'] = $curr_val['values'];
if (isset($curr_val['php_class']))
$GLOBALS['_xh']['php_class'] = $curr_val['php_class'];
break;
case 'PARAM':
// add to array of params the current value,
$GLOBALS['_xh']['params'][]=$GLOBALS['_xh']['value'];
$GLOBALS['_xh']['pt'][]=$GLOBALS['_xh']['vt'];
else
error_log('XML-RPC: missing VALUE inside PARAM in received xml');
break;
case 'METHODNAME':
$GLOBALS['_xh']['method']=preg_replace('/^[
\r ]+/', '', $GLOBALS['_xh']['ac']);
break;
case 'NIL':
case 'EX:NIL':
$GLOBALS['_xh']['vt']='null';
$GLOBALS['_xh']['value']=null;
break;
// drop through intentionally if nil extension not enabled
case 'PARAMS':
case 'FAULT':
case 'METHODCALL':
case 'METHORESPONSE':
break;
default:
// End of INVALID ELEMENT!
// shall we add an assert here for unreachable code???
break;
/// Used in decoding xmlrpc requests/responses without rebuilding xmlrpc values
function xmlrpc_ee_fast($parser, $name)
xmlrpc_ee($parser, $name, false);
/// xml parser handler function for character data
function xmlrpc_cd($parser, $data)
// skip processing if xml fault already detected
// "lookforvalue==3" means that we've found an entire value
// and should discard any further character data
if($GLOBALS['_xh']['lv']!=3)
// G. Giunta 2006-08-23: useless change of 'lv' from 1 to 2
//if($GLOBALS['_xh']['lv']==1)
// if we've found text and we're just in a <value> then
// say we've found a value
//$GLOBALS['_xh']['lv']=2;
// we always initialize the accumulator before starting parsing, anyway...
//if(!@isset($GLOBALS['_xh']['ac']))
// $GLOBALS['_xh']['ac'] = '';
$GLOBALS['_xh']['ac'].=$data;
/// xml parser handler function for 'other stuff', ie. not char data or
/// element start/end tag. In fact it only gets called on unknown entities...
function xmlrpc_dh($parser, $data)
if(substr($data, 0, 1) == '&' && substr($data, -1, 1) == ';')
// G. Giunta 2006-08-25: useless change of 'lv' from 1 to 2
// $GLOBALS['_xh']['lv']=2;
return true;
class xmlrpc_client
var $path;
var $server;
var $port=0;
var $method='http';
var $errno;
var $errstr;
var $debug=0;
var $username='';
var $password='';
var $authtype=1;
var $cert='';
var $certpass='';
var $cacert='';
var $cacertdir='';
var $key='';
var $keypass='';
var $verifypeer=true;
var $verifyhost=1;
var $no_multicall=false;
var $proxy='';
var $proxyport=0;
var $proxy_user='';
var $proxy_pass='';
var $proxy_authtype=1;
var $cookies=array();
var $extracurlopts=array();
* List of http compression methods accepted by the client for responses.
* NB: PHP supports deflate, gzip compressions out of the box if compiled w. zlib
* NNB: you can set it to any non-empty array for HTTP11 and HTTPS, since
* in those cases it will be up to CURL to decide the compression methods
* it supports. You might check for the presence of 'zlib' in the output of
* curl_version() to determine wheter compression is supported or not
var $accepted_compression = array();
* Name of compression scheme to be used for sending requests.
* Either null, gzip or deflate
var $request_compression = '';
* CURL handle: used for keep-alive connections (PHP 4.3.8 up, see:
* http://curl.haxx.se/docs/faq.html#7.3)
var $xmlrpc_curl_handle = null;
/// Wheter to use persistent connections for http 1.1 and https
var $keepalive = false;
/// Charset encodings that can be decoded without problems by the client
var $accepted_charset_encodings = array();
/// Charset encoding to be used in serializing request. NULL = use ASCII
var $request_charset_encoding = '';
* Decides the content of xmlrpcresp objects returned by calls to send()
* valid strings are 'xmlrpcvals', 'phpvals' or 'xml'
var $return_type = 'xmlrpcvals';
* Sent to servers in http headers
var $user_agent;
* @param string $path either the complete server URL or the PATH part of the xmlrc server URL, e.g. /xmlrpc/server.php
* @param string $server the server name / ip address
* @param integer $port the port the server is listening on, defaults to 80 or 443 depending on protocol used
* @param string $method the http protocol variant: defaults to 'http', 'https' and 'http11' can be used if CURL is installed
function xmlrpc_client($path, $server='', $port='', $method='')
// allow user to specify all params in $path
if($server == '' and $port == '' and $method == '')
$parts = parse_url($path);
$server = $parts['host'];
$path = isset($parts['path']) ? $parts['path'] : '';
if(isset($parts['query']))
$path .= '?'.$parts['query'];
if(isset($parts['fragment']))
$path .= '#'.$parts['fragment'];
if(isset($parts['port']))
$port = $parts['port'];
if(isset($parts['scheme']))
$method = $parts['scheme'];
if(isset($parts['user']))
$this->username = $parts['user'];
if(isset($parts['pass']))
$this->password = $parts['pass'];
if($path == '' || $path[0] != '/')
$this->path='/'.$path;
else
$this->path=$path;
$this->server=$server;
if($port != '')
$this->port=$port;
if($method != '')
$this->method=$method;
// if ZLIB is enabled, let the client by default accept compressed responses
if(function_exists('gzinflate') || (
function_exists('curl_init') && (($info = curl_version()) &&
((is_string($info) && strpos($info, 'zlib') !== null) || isset($info['libz_version'])))
$this->accepted_compression = array('gzip', 'deflate');
// keepalives: enabled by default
$this->keepalive = true;
// by default the xml parser can support these 3 charset encodings
$this->accepted_charset_encodings = array('UTF-8', 'ISO-8859-1', 'US-ASCII');
// initialize user_agent string
$this->user_agent = $GLOBALS['xmlrpcName'] . ' ' . $GLOBALS['xmlrpcVersion'];
* Enables/disables the echoing to screen of the xmlrpc responses received
* @param integer $debug values 0, 1 and 2 are supported (2 = echo sent msg too, before received response)
* @access public
function setDebug($in)
$this->debug=$in;
* Add some http BASIC AUTH credentials, used by the client to authenticate
* @param string $u username
* @param string $p password
* @param integer $t auth type. See curl_setopt man page for supported auth types. Defaults to CURLAUTH_BASIC (basic auth)
* @access public
function setCredentials($u, $p, $t=1)
$this->username=$u;
$this->password=$p;
$this->authtype=$t;
* Add a client-side https certificate
* @param string $cert
* @param string $certpass
* @access public
function setCertificate($cert, $certpass)
$this->cert = $cert;
$this->certpass = $certpass;
* Add a CA certificate to verify server with (see man page about
* CURLOPT_CAINFO for more details
* @param string $cacert certificate file name (or dir holding certificates)
* @param bool $is_dir set to true to indicate cacert is a dir. defaults to false
* @access public
function setCaCertificate($cacert, $is_dir=false)
if ($is_dir)
$this->cacertdir = $cacert;
else
$this->cacert = $cacert;
* Set attributes for SSL communication: private SSL key
* NB: does not work in older php/curl installs
* Thanks to Daniel Convissor
* @param string $key The name of a file containing a private SSL key
* @param string $keypass The secret password needed to use the private SSL key
* @access public
function setKey($key, $keypass)
$this->key = $key;
$this->keypass = $keypass;
* Set attributes for SSL communication: verify server certificate
* @param bool $i enable/disable verification of peer certificate
* @access public
function setSSLVerifyPeer($i)
$this->verifypeer = $i;
* Set attributes for SSL communication: verify match of server cert w. hostname
* @param int $i
* @access public
function setSSLVerifyHost($i)
$this->verifyhost = $i;
* Set proxy info
* @param string $proxyhost
* @param string $proxyport Defaults to 8080 for HTTP and 443 for HTTPS
* @param string $proxyusername Leave blank if proxy has public access
* @param string $proxypassword Leave blank if proxy has public access
* @param int $proxyauthtype set to constant CURLAUTH_NTLM to use NTLM auth with proxy
* @access public
function setProxy($proxyhost, $proxyport, $proxyusername = '', $proxypassword = '', $proxyauthtype = 1)
$this->proxy = $proxyhost;
$this->proxyport = $proxyport;
$this->proxy_user = $proxyusername;
$this->proxy_pass = $proxypassword;
$this->proxy_authtype = $proxyauthtype;
* Enables/disables reception of compressed xmlrpc responses.
* Note that enabling reception of compressed responses merely adds some standard
* http headers to xmlrpc requests. It is up to the xmlrpc server to return
* compressed responses when receiving such requests.
* @param string $compmethod either 'gzip', 'deflate', 'any' or ''
* @access public
function setAcceptedCompression($compmethod)
if ($compmethod == 'any')
else
$this->accepted_compression = array($compmethod);
* Enables/disables http compression of xmlrpc request.
* Take care when sending compressed requests: servers might not support them
* (and automatic fallback to uncompressed requests is not yet implemented)
* @param string $compmethod either 'gzip', 'deflate' or ''
* @access public
function setRequestCompression($compmethod)
$this->request_compression = $compmethod;
* Adds a cookie to list of cookies that will be sent to server.
* NB: setting any param but name and value will turn the cookie into a 'version 1' cookie:
* do not do it unless you know what you are doing
* @param string $name
* @param string $value
* @param string $domain
* @param int $port
* @access public
* @todo check correctness of urlencoding cookie value (copied from php way of doing it...)
function setCookie($name, $value='', $path='', $domain='', $port=null)
$this->cookies[$name]['value'] = urlencode($value);
if ($path || $domain || $port)
$this->cookies[$name]['path'] = $path;
$this->cookies[$name]['domain'] = $domain;
$this->cookies[$name]['port'] = $port;
$this->cookies[$name]['version'] = 1;
else
$this->cookies[$name]['version'] = 0;
* Directly set cURL options, for extra flexibility
* It allows eg. to bind client to a specific IP interface / address
* @param $options array
function SetCurlOptions( $options )
$this->extracurlopts = $options;
* Set user-agent string that will be used by this client instance
* in http headers sent to the server
function SetUserAgent( $agentstring )
$this->user_agent = $agentstring;
* Send an xmlrpc request
* @param mixed $msg The message object, or an array of messages for using multicall, or the complete xml representation of a request
* @param integer $timeout Connection timeout, in seconds, If unspecified, a platform specific timeout will apply
* @param string $method if left unspecified, the http protocol chosen during creation of the object will be used
* @return xmlrpcresp
* @access public
function& send($msg, $timeout=0, $method='')
// if user deos not specify http protocol, use native method of this client
// (i.e. method set during call to constructor)
if($method == '')
$method = $this->method;
if(is_array($msg))
// $msg is an array of xmlrpcmsg's
$r = $this->multicall($msg, $timeout, $method);
return $r;
elseif(is_string($msg))
$n = new xmlrpcmsg('');
$n->payload = $msg;
$msg = $n;
// where msg is an xmlrpcmsg
$msg->debug=$this->debug;
if($method == 'https')
$r =& $this->sendPayloadHTTPS(
$msg,
$this->server,
$this->port,
$timeout,
$this->username,
$this->password,
$this->authtype,
$this->cert,
$this->certpass,
$this->cacert,
$this->cacertdir,
$this->proxy,
$this->proxyport,
$this->proxy_user,
$this->proxy_pass,
$this->proxy_authtype,
$this->keepalive,
$this->key,
$this->keypass
elseif($method == 'http11')
$r =& $this->sendPayloadCURL(
$msg,
$this->server,
$this->port,
$timeout,
$this->username,
$this->password,
$this->authtype,
null,
null,
null,
null,
$this->proxy,
$this->proxyport,
$this->proxy_user,
$this->proxy_pass,
'http',
$this->keepalive
else
$r =& $this->sendPayloadHTTP10(
$msg,
$this->server,
$this->port,
$timeout,
$this->username,
$this->password,
$this->authtype,
$this->proxy,
$this->proxyport,
$this->proxy_user,
$this->proxy_pass,
return $r;
* @access private
function &sendPayloadHTTP10($msg, $server, $port, $timeout=0,
$username='', $password='', $authtype=1, $proxyhost='',
$proxyport=0, $proxyusername='', $proxypassword='', $proxyauthtype=1)
if($port==0)
$port=80;
// Only create the payload if it was not created previously
if(empty($msg->payload))
$msg->createPayload($this->request_charset_encoding);
$payload = $msg->payload;
// Deflate request body and set appropriate request headers
if(function_exists('gzdeflate') && ($this->request_compression == 'gzip' || $this->request_compression == 'deflate'))
if($this->request_compression == 'gzip')
$a = @gzencode($payload);
if($a)
$payload = $a;
$encoding_hdr = "Content-Encoding: gzip
else
$a = @gzcompress($payload);
if($a)
$payload = $a;
$encoding_hdr = "Content-Encoding: deflate
else
$encoding_hdr = '';
// thanks to Grant Rauscher <grant7@firstworld.net> for this
$credentials='';
if($username!='')
$credentials='Authorization: Basic ' . base64_encode($username . ':' . $password) . "
if ($authtype != 1)
error_log('XML-RPC: '.__METHOD__.': warning. Only Basic auth is supported with HTTP 1.0');
$accepted_encoding = '';
if(is_array($this->accepted_compression) && count($this->accepted_compression))
$accepted_encoding = 'Accept-Encoding: ' . implode(', ', $this->accepted_compression) . "
$proxy_credentials = '';
if($proxyhost)
if($proxyport == 0)
$proxyport = 8080;
$connectserver = $proxyhost;
$connectport = $proxyport;
$uri = 'http://'.$server.':'.$port.$this->path;
if($proxyusername != '')
if ($proxyauthtype != 1)
error_log('XML-RPC: '.__METHOD__.': warning. Only Basic auth to proxy is supported with HTTP 1.0');
$proxy_credentials = 'Proxy-Authorization: Basic ' . base64_encode($proxyusername.':'.$proxypassword) . "
else
$connectserver = $server;
$connectport = $port;
$uri = $this->path;
// Cookie generation, as per rfc2965 (version 1 cookies) or
// netscape's rules (version 0 cookies)
$cookieheader='';
if (count($this->cookies))
$version = '';
foreach ($this->cookies as $name => $cookie)
if ($cookie['version'])
$version = ' $Version="' . $cookie['version'] . '";';
$cookieheader .= ' ' . $name . '="' . $cookie['value'] . '";';
if ($cookie['path'])
$cookieheader .= ' $Path="' . $cookie['path'] . '";';
if ($cookie['domain'])
$cookieheader .= ' $Domain="' . $cookie['domain'] . '";';
if ($cookie['port'])
$cookieheader .= ' $Port="' . $cookie['port'] . '";';
else
$cookieheader .= ' ' . $name . '=' . $cookie['value'] . ";";
$cookieheader = 'Cookie:' . $version . substr($cookieheader, 0, -1) . "
$op= 'POST ' . $uri. " HTTP/1.0
'User-Agent: ' . $this->user_agent . "
'Host: '. $server . ':' . $port . "
$credentials .
$proxy_credentials .
$accepted_encoding .
$encoding_hdr .
'Accept-Charset: ' . implode(',', $this->accepted_charset_encodings) . "
$cookieheader .
'Content-Type: ' . $msg->content_type . "
Content-Length: " .
strlen($payload) . "
$payload;
if($this->debug > 1)
print "<PRE>
---SENDING---
" . htmlentities($op) . "
---END---
</PRE>";
// let the client see this now in case http times out...
flush();
if($timeout>0)
$fp=@fsockopen($connectserver, $connectport, $this->errno, $this->errstr, $timeout);
else
$fp=@fsockopen($connectserver, $connectport, $this->errno, $this->errstr);
if($fp)
if($timeout>0 && function_exists('stream_set_timeout'))
stream_set_timeout($fp, $timeout);
else
$this->errstr='Connect error: '.$this->errstr;
$r=new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['http_error'], $this->errstr . ' (' . $this->errno . ')');
return $r;
if(!fputs($fp, $op, strlen($op)))
fclose($fp);
$this->errstr='Write error';
$r=new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['http_error'], $this->errstr);
return $r;
else
// reset errno and errstr on succesful socket connection
$this->errstr = '';
// G. Giunta 2005/10/24: close socket before parsing.
// should yeld slightly better execution times, and make easier recursive calls (e.g. to follow http redirects)
$ipd='';
do
// shall we check for $data === FALSE?
// as per the manual, it signals an error
$ipd.=fread($fp, 32768);
} while(!feof($fp));
fclose($fp);
$r =& $msg->parseResponse($ipd, false, $this->return_type);
return $r;
* @access private
function &sendPayloadHTTPS($msg, $server, $port, $timeout=0, $username='',
$password='', $authtype=1, $cert='',$certpass='', $cacert='', $cacertdir='',
$proxyhost='', $proxyport=0, $proxyusername='', $proxypassword='', $proxyauthtype=1,
$keepalive=false, $key='', $keypass='')
$r =& $this->sendPayloadCURL($msg, $server, $port, $timeout, $username,
$password, $authtype, $cert, $certpass, $cacert, $cacertdir, $proxyhost, $proxyport,
$proxyusername, $proxypassword, $proxyauthtype, 'https', $keepalive, $key, $keypass);
return $r;
* Contributed by Justin Miller <justin@voxel.net>
* Requires curl to be built into PHP
* NB: CURL versions before 7.11.10 cannot use proxy to talk to https servers!
* @access private
function &sendPayloadCURL($msg, $server, $port, $timeout=0, $username='',
$password='', $authtype=1, $cert='', $certpass='', $cacert='', $cacertdir='',
$proxyhost='', $proxyport=0, $proxyusername='', $proxypassword='', $proxyauthtype=1, $method='https',
if(!function_exists('curl_init'))
$this->errstr='CURL unavailable on this install';
$r=new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['no_curl'], $GLOBALS['xmlrpcstr']['no_curl']);
return $r;
if(($info = curl_version()) &&
((is_string($info) && strpos($info, 'OpenSSL') === null) || (is_array($info) && !isset($info['ssl_version']))))
$this->errstr='SSL unavailable on this install';
$r=new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['no_ssl'], $GLOBALS['xmlrpcstr']['no_ssl']);
return $r;
if($port == 0)
if($method == 'http')
$port = 80;
else
$port = 443;
if($a)
$payload = $a;
$encoding_hdr = 'Content-Encoding: gzip';
else
if($a)
$payload = $a;
$encoding_hdr = 'Content-Encoding: deflate';
else
$encoding_hdr = '';
print "<PRE>
---SENDING---
" . htmlentities($payload) . "
---END---
</PRE>";
flush();
if(!$keepalive || !$this->xmlrpc_curl_handle)
$curl = curl_init($method . '://' . $server . ':' . $port . $this->path);
if($keepalive)
$this->xmlrpc_curl_handle = $curl;
else
$curl = $this->xmlrpc_curl_handle;
// results into variable
curl_setopt($curl, CURLOPT_RETURNTRANSFER, 1);
if($this->debug)
curl_setopt($curl, CURLOPT_VERBOSE, 1);
curl_setopt($curl, CURLOPT_USERAGENT, $this->user_agent);
// required for XMLRPC: post the data
curl_setopt($curl, CURLOPT_POST, 1);
// the data
curl_setopt($curl, CURLOPT_POSTFIELDS, $payload);
// return the header too
curl_setopt($curl, CURLOPT_HEADER, 1);
// will only work with PHP >= 5.0
// NB: if we set an empty string, CURL will add http header indicating
// ALL methods it is supporting. This is possibly a better option than
// letting the user tell what curl can / cannot do...
//curl_setopt($curl, CURLOPT_ENCODING, implode(',', $this->accepted_compression));
// empty string means 'any supported by CURL' (shall we catch errors in case CURLOPT_SSLKEY undefined ?)
if (count($this->accepted_compression) == 1)
curl_setopt($curl, CURLOPT_ENCODING, $this->accepted_compression[0]);
else
curl_setopt($curl, CURLOPT_ENCODING, '');
// extra headers
$headers = array('Content-Type: ' . $msg->content_type , 'Accept-Charset: ' . implode(',', $this->accepted_charset_encodings));
// if no keepalive is wanted, let the server know it in advance
if(!$keepalive)
$headers[] = 'Connection: close';
// request compression header
if($encoding_hdr)
$headers[] = $encoding_hdr;
curl_setopt($curl, CURLOPT_HTTPHEADER, $headers);
// timeout is borked
if($timeout)
curl_setopt($curl, CURLOPT_TIMEOUT, $timeout == 1 ? 1 : $timeout - 1);
if($username && $password)
curl_setopt($curl, CURLOPT_USERPWD, $username.':'.$password);
if (defined('CURLOPT_HTTPAUTH'))
curl_setopt($curl, CURLOPT_HTTPAUTH, $authtype);
else if ($authtype != 1)
error_log('XML-RPC: '.__METHOD__.': warning. Only Basic auth is supported by the current PHP/curl install');
// set cert file
if($cert)
curl_setopt($curl, CURLOPT_SSLCERT, $cert);
// set cert password
if($certpass)
curl_setopt($curl, CURLOPT_SSLCERTPASSWD, $certpass);
// whether to verify remote host's cert
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, $this->verifypeer);
// set ca certificates file/dir
if($cacert)
curl_setopt($curl, CURLOPT_CAINFO, $cacert);
if($cacertdir)
curl_setopt($curl, CURLOPT_CAPATH, $cacertdir);
// set key file (shall we catch errors in case CURLOPT_SSLKEY undefined ?)
if($key)
curl_setopt($curl, CURLOPT_SSLKEY, $key);
// set key password (shall we catch errors in case CURLOPT_SSLKEY undefined ?)
if($keypass)
curl_setopt($curl, CURLOPT_SSLKEYPASSWD, $keypass);
// whether to verify cert's common name (CN); 0 for no, 1 to verify that it exists, and 2 to verify that it matches the hostname used
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, $this->verifyhost);
// proxy info
if($proxyhost)
if($proxyport == 0)
$proxyport = 8080; // NB: even for HTTPS, local connection is on port 8080
curl_setopt($curl, CURLOPT_PROXY, $proxyhost.':'.$proxyport);
//curl_setopt($curl, CURLOPT_PROXYPORT,$proxyport);
if($proxyusername)
curl_setopt($curl, CURLOPT_PROXYUSERPWD, $proxyusername.':'.$proxypassword);
if (defined('CURLOPT_PROXYAUTH'))
curl_setopt($curl, CURLOPT_PROXYAUTH, $proxyauthtype);
else if ($proxyauthtype != 1)
error_log('XML-RPC: '.__METHOD__.': warning. Only Basic auth to proxy is supported by the current PHP/curl install');
// NB: should we build cookie http headers by hand rather than let CURL do it?
// the following code does not honour 'expires', 'path' and 'domain' cookie attributes
// set to client obj the the user...
$cookieheader = '';
$cookieheader .= $name . '=' . $cookie['value'] . '; ';
curl_setopt($curl, CURLOPT_COOKIE, substr($cookieheader, 0, -2));
foreach ($this->extracurlopts as $opt => $val)
curl_setopt($curl, $opt, $val);
$result = curl_exec($curl);
if ($this->debug > 1)
print "<PRE>
---CURL INFO---
foreach(curl_getinfo($curl) as $name => $val)
print $name . ': ' . htmlentities($val). "
print "---END---
</PRE>";
if(!$result) /// @todo we should use a better check here - what if we get back '' or '0'?
$this->errstr='no response';
$resp=new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['curl_fail'], $GLOBALS['xmlrpcstr']['curl_fail']. ': '. curl_error($curl));
curl_close($curl);
if($keepalive)
$this->xmlrpc_curl_handle = null;
else
if(!$keepalive)
curl_close($curl);
$resp =& $msg->parseResponse($result, true, $this->return_type);
return $resp;
* Send an array of request messages and return an array of responses.
* Unless $this->no_multicall has been set to true, it will try first
* to use one single xmlrpc call to server method system.multicall, and
* revert to sending many successive calls in case of failure.
* This failure is also stored in $this->no_multicall for subsequent calls.
* Unfortunately, there is no server error code universally used to denote
* the fact that multicall is unsupported, so there is no way to reliably
* distinguish between that and a temporary failure.
* If you are sure that server supports multicall and do not want to
* fallback to using many single calls, set the fourth parameter to FALSE.
* NB: trying to shoehorn extra functionality into existing syntax has resulted
* in pretty much convoluted code...
* @param array $msgs an array of xmlrpcmsg objects
* @param integer $timeout connection timeout (in seconds)
* @param string $method the http protocol variant to be used
* @param boolean fallback When true, upon receiveing an error during multicall, multiple single calls will be attempted
* @return array
* @access public
function multicall($msgs, $timeout=0, $method='', $fallback=true)
if ($method == '')
if(!$this->no_multicall)
$results = $this->_try_multicall($msgs, $timeout, $method);
if(is_array($results))
// System.multicall succeeded
return $results;
else
// either system.multicall is unsupported by server,
// or call failed for some other reason.
if ($fallback)
// Don't try it next time...
$this->no_multicall = true;
else
if (is_a($results, 'xmlrpcresp'))
$result = $results;
else
$result = new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['multicall_error'], $GLOBALS['xmlrpcstr']['multicall_error']);
else
// override fallback, in case careless user tries to do two
// opposite things at the same time
$fallback = true;
$results = array();
if ($fallback)
// system.multicall is (probably) unsupported by server:
// emulate multicall via multiple requests
foreach($msgs as $msg)
$results[] =& $this->send($msg, $timeout, $method);
else
// user does NOT want to fallback on many single calls:
// since we should always return an array of responses,
// return an array with the same error repeated n times
$results[] = $result;
return $results;
* Attempt to boxcar $msgs via system.multicall.
* Returns either an array of xmlrpcreponses, an xmlrpc error response
* or false (when received response does not respect valid multicall syntax)
* @access private
function _try_multicall($msgs, $timeout, $method)
// Construct multicall message
$calls = array();
$call['methodName'] = new xmlrpcval($msg->method(),'string');
$numParams = $msg->getNumParams();
$params = array();
for($i = 0; $i < $numParams; $i++)
$params[$i] = $msg->getParam($i);
$call['params'] = new xmlrpcval($params, 'array');
$calls[] = new xmlrpcval($call, 'struct');
$multicall = new xmlrpcmsg('system.multicall');
$multicall->addParam(new xmlrpcval($calls, 'array'));
// Attempt RPC call
$result =& $this->send($multicall, $timeout, $method);
if($result->faultCode() != 0)
// call to system.multicall failed
return $result;
// Unpack responses.
$rets = $result->value();
if ($this->return_type == 'xml')
return $rets;
else if ($this->return_type == 'phpvals')
///@todo test this code branch...
if(!is_array($rets))
return false; // bad return type from system.multicall
$numRets = count($rets);
if($numRets != count($msgs))
return false; // wrong number of return values.
$response = array();
for($i = 0; $i < $numRets; $i++)
$val = $rets[$i];
if (!is_array($val)) {
return false;
switch(count($val))
case 1:
if(!isset($val[0]))
return false; // Bad value
// Normal return value
$response[$i] = new xmlrpcresp($val[0], 0, '', 'phpvals');
break;
case 2:
/// @todo remove usage of @: it is apparently quite slow
$code = @$val['faultCode'];
if(!is_int($code))
return false;
$str = @$val['faultString'];
if(!is_string($str))
return false;
$response[$i] = new xmlrpcresp(0, $code, $str);
break;
default:
return false;
return $response;
else // return type == 'xmlrpcvals'
if($rets->kindOf() != 'array')
$numRets = $rets->arraysize();
$val = $rets->arraymem($i);
switch($val->kindOf())
case 'array':
if($val->arraysize() != 1)
$response[$i] = new xmlrpcresp($val->arraymem(0));
break;
case 'struct':
$code = $val->structmem('faultCode');
if($code->kindOf() != 'scalar' || $code->scalartyp() != 'int')
return false;
$str = $val->structmem('faultString');
if($str->kindOf() != 'scalar' || $str->scalartyp() != 'string')
return false;
$response[$i] = new xmlrpcresp(0, $code->scalarval(), $str->scalarval());
break;
default:
return false;
return $response;
} // end class xmlrpc_client
class xmlrpcresp
var $val = 0;
var $valtyp;
var $errno = 0;
var $errstr = '';
var $payload;
var $hdrs = array();
var $_cookies = array();
var $content_type = 'text/xml';
var $raw_data = '';
* @param mixed $val either an xmlrpcval obj, a php value or the xml serialization of an xmlrpcval (a string)
* @param integer $fcode set it to anything but 0 to create an error response
* @param string $fstr the error string, in case of an error response
* @param string $valtyp either 'xmlrpcvals', 'phpvals' or 'xml'
* @todo add check that $val / $fcode / $fstr is of correct type???
* NB: as of now we do not do it, since it might be either an xmlrpcval or a plain
* php val, or a complete xml chunk, depending on usage of xmlrpc_client::send() inside which creator is called...
function xmlrpcresp($val, $fcode = 0, $fstr = '', $valtyp='')
if($fcode != 0)
// error response
$this->errno = $fcode;
$this->errstr = $fstr;
//$this->errstr = htmlspecialchars($fstr); // XXX: encoding probably shouldn't be done here; fix later.
else
// successful response
$this->val = $val;
if ($valtyp == '')
// user did not declare type of response value: try to guess it
if (is_object($this->val) && is_a($this->val, 'xmlrpcval'))
$this->valtyp = 'xmlrpcvals';
else if (is_string($this->val))
$this->valtyp = 'xml';
else
$this->valtyp = 'phpvals';
else
// user declares type of resp value: believe him
$this->valtyp = $valtyp;
* Returns the error code of the response.
* @return integer the error code of this response (0 for not-error responses)
* @access public
function faultCode()
return $this->errno;
* @return string the error string of this response ('' for not-error responses)
* @access public
function faultString()
return $this->errstr;
* Returns the value received by the server.
* @return mixed the xmlrpcval object returned by the server. Might be an xml string or php value if the response has been created by specially configured xmlrpc_client objects
* @access public
function value()
return $this->val;
* Returns an array with the cookies received from the server.
* Array has the form: $cookiename => array ('value' => $val, $attr1 => $val1, $attr2 = $val2, ...)
* with attributes being e.g. 'expires', 'path', domain'.
* NB: cookies sent as 'expired' by the server (i.e. with an expiry date in the past)
* are still present in the array. It is up to the user-defined code to decide
* how to use the received cookies, and wheter they have to be sent back with the next
* request to the server (using xmlrpc_client::setCookie) or not
* @return array array of cookies received from the server
* @access public
function cookies()
return $this->_cookies;
* Returns xml representation of the response. XML prologue not included
* @param string $charset_encoding the charset to be used for serialization. if null, US-ASCII is assumed
* @return string the xml representation of the response
* @access public
function serialize($charset_encoding='')
if ($charset_encoding != '')
$this->content_type = 'text/xml; charset=' . $charset_encoding;
else
$this->content_type = 'text/xml';
$result = "<methodResponse>
if($this->errno)
// G. Giunta 2005/2/13: let non-ASCII response messages be tolerated by clients
// by xml-encoding non ascii chars
$result .= "<fault>
"<value>
<struct><member><name>faultCode</name>
<value><int>" . $this->errno .
"</int></value>
</member>
<member>
<name>faultString</name>
<value><string>" .
xmlrpc_encode_entitites($this->errstr, $GLOBALS['xmlrpc_internalencoding'], $charset_encoding) . "</string></value>
</member>
"</struct>
</value>
</fault>";
else
if(!is_object($this->val) || !is_a($this->val, 'xmlrpcval'))
if (is_string($this->val) && $this->valtyp == 'xml')
$result .= "<params>
<param>
$this->val .
"</param>
</params>";
else
/// @todo try to build something serializable?
die('cannot serialize xmlrpcresp objects whose content is native php values');
else
<param>
$this->val->serialize($charset_encoding) .
"</param>
</params>";
$result .= "
</methodResponse>";
$this->payload = $result;
return $result;
class xmlrpcmsg
var $payload;
var $methodname;
var $params=array();
var $debug=0;
* @param string $meth the name of the method to invoke
* @param array $pars array of parameters to be paased to the method (xmlrpcval objects)
function xmlrpcmsg($meth, $pars=0)
$this->methodname=$meth;
if(is_array($pars) && count($pars)>0)
for($i=0; $i<count($pars); $i++)
$this->addParam($pars[$i]);
* @access private
function xml_header($charset_encoding='')
return "<?xml version=\"1.0\" encoding=\"$charset_encoding\" ?" . ">
<methodCall>
else
return "<?xml version=\"1.0\"?" . ">
<methodCall>
* @access private
function xml_footer()
return '</methodCall>';
* @access private
function kindOf()
return 'msg';
* @access private
function createPayload($charset_encoding='')
else
$this->payload=$this->xml_header($charset_encoding);
$this->payload.='<methodName>' . $this->methodname . "</methodName>
$this->payload.="<params>
for($i=0; $i<count($this->params); $i++)
$p=$this->params[$i];
$this->payload.="<param>
" . $p->serialize($charset_encoding) .
"</param>
$this->payload.="</params>
$this->payload.=$this->xml_footer();
* Gets/sets the xmlrpc method to be invoked
* @param string $meth the method to be set (leave empty not to set it)
* @return string the method that will be invoked
* @access public
function method($meth='')
if($meth!='')
return $this->methodname;
* Returns xml representation of the message. XML prologue included
* @return string the xml representation of the message, xml prologue included
* @access public
$this->createPayload($charset_encoding);
return $this->payload;
* Add a parameter to the list of parameters to be used upon method invocation
* @param xmlrpcval $par
* @return boolean false on failure
* @access public
function addParam($par)
// add check: do not add to self params which are not xmlrpcvals
if(is_object($par) && is_a($par, 'xmlrpcval'))
$this->params[]=$par;
return true;
else
return false;
* Returns the nth parameter in the message. The index zero-based.
* @param integer $i the index of the parameter to fetch (zero based)
* @return xmlrpcval the i-th parameter
* @access public
function getParam($i) { return $this->params[$i]; }
* Returns the number of parameters in the messge.
* @return integer the number of parameters currently set
* @access public
function getNumParams() { return count($this->params); }
* Given an open file handle, read all data available and parse it as axmlrpc response.
* NB: the file handle is not closed by this function.
* NNB: might have trouble in rare cases to work on network streams, as we
* check for a read of 0 bytes instead of feof($fp).
* But since checking for feof(null) returns false, we would risk an
* infinite loop in that case, because we cannot trust the caller
* to give us a valid pointer to an open file...
* @access public
* @todo add 2nd & 3rd param to be passed to ParseResponse() ???
function &parseResponseFile($fp)
$ipd='';
while($data=fread($fp, 32768))
$ipd.=$data;
//fclose($fp);
$r =& $this->parseResponse($ipd);
return $r;
* Parses HTTP headers and separates them from data.
* @access private
function &parseResponseHeaders(&$data, $headers_processed=false)
// Support "web-proxy-tunelling" connections for https through proxies
if(preg_match('/^HTTP\/1\.[0-1] 200 Connection established/', $data))
// Look for CR/LF or simple LF as line separator,
// (even though it is not valid http)
$pos = strpos($data,"
if($pos || is_int($pos))
$bd = $pos+4;
else
$bd = $pos+2;
else
// No separation between response headers and body: fault?
$bd = 0;
if ($bd)
// this filters out all http headers from proxy.
// maybe we could take them into account, too?
$data = substr($data, $bd);
else
error_log('XML-RPC: '.__METHOD__.': HTTPS via proxy error, tunnel connection possibly failed');
$r=new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['http_error'], $GLOBALS['xmlrpcstr']['http_error']. ' (HTTPS via proxy error, tunnel connection possibly failed)');
return $r;
// Strip HTTP 1.1 100 Continue header if present
while(preg_match('/^HTTP\/1\.1 1[0-9]{2} /', $data))
$pos = strpos($data, 'HTTP', 12);
// server sent a Continue header without any (valid) content following...
// give the client a chance to know it
if(!$pos && !is_int($pos)) // works fine in php 3, 4 and 5
break;
$data = substr($data, $pos);
if(!preg_match('/^HTTP\/[0-9.]+ 200 /', $data))
$errstr= substr($data, 0, strpos($data, "
")-1);
error_log('XML-RPC: '.__METHOD__.': HTTP error, got response: ' .$errstr);
$r=new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['http_error'], $GLOBALS['xmlrpcstr']['http_error']. ' (' . $errstr . ')');
return $r;
$GLOBALS['_xh']['headers'] = array();
$GLOBALS['_xh']['cookies'] = array();
// be tolerant to usage of
instead of
to separate headers and data
$bd = $pos+4;
else
$bd = $pos+2;
else
// we could take some action here instead of going on...
$bd = 0;
// be tolerant to line endings, and extra empty lines
$ar = preg_split("/\r?
/", trim(substr($data, 0, $pos)));
while(list(,$line) = @each($ar))
// take care of multi-line headers and cookies
$arr = explode(':',$line,2);
if(count($arr) > 1)
$header_name = strtolower(trim($arr[0]));
/// @todo some other headers (the ones that allow a CSV list of values)
/// do allow many values to be passed using multiple header lines.
/// We should add content to $GLOBALS['_xh']['headers'][$header_name]
/// instead of replacing it for those...
if ($header_name == 'set-cookie' || $header_name == 'set-cookie2')
if ($header_name == 'set-cookie2')
// version 2 cookies:
// there could be many cookies on one line, comma separated
$cookies = explode(',', $arr[1]);
else
$cookies = array($arr[1]);
foreach ($cookies as $cookie)
// glue together all received cookies, using a comma to separate them
// (same as php does with getallheaders())
if (isset($GLOBALS['_xh']['headers'][$header_name]))
$GLOBALS['_xh']['headers'][$header_name] .= ', ' . trim($cookie);
else
$GLOBALS['_xh']['headers'][$header_name] = trim($cookie);
// parse cookie attributes, in case user wants to correctly honour them
// feature creep: only allow rfc-compliant cookie attributes?
// @todo support for server sending multiple time cookie with same name, but using different PATHs
$cookie = explode(';', $cookie);
foreach ($cookie as $pos => $val)
$val = explode('=', $val, 2);
$tag = trim($val[0]);
$val = trim(@$val[1]);
/// @todo with version 1 cookies, we should strip leading and trailing " chars
if ($pos == 0)
$cookiename = $tag;
$GLOBALS['_xh']['cookies'][$tag] = array();
$GLOBALS['_xh']['cookies'][$cookiename]['value'] = urldecode($val);
else
if ($tag != 'value')
$GLOBALS['_xh']['cookies'][$cookiename][$tag] = $val;
else
$GLOBALS['_xh']['headers'][$header_name] = trim($arr[1]);
elseif(isset($header_name))
/// @todo version1 cookies might span multiple lines, thus breaking the parsing above
$GLOBALS['_xh']['headers'][$header_name] .= ' ' . trim($line);
if($this->debug && count($GLOBALS['_xh']['headers']))
print '<PRE>';
foreach($GLOBALS['_xh']['headers'] as $header => $value)
print htmlentities("HEADER: $header: $value
foreach($GLOBALS['_xh']['cookies'] as $header => $value)
print htmlentities("COOKIE: $header={$value['value']}
print "</PRE>
// if CURL was used for the call, http headers have been processed,
// and dechunking + reinflating have been carried out
if(!$headers_processed)
// Decode chunked encoding sent by http 1.1 servers
if(isset($GLOBALS['_xh']['headers']['transfer-encoding']) && $GLOBALS['_xh']['headers']['transfer-encoding'] == 'chunked')
if(!$data = decode_chunked($data))
error_log('XML-RPC: '.__METHOD__.': errors occurred when trying to rebuild the chunked data received from server');
$r = new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['dechunk_fail'], $GLOBALS['xmlrpcstr']['dechunk_fail']);
return $r;
// Decode gzip-compressed stuff
// code shamelessly inspired from nusoap library by Dietrich Ayala
if(isset($GLOBALS['_xh']['headers']['content-encoding']))
$GLOBALS['_xh']['headers']['content-encoding'] = str_replace('x-', '', $GLOBALS['_xh']['headers']['content-encoding']);
if($GLOBALS['_xh']['headers']['content-encoding'] == 'deflate' || $GLOBALS['_xh']['headers']['content-encoding'] == 'gzip')
// if decoding works, use it. else assume data wasn't gzencoded
if(function_exists('gzinflate'))
if($GLOBALS['_xh']['headers']['content-encoding'] == 'deflate' && $degzdata = @gzuncompress($data))
$data = $degzdata;
if($this->debug)
print "<PRE>---INFLATED RESPONSE---[".strlen($data)." chars]---
" . htmlentities($data) . "
---END---</PRE>";
elseif($GLOBALS['_xh']['headers']['content-encoding'] == 'gzip' && $degzdata = @gzinflate(substr($data, 10)))
$data = $degzdata;
if($this->debug)
---END---</PRE>";
else
error_log('XML-RPC: '.__METHOD__.': errors occurred when trying to decode the deflated data received from server');
$r = new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['decompress_fail'], $GLOBALS['xmlrpcstr']['decompress_fail']);
return $r;
else
error_log('XML-RPC: '.__METHOD__.': the server sent deflated data. Your php install must have the Zlib extension compiled in to support this.');
$r = new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['cannot_decompress'], $GLOBALS['xmlrpcstr']['cannot_decompress']);
return $r;
} // end of 'if needed, de-chunk, re-inflate response'
// real stupid hack to avoid PHP complaining about returning NULL by ref
$r = null;
$r =& $r;
return $r;
* Parse the xmlrpc response contained in the string $data and return an xmlrpcresp object.
* @param string $data the xmlrpc response, eventually including http headers
* @param bool $headers_processed when true prevents parsing HTTP headers for interpretation of content-encoding and consequent decoding
* @param string $return_type decides return type, i.e. content of response->value(). Either 'xmlrpcvals', 'xml' or 'phpvals'
* @access public
function &parseResponse($data='', $headers_processed=false, $return_type='xmlrpcvals')
if($this->debug)
//by maHo, replaced htmlspecialchars with htmlentities
print "<PRE>---GOT---
---END---
</PRE>";
if($data == '')
error_log('XML-RPC: '.__METHOD__.': no response received from server.');
$r = new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['no_data'], $GLOBALS['xmlrpcstr']['no_data']);
return $r;
$GLOBALS['_xh']=array();
$raw_data = $data;
// parse the HTTP headers of the response, if present, and separate them from data
if(substr($data, 0, 4) == 'HTTP')
$r =& $this->parseResponseHeaders($data, $headers_processed);
if ($r)
// failed processing of HTTP response headers
// save into response obj the full payload received, for debugging
$r->raw_data = $data;
return $r;
else
if($this->debug)
$start = strpos($data, '<!-- SERVER DEBUG INFO (BASE64 ENCODED):');
if ($start)
$start += strlen('<!-- SERVER DEBUG INFO (BASE64 ENCODED):');
$end = strpos($data, '-->', $start);
$comments = substr($data, $start, $end-$start);
print "<PRE>---SERVER DEBUG INFO (DECODED) ---
".htmlentities(str_replace("
", base64_decode($comments)))."
---END---
</PRE>";
// be tolerant of extra whitespace in response body
$data = trim($data);
/// @todo return an error msg if $data=='' ?
// be tolerant of junk after methodResponse (e.g. javascript ads automatically inserted by free hosts)
// idea from Luca Mariano <luca.mariano@email.it> originally in PEARified version of the lib
$pos = strrpos($data, '</methodResponse>');
if($pos !== false)
$data = substr($data, 0, $pos+17);
// if user wants back raw xml, give it to him
if ($return_type == 'xml')
$r = new xmlrpcresp($data, 0, '', 'xml');
$r->hdrs = $GLOBALS['_xh']['headers'];
$r->_cookies = $GLOBALS['_xh']['cookies'];
$r->raw_data = $raw_data;
return $r;
// try to 'guestimate' the character encoding of the received response
$resp_encoding = guess_encoding(@$GLOBALS['_xh']['headers']['content-type'], $data);
//$GLOBALS['_xh']['qt']=''; //unused...
$GLOBALS['_xh']['stack'] = array();
$GLOBALS['_xh']['valuestack'] = array();
$GLOBALS['_xh']['isf']=0; // 0 = OK, 1 for xmlrpc fault responses, 2 = invalid xmlrpc
$GLOBALS['_xh']['isf_reason']='';
$GLOBALS['_xh']['rt']=''; // 'methodcall or 'methodresponse'
// if response charset encoding is not known / supported, try to use
// the default encoding and parse the xml anyway, but log a warning...
if (!in_array($resp_encoding, array('UTF-8', 'ISO-8859-1', 'US-ASCII')))
// the following code might be better for mb_string enabled installs, but
// makes the lib about 200% slower...
//if (!is_valid_charset($resp_encoding, array('UTF-8', 'ISO-8859-1', 'US-ASCII')))
error_log('XML-RPC: '.__METHOD__.': invalid charset encoding of received response: '.$resp_encoding);
$resp_encoding = $GLOBALS['xmlrpc_defencoding'];
$parser = xml_parser_create($resp_encoding);
xml_parser_set_option($parser, XML_OPTION_CASE_FOLDING, true);
// G. Giunta 2005/02/13: PHP internally uses ISO-8859-1, so we have to tell
// the xml parser to give us back data in the expected charset.
// What if internal encoding is not in one of the 3 allowed?
// we use the broadest one, ie. utf8
// This allows to send data which is native in various charset,
// by extending xmlrpc_encode_entitites() and setting xmlrpc_internalencoding
if (!in_array($GLOBALS['xmlrpc_internalencoding'], array('UTF-8', 'ISO-8859-1', 'US-ASCII')))
xml_parser_set_option($parser, XML_OPTION_TARGET_ENCODING, 'UTF-8');
else
xml_parser_set_option($parser, XML_OPTION_TARGET_ENCODING, $GLOBALS['xmlrpc_internalencoding']);
if ($return_type == 'phpvals')
xml_set_element_handler($parser, 'xmlrpc_se', 'xmlrpc_ee_fast');
else
xml_set_element_handler($parser, 'xmlrpc_se', 'xmlrpc_ee');
xml_set_character_data_handler($parser, 'xmlrpc_cd');
xml_set_default_handler($parser, 'xmlrpc_dh');
// first error check: xml not well formed
if(!xml_parse($parser, $data, count($data)))
// thanks to Peter Kocks <peter.kocks@baygate.com>
if((xml_get_current_line_number($parser)) == 1)
$errstr = 'XML error at line 1, check URL';
else
$errstr = sprintf('XML error: %s at line %d, column %d',
xml_error_string(xml_get_error_code($parser)),
xml_get_current_line_number($parser), xml_get_current_column_number($parser));
error_log($errstr);
$r=new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['invalid_return'], $GLOBALS['xmlrpcstr']['invalid_return'].' ('.$errstr.')');
xml_parser_free($parser);
if($this->debug)
print $errstr;
return $r;
// second error check: xml well formed but not xml-rpc compliant
if ($GLOBALS['_xh']['isf'] > 1)
if ($this->debug)
/// @todo echo something for user?
$r = new xmlrpcresp(0, $GLOBALS['xmlrpcerr']['invalid_return'],
$GLOBALS['xmlrpcstr']['invalid_return'] . ' ' . $GLOBALS['_xh']['isf_reason']);
// third error check: parsing of the response has somehow gone boink.
// NB: shall we omit this check, since we trust the parsing code?
elseif ($return_type == 'xmlrpcvals' && !is_object($GLOBALS['_xh']['value']))
// something odd has happened
// and it's time to generate a client side error
// indicating something odd went on
$GLOBALS['xmlrpcstr']['invalid_return']);
else
if ($this->debug)
print "<PRE>---PARSED---
// somehow htmlentities chokes on var_export, and some full html string...
//print htmlentitites(var_export($GLOBALS['_xh']['value'], true));
print htmlspecialchars(var_export($GLOBALS['_xh']['value'], true));
print "
---END---</PRE>";
// note that using =& will raise an error if $GLOBALS['_xh']['st'] does not generate an object.
$v =& $GLOBALS['_xh']['value'];
if($GLOBALS['_xh']['isf'])
/// @todo we should test here if server sent an int and a string,
/// and/or coerce them into such...
if ($return_type == 'xmlrpcvals')
$errno_v = $v->structmem('faultCode');
$errstr_v = $v->structmem('faultString');
$errno = $errno_v->scalarval();
$errstr = $errstr_v->scalarval();
else
$errno = $v['faultCode'];
$errstr = $v['faultString'];
if($errno == 0)
// FAULT returned, errno needs to reflect that
$errno = -1;
$r = new xmlrpcresp(0, $errno, $errstr);
else
$r=new xmlrpcresp($v, 0, '', $return_type);
return $r;
class xmlrpcval
var $me=array();
var $mytype=0;
var $_php_class=null;
* @param mixed $val
* @param string $type any valid xmlrpc type name (lowercase). If null, 'string' is assumed
function xmlrpcval($val=-1, $type='')
/// @todo: optimization creep - do not call addXX, do it all inline.
/// downside: booleans will not be coerced anymore
if($val!==-1 || $type!='')
// optimization creep: inlined all work done by constructor
switch($type)
case '':
$this->mytype=1;
$this->me['string']=$val;
break;
case 'i4':
case 'int':
case 'double':
case 'string':
case 'boolean':
case 'dateTime.iso8601':
case 'base64':
case 'null':
$this->mytype=1;
$this->me[$type]=$val;
break;
case 'array':
$this->mytype=2;
$this->me['array']=$val;
break;
case 'struct':
$this->mytype=3;
$this->me['struct']=$val;
break;
default:
error_log("XML-RPC: ".__METHOD__.": not a known type ($type)");
/*if($type=='')
$type='string';
if($GLOBALS['xmlrpcTypes'][$type]==1)
$this->addScalar($val,$type);
elseif($GLOBALS['xmlrpcTypes'][$type]==2)
$this->addArray($val);
elseif($GLOBALS['xmlrpcTypes'][$type]==3)
$this->addStruct($val);
* Add a single php value to an (unitialized) xmlrpcval
* @param mixed $val
* @return int 1 or 0 on failure
function addScalar($val, $type='string')
$typeof=@$GLOBALS['xmlrpcTypes'][$type];
if($typeof!=1)
error_log("XML-RPC: ".__METHOD__.": not a scalar type ($type)");
return 0;
// coerce booleans into correct values
// NB: we should either do it for datetimes, integers and doubles, too,
// or just plain remove this check, implemented on booleans only...
if($type==$GLOBALS['xmlrpcBoolean'])
if(strcasecmp($val,'true')==0 || $val==1 || ($val==true && strcasecmp($val,'false')))
$val=true;
else
$val=false;
switch($this->mytype)
case 1:
error_log('XML-RPC: '.__METHOD__.': scalar xmlrpcval can have only one value');
return 0;
case 3:
error_log('XML-RPC: '.__METHOD__.': cannot add anonymous scalar to struct xmlrpcval');
return 0;
case 2:
// we're adding a scalar value to an array here
//$ar=$this->me['array'];
//$ar[]=new xmlrpcval($val, $type);
//$this->me['array']=$ar;
// Faster (?) avoid all the costly array-copy-by-val done here...
$this->me['array'][]=new xmlrpcval($val, $type);
return 1;
default:
// a scalar, so set the value and remember we're scalar
$this->mytype=$typeof;
return 1;
* Add an array of xmlrpcval objects to an xmlrpcval
* @param array $vals
* @access public
* @todo add some checking for $vals to be an array of xmlrpcvals?
function addArray($vals)
if($this->mytype==0)
$this->mytype=$GLOBALS['xmlrpcTypes']['array'];
$this->me['array']=$vals;
return 1;
elseif($this->mytype==2)
// we're adding to an array here
$this->me['array'] = array_merge($this->me['array'], $vals);
return 1;
else
error_log('XML-RPC: '.__METHOD__.': already initialized as a [' . $this->kindOf() . ']');
return 0;
* Add an array of named xmlrpcval objects to an xmlrpcval
* @access public
* @todo add some checking for $vals to be an array?
function addStruct($vals)
$this->mytype=$GLOBALS['xmlrpcTypes']['struct'];
$this->me['struct']=$vals;
return 1;
elseif($this->mytype==3)
// we're adding to a struct here
$this->me['struct'] = array_merge($this->me['struct'], $vals);
return 1;
else
return 0;
// poor man's version of print_r ???
// DEPRECATED!
function dump($ar)
foreach($ar as $key => $val)
echo "$key => $val<br />";
if($key == 'array')
while(list($key2, $val2) = each($val))
echo "-- $key2 => $val2<br />";
* Returns a string containing "struct", "array" or "scalar" describing the base type of the value
* @return string
* @access public
function kindOf()
case 3:
return 'struct';
break;
case 2:
return 'array';
break;
case 1:
return 'scalar';
break;
default:
return 'undef';
* @access private
function serializedata($typ, $val, $charset_encoding='')
$rs='';
switch(@$GLOBALS['xmlrpcTypes'][$typ])
case 1:
switch($typ)
case $GLOBALS['xmlrpcBase64']:
$rs.="<${typ}>" . base64_encode($val) . "</${typ}>";
break;
case $GLOBALS['xmlrpcBoolean']:
$rs.="<${typ}>" . ($val ? '1' : '0') . "</${typ}>";
break;
case $GLOBALS['xmlrpcString']:
// G. Giunta 2005/2/13: do NOT use htmlentities, since
// it will produce named html entities, which are invalid xml
$rs.="<${typ}>" . xmlrpc_encode_entitites($val, $GLOBALS['xmlrpc_internalencoding'], $charset_encoding). "</${typ}>";
break;
case $GLOBALS['xmlrpcInt']:
case $GLOBALS['xmlrpcI4']:
$rs.="<${typ}>".(int)$val."</${typ}>";
break;
case $GLOBALS['xmlrpcDouble']:
// avoid using standard conversion of float to string because it is locale-dependent,
// and also because the xmlrpc spec forbids exponential notation.
// sprintf('%F') could be most likely ok but it fails eg. on 2e-14.
// The code below tries its best at keeping max precision while avoiding exp notation,
// but there is of course no limit in the number of decimal places to be used...
$rs.="<${typ}>".preg_replace('/\\.?0+$/','',number_format((double)$val, 128, '.', ''))."</${typ}>";
break;
case $GLOBALS['xmlrpcDateTime']:
if (is_string($val))
$rs.="<${typ}>${val}</${typ}>";
else if(is_a($val, 'DateTime'))
$rs.="<${typ}>".$val->format('Ymd\TH:i:s')."</${typ}>";
else if(is_int($val))
$rs.="<${typ}>".strftime("%Y%m%dT%H:%M:%S", $val)."</${typ}>";
else
// not really a good idea here: but what shall we output anyway? left for backward compat...
break;
case $GLOBALS['xmlrpcNull']:
if ($GLOBALS['xmlrpc_null_apache_encoding'])
$rs.="<ex:nil/>";
else
$rs.="<nil/>";
break;
default:
// no standard type value should arrive here, but provide a possibility
// for xmlrpcvals of unknown type...
break;
case 3:
// struct
if ($this->_php_class)
$rs.='<struct php_class="' . $this->_php_class . "\">
else
$rs.="<struct>
foreach($val as $key2 => $val2)
$rs.='<member><name>'.xmlrpc_encode_entitites($key2, $GLOBALS['xmlrpc_internalencoding'], $charset_encoding)."</name>
//$rs.=$this->serializeval($val2);
$rs.=$val2->serialize($charset_encoding);
$rs.="</member>
$rs.='</struct>';
break;
case 2:
// array
$rs.="<array>
<data>
for($i=0; $i<count($val); $i++)
//$rs.=$this->serializeval($val[$i]);
$rs.=$val[$i]->serialize($charset_encoding);
$rs.="</data>
</array>";
break;
default:
break;
return $rs;
* Returns xml representation of the value. XML prologue not included
* @return string
* @access public
// add check? slower, but helps to avoid recursion in serializing broken xmlrpcvals...
//if (is_object($o) && (get_class($o) == 'xmlrpcval' || is_subclass_of($o, 'xmlrpcval')))
reset($this->me);
list($typ, $val) = each($this->me);
return '<value>' . $this->serializedata($typ, $val, $charset_encoding) . "</value>
// DEPRECATED
function serializeval($o)
$ar=$o->me;
reset($ar);
list($typ, $val) = each($ar);
return '<value>' . $this->serializedata($typ, $val) . "</value>
* Checks wheter a struct member with a given name is present.
* Works only on xmlrpcvals of type struct.
* @param string $m the name of the struct member to be looked up
* @return boolean
* @access public
function structmemexists($m)
return array_key_exists($m, $this->me['struct']);
* Returns the value of a given struct member (an xmlrpcval object in itself).
* Will raise a php warning if struct member of given name does not exist
* @return xmlrpcval
* @access public
function structmem($m)
return $this->me['struct'][$m];
* Reset internal pointer for xmlrpcvals of type struct.
* @access public
function structreset()
reset($this->me['struct']);
* Return next member element for xmlrpcvals of type struct.
* @return xmlrpcval
* @access public
function structeach()
return each($this->me['struct']);
// DEPRECATED! this code looks like it is very fragile and has not been fixed
// for a long long time. Shall we remove it for 2.0?
function getval()
// UNSTABLE
reset($this->me);
list($a,$b)=each($this->me);
// contributed by I Sofer, 2001-03-24
// add support for nested arrays to scalarval
// i've created a new method here, so as to
// preserve back compatibility
if(is_array($b))
@reset($b);
while(list($id,$cont) = @each($b))
$b[$id] = $cont->scalarval();
// add support for structures directly encoding php objects
if(is_object($b))
$t = get_object_vars($b);
@reset($t);
while(list($id,$cont) = @each($t))
$t[$id] = $cont->scalarval();
@reset($t);
@$b->$id = $cont;
// end contrib
return $b;
* Returns the value of a scalar xmlrpcval
* @return mixed
* @access public
function scalarval()
reset($this->me);
list(,$b)=each($this->me);
return $b;
* Returns the type of the xmlrpcval.
* For integers, 'int' is always returned in place of 'i4'
* @return string
* @access public
function scalartyp()
reset($this->me);
list($a,)=each($this->me);
if($a==$GLOBALS['xmlrpcI4'])
$a=$GLOBALS['xmlrpcInt'];
return $a;
* Returns the m-th member of an xmlrpcval of struct type
* @param integer $m the index of the value to be retrieved (zero based)
* @return xmlrpcval
* @access public
function arraymem($m)
return $this->me['array'][$m];
* Returns the number of members in an xmlrpcval of array type
* @return integer
* @access public
function arraysize()
return count($this->me['array']);
* Returns the number of members in an xmlrpcval of struct type
* @return integer
* @access public
function structsize()
return count($this->me['struct']);
// date helpers
* Given a timestamp, return the corresponding ISO8601 encoded string.
* Really, timezones ought to be supported
* but the XML-RPC spec says:
* "Don't assume a timezone. It should be specified by the server in its
* documentation what assumptions it makes about timezones."
* These routines always assume localtime unless
* $utc is set to 1, in which case UTC is assumed
* and an adjustment for locale is made when encoding
* @param int $timet (timestamp)
* @param int $utc (0 or 1)
* @return string
function iso8601_encode($timet, $utc=0)
if(!$utc)
$t=strftime("%Y%m%dT%H:%M:%S", $timet);
else
if(function_exists('gmstrftime'))
// gmstrftime doesn't exist in some versions
// of PHP
$t=gmstrftime("%Y%m%dT%H:%M:%S", $timet);
else
$t=strftime("%Y%m%dT%H:%M:%S", $timet-date('Z'));
return $t;
* Given an ISO8601 date string, return a timet in the localtime, or UTC
* @param string $idate
* @param int $utc either 0 or 1
* @return int (datetime)
function iso8601_decode($idate, $utc=0)
$t=0;
if(preg_match('/([0-9]{4})([0-9]{2})([0-9]{2})T([0-9]{2}):([0-9]{2}):([0-9]{2})/', $idate, $regs))
if($utc)
$t=gmmktime($regs[4], $regs[5], $regs[6], $regs[2], $regs[3], $regs[1]);
else
$t=mktime($regs[4], $regs[5], $regs[6], $regs[2], $regs[3], $regs[1]);
return $t;
* Takes an xmlrpc value in PHP xmlrpcval object format and translates it into native PHP types.
* Works with xmlrpc message objects as input, too.
* Given proper options parameter, can rebuild generic php object instances
* (provided those have been encoded to xmlrpc format using a corresponding
* option in php_xmlrpc_encode())
* PLEASE NOTE that rebuilding php objects involves calling their constructor function.
* This means that the remote communication end can decide which php code will
* get executed on your server, leaving the door possibly open to 'php-injection'
* style of attacks (provided you have some classes defined on your server that
* might wreak havoc if instances are built outside an appropriate context).
* Make sure you trust the remote server/client before eanbling this!
* @author Dan Libby (dan@libby.com)
* @param xmlrpcval $xmlrpc_val
* @param array $options if 'decode_php_objs' is set in the options array, xmlrpc structs can be decoded into php objects; if 'dates_as_objects' is set xmlrpc datetimes are decoded as php DateTime objects (standard is
* @return mixed
function php_xmlrpc_decode($xmlrpc_val, $options=array())
switch($xmlrpc_val->kindOf())
case 'scalar':
if (in_array('extension_api', $options))
reset($xmlrpc_val->me);
list($typ,$val) = each($xmlrpc_val->me);
switch ($typ)
$xmlrpc_val->scalar = $val;
$xmlrpc_val->xmlrpc_type = 'datetime';
$xmlrpc_val->timestamp = iso8601_decode($val);
return $xmlrpc_val;
case 'base64':
$xmlrpc_val->type = $typ;
return $xmlrpc_val;
default:
return $xmlrpc_val->scalarval();
if (in_array('dates_as_objects', $options) && $xmlrpc_val->scalartyp() == 'dateTime.iso8601')
// we return a Datetime object instead of a string
// since now the constructor of xmlrpcval accepts safely strings, ints and datetimes,
// we cater to all 3 cases here
$out = $xmlrpc_val->scalarval();
if (is_string($out))
$out = strtotime($out);
if (is_int($out))
$result = new Datetime();
$result->setTimestamp($out);
return $result;
elseif (is_a($out, 'Datetime'))
return $out;
case 'array':
$size = $xmlrpc_val->arraysize();
$arr = array();
for($i = 0; $i < $size; $i++)
$arr[] = php_xmlrpc_decode($xmlrpc_val->arraymem($i), $options);
return $arr;
case 'struct':
$xmlrpc_val->structreset();
// If user said so, try to rebuild php objects for specific struct vals.
/// @todo should we raise a warning for class not found?
// shall we check for proper subclass of xmlrpcval instead of
// presence of _php_class to detect what we can do?
if (in_array('decode_php_objs', $options) && $xmlrpc_val->_php_class != ''
&& class_exists($xmlrpc_val->_php_class))
$obj = @new $xmlrpc_val->_php_class;
while(list($key,$value)=$xmlrpc_val->structeach())
$obj->$key = php_xmlrpc_decode($value, $options);
return $obj;
else
$arr = array();
$arr[$key] = php_xmlrpc_decode($value, $options);
return $arr;
case 'msg':
$paramcount = $xmlrpc_val->getNumParams();
$arr = array();
for($i = 0; $i < $paramcount; $i++)
$arr[] = php_xmlrpc_decode($xmlrpc_val->getParam($i));
return $arr;
// This constant left here only for historical reasons...
// it was used to decide if we have to define xmlrpc_encode on our own, but
// we do not do it anymore
if(function_exists('xmlrpc_decode'))
define('XMLRPC_EPI_ENABLED','1');
else
define('XMLRPC_EPI_ENABLED','0');
* Takes native php types and encodes them into xmlrpc PHP object format.
* It will not re-encode xmlrpcval objects.
* Feature creep -- could support more types via optional type argument
* (string => datetime support has been added, ??? => base64 not yet)
* If given a proper options parameter, php object instances will be encoded
* into 'special' xmlrpc values, that can later be decoded into php objects
* by calling php_xmlrpc_decode() with a corresponding option
* @param mixed $php_val the value to be converted into an xmlrpcval object
* @param array $options can include 'encode_php_objs', 'auto_dates', 'null_extension' or 'extension_api'
* @return xmlrpcval
function php_xmlrpc_encode($php_val, $options=array())
$type = gettype($php_val);
switch($type)
case 'string':
if (in_array('auto_dates', $options) && preg_match('/^[0-9]{8}T[0-9]{2}:[0-9]{2}:[0-9]{2}$/', $php_val))
$xmlrpc_val = new xmlrpcval($php_val, $GLOBALS['xmlrpcDateTime']);
else
$xmlrpc_val = new xmlrpcval($php_val, $GLOBALS['xmlrpcString']);
break;
case 'integer':
$xmlrpc_val = new xmlrpcval($php_val, $GLOBALS['xmlrpcInt']);
break;
case 'double':
$xmlrpc_val = new xmlrpcval($php_val, $GLOBALS['xmlrpcDouble']);
break;
// <G_Giunta_2001-02-29>
// Add support for encoding/decoding of booleans, since they are supported in PHP
case 'boolean':
$xmlrpc_val = new xmlrpcval($php_val, $GLOBALS['xmlrpcBoolean']);
break;
// </G_Giunta_2001-02-29>
case 'array':
// PHP arrays can be encoded to either xmlrpc structs or arrays,
// depending on wheter they are hashes or plain 0..n integer indexed
// A shorter one-liner would be
// $tmp = array_diff(array_keys($php_val), range(0, count($php_val)-1));
// but execution time skyrockets!
$j = 0;
$arr = array();
$ko = false;
foreach($php_val as $key => $val)
$arr[$key] = php_xmlrpc_encode($val, $options);
if(!$ko && $key !== $j)
$ko = true;
$j++;
if($ko)
$xmlrpc_val = new xmlrpcval($arr, $GLOBALS['xmlrpcStruct']);
else
$xmlrpc_val = new xmlrpcval($arr, $GLOBALS['xmlrpcArray']);
break;
case 'object':
if(is_a($php_val, 'xmlrpcval'))
$xmlrpc_val = $php_val;
else if(is_a($php_val, 'DateTime'))
$xmlrpc_val = new xmlrpcval($php_val->format('Ymd\TH:i:s'), $GLOBALS['xmlrpcStruct']);
else
$arr = array();
reset($php_val);
while(list($k,$v) = each($php_val))
$arr[$k] = php_xmlrpc_encode($v, $options);
if (in_array('encode_php_objs', $options))
// let's save original class name into xmlrpcval:
// might be useful later on...
$xmlrpc_val->_php_class = get_class($php_val);
break;
case 'NULL':
$xmlrpc_val = new xmlrpcval('', $GLOBALS['xmlrpcString']);
else if (in_array('null_extension', $options))
$xmlrpc_val = new xmlrpcval('', $GLOBALS['xmlrpcNull']);
else
$xmlrpc_val = new xmlrpcval();
break;
case 'resource':
$xmlrpc_val = new xmlrpcval((int)$php_val, $GLOBALS['xmlrpcInt']);
else
// catch "user function", "unknown type"
default:
// giancarlo pinerolo <ping@alt.it>
// it has to return
// an empty object in case, not a boolean.
break;
return $xmlrpc_val;
* Convert the xml representation of a method response, method request or single
* xmlrpc value into the appropriate object (a.k.a. deserialize)
* @param string $xml_val
* @return mixed false on error, or an instance of either xmlrpcval, xmlrpcmsg or xmlrpcresp
function php_xmlrpc_decode_xml($xml_val, $options=array())
$GLOBALS['_xh'] = array();
$GLOBALS['_xh']['ac'] = '';
$GLOBALS['_xh']['params'] = array();
$GLOBALS['_xh']['pt'] = array();
$GLOBALS['_xh']['isf'] = 0;
$GLOBALS['_xh']['isf_reason'] = '';
$GLOBALS['_xh']['method'] = false;
$GLOBALS['_xh']['rt'] = '';
/// @todo 'guestimate' encoding
$parser = xml_parser_create();
// we use the broadest one, ie. utf8!
else
xml_set_element_handler($parser, 'xmlrpc_se_any', 'xmlrpc_ee');
if(!xml_parse($parser, $xml_val, 1))
error_log($errstr);
return false;
if ($GLOBALS['_xh']['isf'] > 1) // test that $GLOBALS['_xh']['value'] is an obj, too???
error_log($GLOBALS['_xh']['isf_reason']);
return false;
switch ($GLOBALS['_xh']['rt'])
case 'methodresponse':
if ($GLOBALS['_xh']['isf'] == 1)
$vc = $v->structmem('faultCode');
$vs = $v->structmem('faultString');
$r = new xmlrpcresp(0, $vc->scalarval(), $vs->scalarval());
else
$r = new xmlrpcresp($v);
return $r;
case 'methodcall':
$m = new xmlrpcmsg($GLOBALS['_xh']['method']);
for($i=0; $i < count($GLOBALS['_xh']['params']); $i++)
$m->addParam($GLOBALS['_xh']['params'][$i]);
return $m;
case 'value':
return $GLOBALS['_xh']['value'];
default:
return false;
* decode a string that is encoded w/ "chunked" transfer encoding
* as defined in rfc2068 par. 19.4.6
* code shamelessly stolen from nusoap library by Dietrich Ayala
* @param string $buffer the string to be decoded
* @return string
function decode_chunked($buffer)
// length := 0
$length = 0;
$new = '';
// read chunk-size, chunk-extension (if any) and crlf
// get the position of the linebreak
$chunkend = strpos($buffer,"
") + 2;
$temp = substr($buffer,0,$chunkend);
$chunk_size = hexdec( trim($temp) );
$chunkstart = $chunkend;
while($chunk_size > 0)
$chunkend = strpos($buffer, "
", $chunkstart + $chunk_size);
// just in case we got a broken connection
if($chunkend == false)
$chunk = substr($buffer,$chunkstart);
// append chunk-data to entity-body
$new .= $chunk;
$length += strlen($chunk);
break;
// read chunk-data and crlf
$chunk = substr($buffer,$chunkstart,$chunkend-$chunkstart);
$new .= $chunk;
// length := length + chunk-size
// read chunk-size and crlf
$chunkstart = $chunkend + 2;
",$chunkstart)+2;
break; //just in case we got a broken connection
$temp = substr($buffer,$chunkstart,$chunkend-$chunkstart);
return $new;
* xml charset encoding guessing helper function.
* Tries to determine the charset encoding of an XML chunk received over HTTP.
* NB: according to the spec (RFC 3023), if text/xml content-type is received over HTTP without a content-type,
* we SHOULD assume it is strictly US-ASCII. But we try to be more tolerant of unconforming (legacy?) clients/servers,
* which will be most probably using UTF-8 anyway...
* @param string $httpheaders the http Content-type header
* @param string $xmlchunk xml content buffer
* @param string $encoding_prefs comma separated list of character encodings to be used as default (when mb extension is enabled)
* @todo explore usage of mb_http_input(): does it detect http headers + post data? if so, use it instead of hand-detection!!!
function guess_encoding($httpheader='', $xmlchunk='', $encoding_prefs=null)
// discussion: see http://www.yale.edu/pclt/encoding/
// 1 - test if encoding is specified in HTTP HEADERS
//Details:
// LWS: (\13\10)?( | )+
// token: (any char but excluded stuff)+
// quoted string: " (any char but double quotes and cointrol chars)* "
// header: Content-type = ...; charset=value(; ...)*
// where value is of type token, no LWS allowed between 'charset' and value
// Note: we do not check for invalid chars in VALUE:
// this had better be done using pure ereg as below
// Note 2: we might be removing whitespace/tabs that ought to be left in if
// the received charset is a quoted string. But nobody uses such charset names...
/// @todo this test will pass if ANY header has charset specification, not only Content-Type. Fix it?
$matches = array();
if(preg_match('/;\s*charset\s*=([^;]+)/i', $httpheader, $matches))
return strtoupper(trim($matches[1], " \""));
// 2 - scan the first bytes of the data for a UTF-16 (or other) BOM pattern
// (source: http://www.w3.org/TR/2000/REC-xml-20001006)
// NOTE: actually, according to the spec, even if we find the BOM and determine
// an encoding, we should check if there is an encoding specified
// in the xml declaration, and verify if they match.
/// @todo implement check as described above?
/// @todo implement check for first bytes of string even without a BOM? (It sure looks harder than for cases WITH a BOM)
if(preg_match('/^(\x00\x00\xFE\xFF|\xFF\xFE\x00\x00|\x00\x00\xFF\xFE|\xFE\xFF\x00\x00)/', $xmlchunk))
return 'UCS-4';
elseif(preg_match('/^(\xFE\xFF|\xFF\xFE)/', $xmlchunk))
return 'UTF-16';
elseif(preg_match('/^(\xEF\xBB\xBF)/', $xmlchunk))
return 'UTF-8';
// 3 - test if encoding is specified in the xml declaration
// Details:
// SPACE: (#x20 | #x9 | #xD | #xA)+ === [ \x9\xD\xA]+
// EQ: SPACE?=SPACE? === [ \x9\xD\xA]*=[ \x9\xD\xA]*
if (preg_match('/^<\?xml\s+version\s*=\s*'. "((?:\"[a-zA-Z0-9_.:-]+\")|(?:'[a-zA-Z0-9_.:-]+'))".
'\s+encoding\s*=\s*' . "((?:\"[A-Za-z][A-Za-z0-9._-]*\")|(?:'[A-Za-z][A-Za-z0-9._-]*'))/",
$xmlchunk, $matches))
return strtoupper(substr($matches[2], 1, -1));
// 4 - if mbstring is available, let it do the guesswork
// NB: we favour finding an encoding that is compatible with what we can process
if(extension_loaded('mbstring'))
if($encoding_prefs)
$enc = mb_detect_encoding($xmlchunk, $encoding_prefs);
else
$enc = mb_detect_encoding($xmlchunk);
// NB: mb_detect likes to call it ascii, xml parser likes to call it US_ASCII...
// IANA also likes better US-ASCII, so go with it
if($enc == 'ASCII')
$enc = 'US-'.$enc;
return $enc;
else
// no encoding specified: as per HTTP1.1 assume it is iso-8859-1?
// Both RFC 2616 (HTTP 1.1) and 1945 (HTTP 1.0) clearly state that for text/xxx content types
// this should be the standard. And we should be getting text/xml as request and response.
// BUT we have to be backward compatible with the lib, which always used UTF-8 as default...
return $GLOBALS['xmlrpc_defencoding'];
* Checks if a given charset encoding is present in a list of encodings or
* if it is a valid subset of any encoding in the list
* @param string $encoding charset to be tested
* @param mixed $validlist comma separated list of valid charsets (or array of charsets)
function is_valid_charset($encoding, $validlist)
$charset_supersets = array(
'US-ASCII' => array ('ISO-8859-1', 'ISO-8859-2', 'ISO-8859-3', 'ISO-8859-4',
'ISO-8859-5', 'ISO-8859-6', 'ISO-8859-7', 'ISO-8859-8',
'ISO-8859-9', 'ISO-8859-10', 'ISO-8859-11', 'ISO-8859-12',
'ISO-8859-13', 'ISO-8859-14', 'ISO-8859-15', 'UTF-8',
'EUC-JP', 'EUC-', 'EUC-KR', 'EUC-CN')
if (is_string($validlist))
$validlist = explode(',', $validlist);
if (@in_array(strtoupper($encoding), $validlist))
return true;
else
if (array_key_exists($encoding, $charset_supersets))
foreach ($validlist as $allowed)
if (in_array($allowed, $charset_supersets[$encoding]))
return true;
return false;
