Today I stubbled into a new chapter in IPS - „dashboard“ designer ! I Created a button with the IPSYMID value „24173“, The value is the object ID to a moeller dimmer. then I wrote a simple script like this thinking that I can use the $IPS_COMPONENT.
paresy, thank you for your prompt answere „like always“ - I didn’t get your example to work - Tried to find some documentation on „IPS_GetStatusVariableID“ but I think there are some problem in IPS online documentation. Under the chapter „IPS_GetStatusVariableID“ I see you describe the function „IPS_Execute“.
Following example
did not work
```php
if( $IPS_SENDER == "Designer" ) {
MXC_SwitchMode($IPS_COMPONENT,!GetValue (IPS_GetStatusVariableID ($IPS_COMPONENT, "Status")));
Following example
worked using GetVariableIDByName instead of IPS_GetStatusVariableID and convert string to integer.
```php
MXC_SwitchMode((integer)$IPS_COMPONENT, !GetValue(IPS_GetVariableIDByName("Status", (integer)$IPS_COMPONENT)));
Thank you for the code example, worked like charm. Can I ask you what’s the different between IPS_GetStatusVariableID and IPS_GetVariableIDByName it looks like they do the same magic job.
IPS_GetStatusVariableID works on an internal name, which is unique and won’t change
IPS_GetVariableIDByName works on the object name you can see and modify in the logical tree view. Therefore it may change and break your script while the first option will always work.
