Wie sieht dein Topic aus?
wie sieht denn dein Tasmota-Script aus und was siehst Du in der Tasmota-Console. Tasmota ist ja allgemein gehalten und es gibt viele unterschiedlich Zähler und Protokolle.
In der Console von Tasmote sollte es in etwa so aussehen:
08:49:44.761 MQT: tele/tasmota_1ED246/STATE = {"Time":"2023-10-15T08:49:44","Uptime":"101T15:09:21","UptimeSec":8780961,"Heap":19,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":45,"POWER":"OFF","Wifi":{"AP":1,"SSId":"RBFritz","BSSId":"2C:3A:FD:A9:2E:F9","Channel":6,"Mode":"11n","RSSI":76,"Signal":-62,"LinkCount":7,"Downtime":"0T00:02:20"}}
08:49:44.770 MQT: tele/tasmota_1ED246/SENSOR = {"Time":"2023-10-15T08:49:44","SML":{"Gesamt":16283.410,"NT":13421.574,"HT":2861.837,"Verbrauch":482}}
Hier bekommst Du eine übersicht für den Anfang: https://hessburg.de/tasmota-wifi-smartmeter-konfigurieren/
Ralf
09:31:01.416 MQT: tele/Zaehler1/STATE = {"Time":"2023-10-15T09:31:01","Uptime":"0T13:13:18","UptimeSec":47598,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Appel tree 1","BSSId":"3C:A6:2F:5D:26:CF","Channel":13,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:03"}}
09:31:01.424 MQT: tele/Zaehler1/SENSOR = {"Time":"2023-10-15T09:31:01","":{"Total_in":0.00,"Total_out":0.00,"Power_curr":0}}
09:31:11.415 MQT: tele/Zaehler1/STATE = {"Time":"2023-10-15T09:31:11","Uptime":"0T13:13:28","UptimeSec":47608,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Appel tree 1","BSSId":"3C:A6:2F:5D:26:CF","Channel":13,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:03"}}
09:31:11.424 MQT: tele/Zaehler1/SENSOR = {"Time":"2023-10-15T09:31:11","":{"Total_in":0.00,"Total_out":0.00,"Power_curr":0}}
09:31:21.426 MQT: tele/Zaehler1/STATE = {"Time":"2023-10-15T09:31:21","Uptime":"0T13:13:38","UptimeSec":47618,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Appel tree 1","BSSId":"3C:A6:2F:5D:26:CF","Channel":13,"Mode":"11n","RSSI":82,"Signal":-59,"LinkCount":1,"Downtime":"0T00:00:03"}}
09:31:21.433 MQT: tele/Zaehler1/SENSOR = {"Time":"2023-10-15T09:31:21","":{"Total_in":0.00,"Total_out":0.00,"Power_curr":0}}
mit dem script
>D
>B
=>sensor53 r
>M 1
+1,3,s,0,9600,
1,77070100010800ff@1000,Gesamtverbrauch,KWh,Total_in,2
1,77070100020800ff@1000,Gesamteinspeisung,KWh,Total_out,2
1,77070100100700ff@1,Verbrauch,W,Power_curr,0
das Topic ist „Zaehler1“
Bei mir in der Instanz:
Dann müsste das ja bei dir sein:
Probiere mal diese Zeile ob dann die Daten kommen.
ok ich trage es nach
Sieht besser aus
Mir fehlt zB. noch der 181 Einspeisewert
bzw der ist nicht richtig
In den mqtt Daten stand noch:
Es wurde also 0 geliefert Protokoll stimmt noch nicht.
Ralf
der sensor war nicht auf der DIODE, es kommen jetzt Wert aber die muss ich mir heut Abend mal genauer ansehen.
Vielen Dank schon mal das ich einen Schritt weiter bin. Schönen Sonntag schon mal
kann der auch HT und NT auslesen ?
280
181
182
aktuell bekomme ich 181 und 182 addiert nur zurück
Das weiß ich jetzt nicht. Mein Zähler hat nur 1.8.0 und 2.8.0. Vielleicht könnte man das im Modul selber erledigen lassen. Müsste mal im Thread vom Modul Ersteller fragen.
Wenn er aber beide addiert ist das ja letztlich der richtige Wert/Verbrauch was er aus dem Netz zieht.
Welche Daten bringt er wenn du in der Tasmota Konsole eingibst:
sensor53 d1
Danach wieder ausschalten mit
sensor53 d0
Hast du das richtig Skript zu deinem Zähler in Tasmota hinterlegt?
wenn du das Script wie hier beschrieben eingibst, dann sollte die Kommunikation mit dem Obis-Counter-Modul aus dem Module-Store einwandfrei funktionieren.
Jürgen
35:52.995 CMD: sensor53 d1
07:35:53.000 MQT: stat/Zaehler1/RESULT = {"Time":"2023-10-16T07:35:52","SML":{"CMD":"dump: 1"}}
07:35:53.055 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:35:53.057 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:35:53.059 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 22 02 01
07:35:54.454 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:35:54.484 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 0f 7a
07:35:54.502 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:35:54.527 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:35:54.552 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 68 01
07:35:54.578 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:35:54.598 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 91 01
07:35:54.620 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:35:54.642 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:35:54.664 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:35:54.685 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 ee 01
07:35:56.134 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:35:56.165 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 11 7a
07:35:56.183 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:35:56.207 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:35:56.232 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 6c 01
07:35:56.257 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:35:56.282 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 95 01
07:35:56.301 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:35:56.322 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:35:56.345 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:35:56.365 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 dd 01
07:35:57.762 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:35:57.793 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 13 7a
07:35:57.810 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:35:57.836 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:35:57.861 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 70 01
07:35:57.885 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:35:57.907 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 99 01
07:35:57.930 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:35:57.977 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:35:57.979 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:35:57.993 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 22 04 01
07:35:59.386 MQT: tele/Zaehler1/STATE = {"Time":"2023-10-16T07:35:59","Uptime":"0T21:53:50","UptimeSec":78830,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Appel tree 1","BSSId":"3C:A6:2F:5D:26:CF","Channel":13,"Mode":"11n","RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:05"}}
07:35:59.394 MQT: tele/Zaehler1/SENSOR = {"Time":"2023-10-16T07:35:59","":{"Total_in":25054.68,"Total_out":28091.28,"Power_curr":874}}
07:35:59.442 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:35:59.472 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 14 7a
07:35:59.489 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:35:59.514 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:35:59.540 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 74 01
07:35:59.565 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:35:59.587 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 9d 01
07:35:59.609 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:35:59.631 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:35:59.652 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:35:59.673 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 f1 01
07:36:01.110 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:01.139 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 16 7a
07:36:01.157 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:01.182 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:01.207 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 78 01
07:36:01.233 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:01.254 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 a1 01
07:36:01.276 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:01.299 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:01.319 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:01.340 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 eb 01
07:36:02.759 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:02.790 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 18 7a
07:36:02.806 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:02.867 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:02.870 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 7c 01
07:36:02.882 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:02.905 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 a5 01
07:36:02.926 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:02.948 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:02.970 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:02.990 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 69 01
07:36:04.428 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:04.459 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 19 7a
07:36:04.476 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:04.502 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:04.527 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 80 01
07:36:04.553 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:04.574 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 a9 01
07:36:04.596 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:04.618 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:04.640 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:04.661 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 9e 01
07:36:06.110 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:06.140 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 1b 7a
07:36:06.157 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:06.181 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:06.208 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 84 01
07:36:06.232 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:06.255 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 ad 01
07:36:06.275 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:06.298 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:06.319 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:06.340 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 b8 01
07:36:07.789 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:07.818 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 1d 7a
07:36:07.836 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:07.862 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:07.885 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 88 01
07:36:07.912 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:07.933 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 b1 01
07:36:07.955 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:07.977 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:07.998 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:08.019 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 bc 01
07:36:09.385 MQT: tele/Zaehler1/STATE = {"Time":"2023-10-16T07:36:09","Uptime":"0T21:54:00","UptimeSec":78840,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Appel tree 1","BSSId":"3C:A6:2F:5D:26:CF","Channel":13,"Mode":"11n","RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:05"}}
07:36:09.396 MQT: tele/Zaehler1/SENSOR = {"Time":"2023-10-16T07:36:09","":{"Total_in":25054.68,"Total_out":28091.28,"Power_curr":874}}
07:36:09.428 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:09.457 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 1e 7a
07:36:09.475 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:09.501 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:09.525 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 8c 01
07:36:09.550 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:09.572 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 b5 01
07:36:09.594 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:09.615 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:09.637 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:09.659 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 d6 01
07:36:11.097 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:11.127 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 20 7a
07:36:11.144 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:11.169 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:11.194 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 90 01
07:36:11.219 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:11.241 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 b9 01
07:36:11.263 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:11.284 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:11.308 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:11.328 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 f8 01
07:36:12.764 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:12.794 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 22 7a
07:36:12.812 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:12.837 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:12.863 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 94 01
07:36:12.887 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:12.908 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 bd 01
07:36:12.931 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:12.953 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:12.974 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:12.995 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 22 05 01
07:36:14.404 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:14.435 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 23 7a
07:36:14.453 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:14.476 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:14.502 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 98 01
07:36:14.526 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:14.548 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 c1 01
07:36:14.570 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:14.593 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:14.614 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:14.635 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 22 10 01
07:36:16.071 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:16.101 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 25 7a
07:36:16.119 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:16.145 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:16.169 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a 9c 01
07:36:16.195 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:16.216 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 c5 01
07:36:16.239 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:16.259 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:16.283 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:16.304 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 d7 01
07:36:17.752 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:17.782 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 27 7a
07:36:17.800 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:17.825 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:17.849 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a a0 01
07:36:17.875 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:17.897 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 c9 01
07:36:17.918 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:17.941 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:17.962 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:17.984 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 9e 01
07:36:19.388 MQT: tele/Zaehler1/STATE = {"Time":"2023-10-16T07:36:19","Uptime":"0T21:54:10","UptimeSec":78850,"Heap":18,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Appel tree 1","BSSId":"3C:A6:2F:5D:26:CF","Channel":13,"Mode":"11n","RSSI":100,"Signal":-50,"LinkCount":1,"Downtime":"0T00:00:05"}}
07:36:19.397 MQT: tele/Zaehler1/SENSOR = {"Time":"2023-10-16T07:36:19","":{"Total_in":25054.68,"Total_out":28091.28,"Power_curr":874}}
07:36:19.405 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:19.432 : 77 01 0b 09 01 45 4d 48 00 00 6e 86 7f 07 01 00 62 0a ff ff 72 62 01 65 0a 30 e4 28 7a
07:36:19.450 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 45 4d 48 01
07:36:19.474 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 45 4d 48 00 00 6e 86 7f 01
07:36:19.500 : 77 07 01 00 01 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 0e ef 0a a4 01
07:36:19.524 : 77 07 01 00 02 08 00 ff 64 01 01 82 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:19.546 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 56 00 08 80 b7 cd 01
07:36:19.569 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 56 00 10 be 63 7c 01
07:36:19.591 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 56 00 06 6e 52 d7 01
07:36:19.612 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 56 00 00 00 00 00 01
07:36:19.632 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 ff 55 00 00 21 d0 01
07:36:21.072 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 fc cc 95 42 d8 df 17 25 f0 a8 5b b3 4b 8d 51 3a 3c aa d7 1b 23 95 5b 73 83 6f
07:36:21.099 CMD: sensor53 d0
07:36:21.106 MQT: stat/Zaehler1/RESULT = {"Time":"2023-10-16T07:36:21","SML":{"CMD":"dump: 0"}}
hast du auch aktuell 2 Tarife?
Das ist das angepasste Skript von Silberstreifen das ich nutze, wobei ich nur hinten die Kommastellen geändert habe:
>D
>B
=>sensor53 r
>M 1
+1,3,s,0,9600,
1,77070100010800ff@1,Gesamtverbrauch,Wh,1.8.0,2
1,77070100020800ff@1,Gesamteinspeisung,Wh,2.8.0,2
1,77070100100700ff@1,Verbrauch,W,16.7.0,2
Ja bei der Wärmepumpe HT NT
hab mal ein anderes Script genommen, da bekomm ich 181/182 gemeldet.
Deins ging ja auch. Nur nicht NT HT
Kann man nicht den Dump von oben an die Firma Hichi (Hersteller) mailen und die passen das script mit den werten an ?
Ah Ok. Es gibt ja kein Universal Skript für alle Zähler. Manche Zähler werfen auch noch andere Werte aus, wie Spannung etc.
Habe eben auch mein Skript mit einer weiteren Zeile erweitert für 1.8.1, da bringt er mir aber den gleichen Wert wie bei 1.8.0. Ich denke das dann mein Zähler das nicht unterstützt bzw. auch nicht braucht wegen fehlender Wärmepumpe.
Aber wenn es ja jetzt funktioniert ist ja alles bestens. Kannst ja mal das Skript posten.
