I like to create a module for a Mitsubishi air conditioner (Smart M-Air).
Someone made already a device in Home Assistant
and
Is there a 'smart/structured way to convert this into an IPS Module?
Regards,
Jan Roelof
and
Regards,
Jan Roelof
Not really. You will need to understand the Python code and port it over to PHP, which Symcon uses. Unfortunately there is not „shortcut“. Some users that setup HA and connected to Symcon through MQTT, if this is a thing you would want to do.
