I created 2 different WebFront instances, and would like to create a direct app shortcut to both of them (Android). Right now I have to switch the instance in the IP-Symcon app. I think it would be more user friendly if I was able to create two individual app shortcuts. Is this possible?
When using the web interface this is quite simply accomplished by using the instance number.
Cheers,
Dennis.
