Hi ich habe wieder regelmäßige Crashs. Ich glaube seit dem ich vor kurzem wieder ein Update gemacht habe.
Die Fehler sehen so aus:
*** Error in `/usr/bin/symcon': double free or corruption (fasttop): 0x6f054a08 ***
Program received signal SIGABRT, Aborted.
[Switching to Thread 0x742ff430 (LWP 3221)]
0x76856f50 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
56 ../nptl/sysdeps/unix/sysv/linux/raise.c: Datei oder Verzeichnis nicht gefunden.
(gdb) bt
#0 0x76856f50 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
#1 0x76858304 in __GI_abort () at abort.c:89
#2 0x76892900 in __libc_message (do_abort=<optimized out>, fmt=0x76945628 "*** Error in `%s': %s: 0x%s ***
") at ../sysdeps/posix/libc_fatal.c:175
#3 0x76898b2c in malloc_printerr (action=1, str=0x76945864 "double free or corruption (fasttop)", ptr=<optimized out>) at malloc.c:4996
#4 0x76899ad0 in _int_free (av=<optimized out>, p=<optimized out>, have_lock=310189824) at malloc.c:3840
#5 0x76d2afd0 in ?? () from /usr/lib/arm-linux-gnueabihf/libcurl.so.4
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
