moin,
nach update auf 5.0.7761.38563 kommt nur noch ‚Object reference not set to an instance of an object‘ beim view generieren.
crashlog:
Crash 2021-04-10 09:25:19.907
Message: Invoke or BeginInvoke cannot be called on a control until the window handle has been created.
Stack: at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object args, Boolean synchronous)
at System.Windows.Forms.Control.Invoke(Delegate method, Object args)
at oEX70E0CGWQPWwsfKkY3FY0GTs8.Bba2gFQONt8ELahaZYI8aGuOZrl(AeGa2j022zyy1h5aEDQJkDenk7q )
at oEX70E0CGWQPWwsfKkY3FY0GTs8.Xv3d8CIuSuabkTlWWk6JXnSUHAm(String , Boolean , String )
at oEX70E0CGWQPWwsfKkY3FY0GTs8.AEJZ4HTDxsMhHZtASe0o0fGMFMm(Boolean )
at oEX70E0CGWQPWwsfKkY3FY0GTs8.NPGvMBk6krm4dkRJSvzqI94DcTk()
at oEX70E0CGWQPWwsfKkY3FY0GTs8…ctor()
at K87PRXRCVr8bEuNhpWSWZHMdf0J.dsGSJcAfkKaDtT9G3JrUY4Ep6mG()
