Hello,
Unfortunately, after the upgrade to the last version - 4.4, Windows x64, 2018-02-19, 36a7b6fcaa27 my 1-wire network based on esera Bus Coupler Ethernet 11308 (two devices) stop working properly. On 1-wire configurator instance I have strange device id -FFFFFFFFFFFFFEA0 with name - 0xA0. I have also other 1-wire device (BT bridge)which working normaly.
On all version I have the same problem.First I try to install older version on existing one. Then I try with clean install but problem still exist. OnewireViewer workig normaly. Is it possible that the last version changed something in the system?
Makki
Today I stopped ipsymcon service and rename main folder with my last 2058 installation. Then started with clean installation from 2044 version but 1-wire devices did not work properly. When I work with 2052 version I have restart computer 2 times and also unplug 1-wire controller from power and everything started working (I have made the same restart earlier with 2058 version but without success).
After that I deleted folder with 2052 version and rename folder with my final installation - 2058 version and everything working normally.
