I had to restart the ip_server because there was a problem with my homematic ccu2.
After the restart and using the ip_symcon management console to establish a connection with server, I got the following message:
Th target address is not IP_Symcon server. Error: net:Err_Connection_Refused.
I’ve no idea what caused this problem and how to solve this.
Hopefully somebody can help me.
The problem was caused by Windows 10 net framework. After reinstall of the framework the problem was solved
