The color selector “Farbauswahl” is not shown in Android Mobile, is this correct or should I change some settings?
Albert
Albert
The color selector is only available for the variable profile „HexColor“. For which variable are you missing the selector?
I don’t see the color selector on my Android Mobile App, in the WebFront it is no problem.
It is just not shown it looks like?
Albert
can you send a screenshot off your webfront and ifront-mobile.
i see the colorselector on both devices.
Mmmmm, OK, found it, I linked a Object which was below a Boolean. I changed the links directly to the Object and now it is working.
Thanks for your answer, because of your reaction that is should work I had to look better.
Sorry ……………
Albert
