Changes are not saved!
Hello,
After the implementation of a ip-camera in webfront there is something wrong with the saving of changes. When i for example make a new variable and close the console then everything is ok. But when i restart the PC all the changes are gone. The scripts are still on the harddisk but not visible in the console, very strange.
I hope someone has an idea, i already did a database check with sqlight and that was ok.
Greetz,
Dennis
Have you checked your settings.xml? You can use one of your backup settings.xml which you can find in the backup folder.
You can post your logfiles - Maybe we can find some clues why the settings are not saved properly.
