Is it possible to change the „WebFront Visualization“ title in the Android (iOS) app to some other text? If it is, I can’t find it.
Thanks!
Thanks!
I tried that, but it doesn’t change the „WebFront Visualization“ title on the Android (or iOS) app.
Have you tried deleting and re-entering the entry in the app?
You need to reconfigure the app afterwards.
I’ve removed and re-added the Symcon server in the app after renaming the „WebFront Visualization“ instance. That applies the change in the app. Thanks.
