Na dann, ich hab da zwar noch ein bisschen mehr mit gemacht aber hier mal alles was man zur korrekten Funktion benötigt.
So kann man darauf aufbauen und seiner Fantasie freien lauf lassen.
los geht es mit der Klasse.
* MyQ Klasse
* open/close/status Funktion
const MYQ_DOOR_ACTION_CLOSE = 0;
const MYQ_DOOR_ACTION_OPEN = 1;
const MYQ_DOOR_STATE_UNKNOWN = -1;
const MYQ_DOOR_STATE_OPEN = 1;
const MYQ_DOOR_STATE_CLOSED = 2;
const MYQ_DOOR_STATE_OPENING = 4;
const MYQ_DOOR_STATE_CLOSING = 5;
class MyQException extends Exception {}
class MyQState {
protected $_state = MYQ_DOOR_STATE_UNKNOWN;
protected $_stateTime = 0;
protected $_stateDescriptions = array (
MYQ_DOOR_STATE_UNKNOWN => 'unknown',
MYQ_DOOR_STATE_OPEN => 'offen',
MYQ_DOOR_STATE_CLOSED => 'geschlossen',
MYQ_DOOR_STATE_OPENING => 'wird geöffnet',
MYQ_DOOR_STATE_CLOSING => 'wird geschlossen',
public function __construct ($state=false, $timestamp=false) {
if ($state) {
$this->_state = $state;
$this->_stateTime = time();
if ($timestamp) {
$this->_stateTime = (int)$timestamp / 1000;
return $this;
public function __get ($attr) {
switch ($attr) {
case 'desc':
return $this->_stateDescriptions[$this->_state];
case 'time':
case 'updated':
case 'date':
return $this->_stateTime;
case 'delta':
return $this->_getTimeDelta('str');
case 'seconds':
return $this->_getTimeDelta();
$trace = debug_backtrace();
trigger_error(
'Undefined property via __get(): ' . $name .
' in ' . $trace[0]['file'] .
' on line ' . $trace[0]['line'],
E_USER_NOTICE);
return null;
public function __toString () {
private function _getTimeDelta($opt=null) {
$currentTz = date_default_timezone_get();
date_default_timezone_set('UTC');
$delta = time() - $this->_stateTime;
if ($opt != 'str') {
return $delta;
// Convert delta in human-readable format
// via https://stackoverflow.com/a/43956977/98030
$secondsInAMinute = 60;
$secondsInAnHour = 60 * $secondsInAMinute;
$secondsInADay = 24 * $secondsInAnHour;
// Extract days
$days = floor($delta / $secondsInADay);
// Extract hours
$hourSeconds = $delta % $secondsInADay;
$hours = floor($hourSeconds / $secondsInAnHour);
// Extract minutes
$minuteSeconds = $hourSeconds % $secondsInAnHour;
$minutes = floor($minuteSeconds / $secondsInAMinute);
// Extract the remaining seconds
$remainingSeconds = $minuteSeconds % $secondsInAMinute;
$seconds = ceil($remainingSeconds);
// Format and return
$timeParts = [];
$sections = [
'Tag' => (int)$days,
'Stunde' => (int)$hours,
'Minute' => (int)$minutes,
'Sekunde' => (int)$seconds,
foreach ($sections as $name => $value){
if ($value > 0){
$timeParts[] = $value. ' '.$name.($value == 1 ? '' : 'n');
return sizeof($timeParts) ? implode(', ', $timeParts) : '0 Sekunden';
class MyQ {
/** @var string|null $username contains the username used to authenticate with the MyQ API */
protected $username = null;
/** @var string|null $password contains the password used to authenticate with the MyQ API */
protected $password = null;
/** @var string|null $appId is the application ID used to register with the MyQ API */
protected $appId = 'Vj8pQggXLhLy0WHahglCD4N1nAkkXQtGYpq2HrHD7H1nvmbT55KqtN6RSF4ILB/i';
/** @var string|null $securityToken is the auth token returned after a successful login */
protected $securityToken = null;
/** @var string|null $userAgent is the User-Agent header value sent with each API request */
protected $userAgent = 'Chamberlain/3.4.1';
/** @var string|null $culture is the API culture code for the API */
protected $culture = 'en';
/** @var string|null $contentType is the content type used for all cURL requests */
protected $contentType = 'application/json';
/** @var array $headers contain HTTP headers for cURL requests */
protected $_headers = array();
protected $_deviceId = null;
protected $_locationName = null;
protected $_doorName = null;
protected $_doorState = null;
protected $_baseUrl = 'https://myqexternal.myqdevice.com/api/v4';
protected $_loginUri = '/User/Validate';
protected $_getDeviceDetailUri = '/UserDeviceDetails/Get';
protected $_putDeviceStateUri = '/DeviceAttribute/PutDeviceAttribute';
/** @var resource|null $_conn is the web connection to the MyQ API */
protected $_conn = null;
* Initializes class. Optionally allows user to override variables
* @param array $params A associative array for overwriting class variables
* @return MyQ
public function __construct ($params = array()) {
// Overwrite class variables
foreach ($params as $k => $v) {
$this->$k = $v;
// Initialize cURL request headers
if (sizeof($this->_headers) == 0) {
$this->_headers = array (
'MyQApplicationId' => $this->appId,
'Culture' => $this->culture,
'Content-Type' => $this->contentType,
'User-Agent' => $this->userAgent,
// Initialize cURL connection
$this->_init();
return $this;
if ($attr == 'state') {
return $this->_doorState;
if (isset($this->$attr)) {
return $this->$attr;
trigger_error(
E_USER_NOTICE);
return null;
public function __set ($attr, $value) {
switch ($attr) {
case 'open':
return ($value) ? $this->open() : $this->close();
break;
case 'close':
return ($value) ? $this->close() : $this->open();
break;
trigger_error(
'Undefined property via __set(): ' . $name .
E_USER_NOTICE);
return null;
* Perform a login request
* @param string|null $username Username to use when logging in
* @param string|null $password Password to use for logging in
* @return MyQ
public function login ($username = null, $password = null) {
// Set username/password if not null
if (!is_null($username)) {
$this->username = $username;
if (!is_null($password)) {
$this->password = $password;
// confirm that we have a valid username/password
$error = array();
if (is_null($this->username)) {
$error[] = 'username';
if (is_null($this->password)) {
$error[] = 'password';
if (sizeof($error) > 0) {
throw new MyQException('Missing required auth credential: ' . implode(',', $error));
return $this->_login();
public function refresh () {
$this->_getDetails();
return $this;
public function open () {
return $this->_requestState(MYQ_DOOR_ACTION_OPEN);
public function close () {
return $this->_requestState(MYQ_DOOR_ACTION_CLOSE);
private function _requestState ($action) {
// Fetch current device information
curl_setopt($this->_conn, CURLOPT_CUSTOMREQUEST, 'PUT');
curl_setopt($this->_conn, CURLOPT_URL, $this->_baseUrl . $this->_putDeviceStateUri);
$payload = array (
'AttributeName' => 'desireddoorstate',
'AttributeValue' => $action,
'MyQDeviceId' => $this->_deviceId,
curl_setopt($this->_conn, CURLOPT_POSTFIELDS, json_encode($payload));
$output = curl_exec($this->_conn);
$err = curl_error($this->_conn);
if ($err) {
throw new MyQException("cURL Error #:" . $err);
$data = json_decode($output);
if ($data == false) {
throw new MyQException("Error updating device state: $output");
if (strlen($data->ErrorMessage) > 0 || $data->ReturnCode != 0) {
throw new MyQException("Error returned from API: " . var_export($data));
// Update was successful, fetch the new status and report
return $this->refresh();
private function _init () {
if (!isset($this->_conn)) {
$this->_conn = curl_init();
curl_setopt_array($this->_conn, array (
CURLOPT_RETURNTRANSFER => true,
CURLOPT_ENCODING => "",
CURLOPT_MAXREDIRS => 10,
CURLOPT_TIMEOUT => 30,
CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1,
CURLOPT_FAILONERROR => true,
CURLOPT_FOLLOWLOCATION => true,
CURLOPT_FRESH_CONNECT => true,
CURLOPT_FORBID_REUSE => true,
CURLOPT_USERAGENT => $this->userAgent,
$this->_setHeaders();
private function _setHeaders () {
$headers = array();
foreach ($this->_headers as $k => $v) {
$headers[] = "$k: $v";
curl_setopt($this->_conn, CURLOPT_HTTPHEADER, $headers);
private function _login () {
$this->_init();
curl_setopt($this->_conn, CURLOPT_CUSTOMREQUEST, 'POST');
curl_setopt($this->_conn, CURLOPT_URL, $this->_baseUrl . $this->_loginUri);
$post = json_encode(array('username' => $this->username, 'password' => $this->password));
curl_setopt($this->_conn, CURLOPT_POSTFIELDS, $post);
if ($data == false || !isset($data->SecurityToken)) {
throw new MyQException("Error processing login request: $output");
$this->_headers['SecurityToken'] = $data->SecurityToken;
return $this;
private function _getDetails ($getState = false, $forceUpdate = false) {
$this->_init();
// always fetch state info from API. Location data is not expected to have changed
$cachedLocation = true;
if ($getState === false && $forceUpdate !== true) {
// get the location information
// check to see if we have this information cached already
if ( $forceUpdate === false && ! (is_null($this->_doorName) || is_null($this->_locationName) ) ) {
return;
$cachedLocation = false;
curl_setopt($this->_conn, CURLOPT_CUSTOMREQUEST, 'GET');
curl_setopt($this->_conn, CURLOPT_URL, $this->_baseUrl . $this->_getDeviceDetailUri);
if ($data == false || !isset($data->Devices)) {
throw new MyQException("Error fetching device details: $output");
// Find our door device ID
// (we only look at the first listed device - later we can look for a device by name)
foreach ($data->Devices as $device) {
if ( $cachedLocation === false && stripos($device->MyQDeviceTypeName, "Gateway") !== false ) {
// Find location name
foreach ($device->Attributes as $attr) {
if ($attr->AttributeDisplayName == 'desc') {
$this->_locationName = $attr->Value;
continue; // we don't want device info on the location
// we should be looking at just our WGDO unit
$this->_deviceId = $device->MyQDeviceId;
switch ($attr->AttributeDisplayName) {
case 'desc':
$this->_doorName = $attr->Value;
break;
case 'doorstate':
$this->_doorState = new MyQState($attr->Value, $attr->UpdatedTime);
break;
default:
continue;
break; // skip any other devices
(keine Eigenentwicklung, vielen Dank an den Entwickler)
und hier der Aufruf:
//absoluter Pfad zur Klasse
require_once('C:\IP-Symcon\scripts\47161 /*[Scripte\Eigenentwicklung\Garagentor\MyQ-Class]*/.ips.php');
$door = new MyQ();
$door->login("<EMAIL>", "<Passwort>");
//Aktueller Status ermitteln
$report = function() {
global $door;
$status = "{$door->refresh()->state}";
$zeit = "{$door->state->delta}";
//Variablen für Zustand setzen
$subst = "Garagentor seit $zeit $status";
setvalue(42271 /*[Wohnung DG\Garage\Garage Status]*/,$subst);
// Current state aufruf
$report();
//Ein Beispiel Tor öffnen
$door->open();
//Ein Beispiel zum Tor schließen
$door->close = true;
Wenn man jetzt je ein Script für „open“, „close“ und „status“ (alle Sekunden ausführen) erstellt, hat man eigentlich alles was man braucht. Selbstverständlich wird der Status auch bei einem bsp… per Handsender ausgelösten öffnen aktualisiert.
Einen Bug gibt es aktuell natürlich auch.
die Zeiten beim öffnen und schließen (also nur die paar Sekunden bis das Tor in Endstellung ist) werden noch wirr dargestellt. Mich stört dies jedoch nicht, da ich nur offen, geschlossen, öffnen und schließen anzeigen / bzw. per TTS ausgeben lassen.
und das beste dran. der berühmt berüchtigte WAF kann bei der all abendlichen Ansage „Die Garagentür wird geöffnet“ gleich das kühle Blonde bereitstellen. Das schlägt wohl alle Argumente gegen Cloud und Co…
Bei Fragen, fragen.
Viel Spaß mit dem Script
Gruß Steffen
