Wie viele Variablen inkl. Kategorien hat er bei dir erstellt? Wenn ich den kompletten Baum kopiere, sind es laut Notepad++ 133 Zeilen. Also 133 Variablen/Kategorien. In der „Werteliste“ von Dir aus dem Fhem sind auch doppelte drin ist mir aufgefallen.
58571 /*[Hardware\Buderus\Heizung\/heatingCircuits]*/,
22583 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1]*/,
27073 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/switchPrograms]*/,
21905 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/switchPrograms\/heatingCircuits/hc1/switchPrograms/A (writeable)]*/,
34735 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/switchPrograms\/heatingCircuits/hc1/switchPrograms/B (writeable)]*/,
57368 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/temperatureLevels]*/,
26833 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/temperatureLevels\/heatingCircuits/hc1/temperatureLevels/comfort2 (writeable) (recordable)]*/,
51319 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/temperatureLevels\/heatingCircuits/hc1/temperatureLevels/eco (writeable) (recordable)]*/,
16305 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/activeSwitchProgram (writeable) (recordable)]*/,
40011 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/actualSupplyTemperature]*/,
31053 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/currentRoomSetpoint]*/,
18383 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/fastHeatupFactor (writeable) (recordable)]*/,
49428 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/manualRoomSetpoint (writeable) (recordable)]*/,
46676 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/operationMode (writeable) (recordable)]*/,
14870 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/pumpModulation]*/,
29868 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/roomtemperature]*/,
21717 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/switchProgramMode (writeable) (recordable)]*/,
16613 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/temperatureRoomSetpoint (writeable) (recordable)]*/,
12774 /*[Hardware\Buderus\Heizung\/heatingCircuits\/heatingCircuits/hc1\/heatingCircuits/hc1/temporaryRoomSetpoint (writeable) (recordable)]*/,
51056 /*[Hardware\Buderus\Heizung\/heatSources]*/,
30435 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/cooling]*/,
13447 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/fuelCell]*/,
18784 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/heating]*/,
18540 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/Source]*/,
34715 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/Source\/heatSources/Source/Compressor]*/,
52681 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/Source\/heatSources/Source/eHeater]*/,
54423 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/workingTime]*/,
23247 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/workingTime\/heatSources/workingTime/centralHeating]*/,
32143 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/workingTime\/heatSources/workingTime/secondBurner]*/,
14523 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/workingTime\/heatSources/workingTime/totalSystem]*/,
15581 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/actualCHPower]*/,
20011 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/actualDHWPower]*/,
21458 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/actualModulation]*/,
45670 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/actualPower]*/,
22525 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/actualSupplyTemperature]*/,
16380 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/applianceSupplyTemperature]*/,
25906 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/burnerModulationSetpoint]*/,
33762 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/burnerPowerSetpoint]*/,
59090 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/ChimneySweeper]*/,
54978 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/CHpumpModulation]*/,
41681 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/fanSpeed_setpoint]*/,
33277 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/flameCurrent]*/,
27878 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/flameStatus]*/,
35830 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/nominalCHPower]*/,
51897 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/nominalDHWPower]*/,
48070 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/numberOfStarts]*/,
10534 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/powerSetpoint]*/,
15560 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/returnTemperature]*/,
50247 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/supplyTemperatureSetpoint]*/,
58883 /*[Hardware\Buderus\Heizung\/heatSources\/heatSources/systemPressure]*/,
55239 /*[Hardware\Buderus\Heizung\/heatSources\0]*/,
59411 /*[Hardware\Buderus\Heizung\/recordings]*/,
11741 /*[Hardware\Buderus\Heizung\/recordings\/recordings/heatSources]*/,
20987 /*[Hardware\Buderus\Heizung\/recordings\/recordings/heatSources\/recordings/heatSources/hs1]*/,
11826 /*[Hardware\Buderus\Heizung\/recordings\/recordings/heatSources\0]*/,
25160 /*[Hardware\Buderus\Heizung\/recordings\/recordings/heatSources\0]*/,
58969 /*[Hardware\Buderus\Heizung\/recordings\/recordings/heatSources\0]*/,
51044 /*[Hardware\Buderus\Heizung\/recordings\/recordings/system]*/,
46666 /*[Hardware\Buderus\Heizung\/recordings\/recordings/system\/recordings/system/heatSources]*/,
53326 /*[Hardware\Buderus\Heizung\/recordings\/recordings/system\/recordings/system/heatSources\/recordings/system/heatSources/hs1]*/,
53575 /*[Hardware\Buderus\Heizung\/recordings\/recordings/system\/recordings/system/heatSources\/recordings/system/heatSources/hs1\0]*/,
45352 /*[Hardware\Buderus\Heizung\/recordings\/recordings/system\/recordings/system/sensors]*/,
49570 /*[Hardware\Buderus\Heizung\/recordings\/recordings/system\/recordings/system/sensors\/recordings/system/sensors/temperatures]*/,
36940 /*[Hardware\Buderus\Heizung\/recordings\/recordings/system\/recordings/system/sensors\/recordings/system/sensors/temperatures\0]*/,
33433 /*[Hardware\Buderus\Heizung\/system]*/,
50846 /*[Hardware\Buderus\Heizung\/system\/system/appliance]*/,
13886 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/workingTime]*/,
36690 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/workingTime\/system/appliance/workingTime/centralHeating]*/,
58031 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/workingTime\/system/appliance/workingTime/secondBurner]*/,
21883 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/workingTime\/system/appliance/workingTime/totalSystem]*/,
59455 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/actualPower]*/,
22582 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/actualSupplyTemperature]*/,
52889 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/ChimneySweeper]*/,
17697 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/CHpumpModulation]*/,
44896 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/fanSpeed_setpoint]*/,
16813 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/flameCurrent]*/,
26392 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/nominalBurnerLoad]*/,
14845 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/numberOfStarts]*/,
26521 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/powerSetpoint]*/,
16557 /*[Hardware\Buderus\Heizung\/system\/system/appliance\/system/appliance/systemPressure]*/,
52476 /*[Hardware\Buderus\Heizung\/system\/system/heatSources]*/,
28185 /*[Hardware\Buderus\Heizung\/system\/system/heatSources\/system/heatSources/hs1]*/,
48367 /*[Hardware\Buderus\Heizung\/system\/system/heatSources\/system/heatSources/hs1\/system/heatSources/hs1/energyReservoir (writeable) (recordable)]*/,
41579 /*[Hardware\Buderus\Heizung\/system\/system/sensors]*/,
36749 /*[Hardware\Buderus\Heizung\/system\/system/sensors\/system/sensors/temperatures]*/,
34273 /*[Hardware\Buderus\Heizung\/system\/system/sensors\/system/sensors/temperatures\/system/sensors/temperatures/outdoor_t1]*/,
50805 /*[Hardware\Buderus\Heizung\/system\/system/sensors\/system/sensors/temperatures\/system/sensors/temperatures/return]*/,
15306 /*[Hardware\Buderus\Heizung\/system\/system/sensors\/system/sensors/temperatures\/system/sensors/temperatures/supply_t1]*/,
52877 /*[Hardware\Buderus\Heizung\/system\/system/sensors\/system/sensors/temperatures\/system/sensors/temperatures/supply_t1_setpoint]*/,
40368 /*[Hardware\Buderus\Heizung\/system\/system/sensors\/system/sensors/temperatures\/system/sensors/temperatures/switch]*/,
36681 /*[Hardware\Buderus\Heizung\/system\/system/brand]*/,
14541 /*[Hardware\Buderus\Heizung\/system\/system/bus]*/,
47505 /*[Hardware\Buderus\Heizung\/system\/system/healthStatus]*/,
43209 /*[Hardware\Buderus\Heizung\/system\/system/minOutdoorTemp (writeable) (recordable)]*/,
46830 /*[Hardware\Buderus\Heizung\/system\/system/systemType]*/,
27882 /*[Hardware\Buderus\Heizung\/system\0]*/,
34050 /*[Hardware\Buderus\Heizung\/system/appliance]*/,
51637 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/workingTime]*/,
47150 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/workingTime\/system/appliance/workingTime/centralHeating]*/,
18414 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/workingTime\/system/appliance/workingTime/secondBurner]*/,
41546 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/workingTime\/system/appliance/workingTime/totalSystem]*/,
14367 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/actualPower]*/,
23200 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/actualSupplyTemperature]*/,
23026 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/ChimneySweeper]*/,
41700 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/CHpumpModulation]*/,
58428 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/fanSpeed_setpoint]*/,
22826 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/flameCurrent]*/,
35823 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/nominalBurnerLoad]*/,
55159 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/numberOfStarts]*/,
29554 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/powerSetpoint]*/,
52468 /*[Hardware\Buderus\Heizung\/system/appliance\/system/appliance/systemPressure]*/,
55686 /*[Hardware\Buderus\Heizung\/system/appliance/workingTime]*/,
16744 /*[Hardware\Buderus\Heizung\/system/appliance/workingTime\/system/appliance/workingTime/centralHeating]*/,
39672 /*[Hardware\Buderus\Heizung\/system/appliance/workingTime\/system/appliance/workingTime/secondBurner]*/,
45872 /*[Hardware\Buderus\Heizung\/system/appliance/workingTime\/system/appliance/workingTime/totalSystem]*/,
41621 /*[Hardware\Buderus\Heizung\/system/heatSources/hs1]*/,
20767 /*[Hardware\Buderus\Heizung\/system/heatSources/hs1\/system/heatSources/hs1/energyReservoir (writeable) (recordable)]*/,
28598 /*[Hardware\Buderus\Heizung\/system/heatSources/hs1\/system/heatSources/hs1/reservoirAlert (writeable) (recordable)]*/,
14691 /*[Hardware\Buderus\Heizung\/gateway/DateTime (writeable) (recordable)]*/,
31738 /*[Hardware\Buderus\Heizung\/gateway/instAccess (writeable) (recordable)]*/,
43599 /*[Hardware\Buderus\Heizung\/gateway/uuid]*/,
54594 /*[Hardware\Buderus\Heizung\/gateway/versionFirmware]*/,
34945 /*[Hardware\Buderus\Heizung\/gateway/versionHardware]*/,
49898 /*[Hardware\Buderus\Heizung\/system/appliance/actualPower]*/,
12350 /*[Hardware\Buderus\Heizung\/system/appliance/actualSupplyTemperature]*/,
31869 /*[Hardware\Buderus\Heizung\/system/appliance/ChimneySweeper]*/,
55780 /*[Hardware\Buderus\Heizung\/system/appliance/CHpumpModulation]*/,
29653 /*[Hardware\Buderus\Heizung\/system/appliance/flameCurrent]*/,
20097 /*[Hardware\Buderus\Heizung\/system/appliance/nominalBurnerLoad]*/,
51440 /*[Hardware\Buderus\Heizung\/system/appliance/numberOfStarts]*/,
22278 /*[Hardware\Buderus\Heizung\/system/appliance/powerSetpoint]*/,
17344 /*[Hardware\Buderus\Heizung\/system/appliance/systemPressure]*/,
18192 /*[Hardware\Buderus\Heizung\0]*/
Ich hatte die Liste für mich mal bereinigt und Sortiert:
#"/gateway/uuid",
#"/gateway/DateTime",
#"/gateway/versionFirmware",
#"/gateway/versionHardware",
#"/gateway/instAccess",
#"/heatingCircuits",
#"/heatingCircuits/hc1",
#"/heatingCircuits/hc1/roomtemperature",
#"/heatingCircuits/hc1/status",
#"/heatingCircuits/hc1/currentRoomSetpoint",
#"/heatingCircuits/hc1/actualSupplyTemperature",
#"/heatingCircuits/hc1/operationMode",
#"/heatingCircuits/hc1/temperatureRoomSetpoint",
#"/heatingCircuits/hc1/manualRoomSetpoint",
#"/heatingCircuits/hc1/temporaryRoomSetpoint",
#"/heatingCircuits/hc1/activeSwitchProgram",
#"/heatingCircuits/hc1/switchPrograms",
#"/heatingCircuits/hc1/temperatureLevels",
#"/heatingCircuits/hc1/pumpModulation",
#"/heatingCircuits/hc1/suWiThreshold",
#"/heatingCircuits/hc1/designTemp",
#"/heatingCircuits/hc1/heatCurveMin",
#"/heatingCircuits/hc1/roomTempOffset",
#"/heatingCircuits/hc1/heatCurveMax",
#"/heatingCircuits/hc1/controlType",
#"/heatingCircuits/hc1/solarInfluence",
#"/heatingCircuits/hc1/roomInfluence",
#"/heatingCircuits/hc1/fastHeatupFactor",
#"/heatingCircuits/hc1/setpointOptimization",
#"/heatingCircuits/hc1/suWiSwitchMode",
##"/heatingCircuits/hc1/currentOpModeInfo",
#"/heatSources",
#"/heatSources/actualPower",
#"/heatSources/actualCHPower",
#"/heatSources/actualDHWPower",
#"/heatSources/flameStatus",
#"/heatSources/CHpumpModulation",
#"/heatSources/actualsupplytemperature",
#"/heatSources/powerSetpoint",
#"/heatSources/gasAirPressure",
#"/heatSources/systemPressure",
#"/heatSources/flameCurrent",
#"/heatSources/ChimneySweeper",
#"/heatSources/returnTemperature",
#"/heatSources/numberOfStarts",
#"/heatSources/nominalCHPower",
#"/heatSources/nominalDHWPower",
##"/heatSources/worki//ngTime",
#"/notifications",
#"/recordings",
#"/recordings/system",
#"/recordings/system/sensors",
#"/recordings/system/sensors/temperatures",
#"/recordings/system/sensors/temperatures/outdoor_t1",
#"/recordings/system/heatSources",
#"/recordings/system/heatSources/hs1",
#"/recordings/system/heatSources/hs1/actualPower",
#"/recordings/heatSources",
#"/recordings/heatSources/actualPower",
#"/recordings/heatSources/actualCHPower",
#"/recordings/heatSources/actualDHWPower",
#"/recordings/heatingCircuits",
#"/recordings/heatingCircuits/hc1",
#"/recordings/heatingCircuits/hc1/roomtemperature",
#"/solarCircuits",
#"/solarCircuits/sc1/status",
#"/solarCircuits/sc1/solarYield",
#"/solarCircuits/sc1/collectorTemperature",
##"/solarCircuits/sc1/pumpModulation",
#"/system",
#"/system/info",
#"/system/brand",
#"/system/bus",
#"/system/systemType",
#"/system/minOutdoorTemp",
#"/system/healthStatus",
#"/system/sensors",
#"/system/sensors/temperatures",
#"/system/sensors/temperatures/outdoor_t1",
#"/system/sensors/temperatures/supply_t1_setpoint",
#"/system/sensors/temperatures/supply_t1",
#"/system/sensors/temperatures/hotWater_t1",
#"/system/sensors/temperatures/hotWater_t2",
#"/system/sensors/temperatures/return",
#"/system/sensors/temperatures/switch",
#"/system/sensors/temperatures/chimney",
##"/system/sensors/temperatures/hotWater_t2",
"/system/appliance",
"/system/appliance/actualSupplyTemperature",
"/system/appliance/powerSetpoint",
"/system/appliance/actualPower",
"/system/appliance/CHpumpModulation",
"/system/appliance/numberOfStarts",
"/system/appliance/gasAirPressure",
"/system/appliance/systemPressure",
"/system/appliance/flameCurrent",
"/system/appliance/ChimneySweeper",
"/system/appliance/workingTime",
"/system/appliance/nominalBurnerLoad",
"/system/heatSources/hs1",
"/system/heatSources/hs1/energyReservoir",
"/system/heatSources/hs1/reservoirAlert",
"/system/heatSources/hs1/nominalFuelConsumption",
"/system/heatSources/hs1/fuelConsmptCorrFactor",
"/system/heatSources/hs1/actualModulation",
"/system/heatSources/hs1/actualPower",
"/system/heatSources/hs1/fuel",
"/system/heatSources/hs1/fuel/density",
