die Szenen in der Alexa-Integration benutzen jetzt auch Aktionen und ich musste die Tabelle aller Alexa Kommandos etwas anpassen. Hier die geänderte Version:
$id_alexa = 0;
$instanceList = IPS_GetInstanceList();
foreach ($instanceList as $id) {
$instance = IPS_GetInstance($id);
if ($instance['ModuleInfo']['ModuleName'] == 'Alexa'){
$id_alexa = $instance['InstanceID'];
break;
if ($id_alexa == 0) return;
$list = [];
$properties = json_decode(IPS_GetConfiguration($id_alexa), true);
foreach($properties as $name => $value) {
if (substr($name, 0, 6) == "Device") {
$devices = json_decode($value, true);
foreach($devices as $device) {
switch ($name){
case 'DeviceSimpleScene':
$SimpleScene = $device["SceneControllerSimpleAction"];
$SimpleAction = json_decode($SimpleScene, true);
$list[] = [
"Name" => $device["Name"],
"Type" => substr($name, 6),
"ID1" => $SimpleAction["parameters"]["TARGET"],
"ID2" => 0,
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
case 'DeviceDeactivatableScene':
$SceneActivate = json_decode($device["SceneControllerDeactivatableActivateAction"], true);
$SceneDeActivate = json_decode($device["SceneControllerDeactivatableDeactivateAction"], true);
$list[] = [
"ID1" => $SceneActivate["parameters"]["TARGET"],
"ID2" => $SceneDeActivate["parameters"]["TARGET"],
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
// print_r($device);
break;
case 'DeviceGenericSwitch':
$list[] = [
"ID1" => $device["PowerControllerID"],
"ID2" => 0,
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
case 'DeviceLightSwitch':
$list[] = [
"ID2" => 0,
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
case 'DeviceLightDimmer':
$list[] = [
"ID1" => $device["BrightnessControllerID"],
"ID2" => 0,
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
case 'DeviceLightExpert':
$list[] = [
"ID2" => $device["BrightnessOnlyControllerID"],
"ID3" => $device["ColorOnlyControllerID"],
"ID4" => $device["ColorTemperatureOnlyControllerID"],
"ID5" => 0
break;
case 'DeviceLock':
$list[] = [
"ID1" => $device["LockControllerID"],
"ID2" => 0,
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
case 'DeviceShutter':
$list[] = [
"ID1" => $device["RangeControllerShutterID"],
"ID2" => 0,
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
case 'DeviceSpeaker':
$list[] = [
"ID1" => $device["SpeakerID"],
"ID2" => 0,
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
case 'DeviceTemperatureSensor':
$list[] = [
"ID1" => $device["TemperatureSensorID"],
"ID2" => 0,
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
case 'DeviceGenericSlider':
$list[] = [
"ID1" => $device["PercentageControllerID"],
"ID2" => 0,
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
case 'DeviceLightColor':
$list[] = [
"ID1" => $device["ColorControllerID"],
"ID2" => 0,
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
case 'DeviceMediaPlayer':
$list[] = [
"ID2" => $device["SpeakerMuteableVolumeID"],
"ID3" => $device["SpeakerMuteableMuteID"],
"ID4" => $device["PlaybackControllerID"],
"ID5" => 0
break;
case 'DeviceSpeakerMuteable':
$list[] = [
"ID1" => $device["SpeakerMuteableVolumeID"],
"ID2" => $device["SpeakerMuteableMuteID"],
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
case 'DeviceTelevision':
$list[] = [
"ID2" => $device["ChannelControllerID"],
"ID3" => $device["SpeakerMuteableVolumeID"],
"ID4" => $device["SpeakerMuteableMuteID"],
"ID5" => $device["InputControllerID"]
break;
case 'DeviceThermostat':
$list[] = [
"ID1" => $device["ThermostatControllerID"],
"ID2" => 0,
"ID3" => 0,
"ID4" => 0,
"ID5" => 0
break;
default:
var_dump($name);
var_dump($device);
break;
$UpdateList = [];
$maxName = 0;
$maxType = 0;
$index = 0;
foreach($list as $item) {
$UpdateList[$index]['Name'] = mb_str_pad($item['Name'], $maxName, " ") ;
$UpdateList[$index]['Type'] = mb_str_pad($item['Type'], $maxType, " ");
$UpdateList[$index]['ID1'] = $item['ID1'];
$UpdateList[$index]['ID2'] = $item['ID2'];
$UpdateList[$index]['ID3'] = $item['ID3'];
$UpdateList[$index]['ID4'] = $item['ID4'];
$UpdateList[$index]['ID5'] = $item['ID5'];
$index++;
$Type = array_column($UpdateList, 'Type');
$Name = array_column($UpdateList, 'Name');
array_multisort($Type, SORT_ASC, $Name, SORT_ASC, $UpdateList);
// HTML ereugen
$HintergrundFarbcode = '000000';
$TextFarbcode = 'FFFFFF';
$TextFarbcodeNOK = 'FF0000';
$TextSize = 14;
$TextSizeTitle = $TextSize + 2;
$TextWeight = 'normal';
$Textausrichtung = 'text-align:left;';
$HTML_CSS_Style = '<style type="text/css">
.bt {border-collapse: separate;border-spacing: 2px;}
.bt td {font-family:Arial, sans-serif;font-size:' . $TextSize . 'px;color:#' . $TextFarbcode . ';' . $Textausrichtung . 'padding:1px 10px;border-style:solid;border-width:1px;overfNOK:hidden;word-break:normal;}
.bt th {font-family:Arial, sans-serif;font-size:' . $TextSize . 'px;color:#' . $TextFarbcode . ';' . $Textausrichtung . 'padding:1px 10px;border-style:solid;border-width:1px;overfNOK:hidden;word-break:normal;}
.bt .tb-title {font-size:' . $TextSizeTitle . 'px;padding:2mm;' . $Textausrichtung . 'background-color:#' . $HintergrundFarbcode . ';color:#' . $TextFarbcode . '}
.bt .tb-content {font-size:' . $TextSize . 'px;font-weight: ' . $TextWeight . ';padding:1mm;' . $Textausrichtung . 'background-color:#' . $HintergrundFarbcode . ';color:#' . $TextFarbcode . '}
.bt .tb-contentNOK {font-size:' . $TextSize . 'px;font-weight: ' . $TextWeight . ';padding:1mm;' . $Textausrichtung . 'background-color:#' . $HintergrundFarbcode . ';color:#' . $TextFarbcodeNOK . '}
</style>';
$HTML = '<html>' . $HTML_CSS_Style;
$HTML .= '<table class="bt"';
$Titel = array();
$Titel = array('Nummer');
$Titel[] = 'Name';
$Titel[] = 'Typ';
$Titel[] = 'ID1';
$Titel[] = 'ID2';
$Titel[] = 'ID3';
$Titel[] = 'ID4';
$Titel[] = 'ID5';
$HTML .= '<tr>';
$colspan = 1;
foreach ($Titel as $TitelEntry) {
$HTML .= '<th class="tb-title"><b>' . $TitelEntry . '</b></th>';
$colspan++;
$HTML .= '</tr><tr>';
$index = 0;
foreach ($UpdateList as $Update) {
$index++;
$HTML .= '<th class="tb-content">' . $index . '</th>';
$HTML .= '<th class="tb-content">' . $Update['Name'] . '</th>';
$HTML .= '<th class="tb-content">' . $Update['Type'] . '</th>';
if ($Update['ID1'] > 0){
if (IPS_ObjectExists($Update['ID1'])){
$IDName = IPS_GetName($Update['ID1']);
$HTML .= '<th class="tb-content">' . $Update['ID1'] . ':' . $IDName . '</th>';
else{
$HTML .= '<th class="tb-contentNOK">' . $Update['ID1'] . ':</th>';
else{
$HTML .= '<th class="tb-contentL"> </th>';
if ($Update['ID2'] > 0){
if (IPS_ObjectExists($Update['ID2'])){
$IDName = IPS_GetName($Update['ID2']);
$HTML .= '<th class="tb-content">' . $Update['ID2'] . ':' . $IDName . '</th>';
else{
$HTML .= '<th class="tb-contentNOK">' . $Update['ID2'] . ':</th>';
else{
if ($Update['ID3'] > 0){
if (IPS_ObjectExists($Update['ID3'])){
$IDName = IPS_GetName($Update['ID3']);
$HTML .= '<th class="tb-content">' . $Update['ID3'] . ':' . $IDName . '</th>';
else{
$HTML .= '<th class="tb-contentNOK">' . $Update['ID3'] . ':</th>';
else{
if ($Update['ID4'] > 0){
if (IPS_ObjectExists($Update['ID4'])){
$IDName = IPS_GetName($Update['ID4']);
$HTML .= '<th class="tb-content">' . $Update['ID4'] . ':' . $IDName . '</th>';
else{
$HTML .= '<th class="tb-contentNOK">' . $Update['ID4'] . ':</th>';
else{
if ($Update['ID5'] > 0){
if (IPS_ObjectExists($Update['ID5'])){
$IDName = IPS_GetName($Update['ID5']);
$HTML .= '<th class="tb-content">' . $Update['ID5'] . ':' . $IDName . '</th>';
else{
$HTML .= '<th class="tb-contentNOK">' . $Update['ID5'] . ':</th>';
else{
$HTML .= '</tr>';
$HTML .= '</table></html>';
$vid = @IPS_GetVariableIDByName("Alexa Kommandos", $_IPS['SELF']);
if ($vid == false){
$vid = IPS_CreateVariable(3);
IPS_SetParent($vid, $_IPS['SELF']); //Variable zuordnen
IPS_SetName($vid, "Alexa Kommandos");
IPS_SetVariableCustomProfile($vid, "~HTMLBox");
SetValue( $vid, $HTML);
function mb_str_pad( $input, $pad_length, $pad_string = ' ', $pad_type = STR_PAD_RIGHT)
$diff = strlen( $input ) - mb_strlen( $input );
return str_pad( $input, $pad_length + $diff, $pad_string, $pad_type );
Falls es noch weitere Änderungen gab bitte melden.
Ralf
