Guten Morgen zusammen,
nachdem heute morgen die Rollladen nicht öffneten, war mir klar, dass Symcon wieder hängt.
Aber nun habe ich einen Backtrace, mit dem Paresy hoffentlich etwas mehr anfangen kann als ich…
(gdb) bt
#0 0x005ae570 in boost::asio::detail::epoll_reactor::start_op(int, int, boost::asio::detail::epoll_reactor::descriptor_state*&, boost::asio::detail::reactor_op*, bool, bool) ()
#1 0x005afa1c in boost::asio::detail::write_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> >, boost::asio::const_buffers_1, boost::asio::detail::transfer_all_t, boost::_bi::bind_t<void, boost::_mfi::mf2<void, IOClientSocket, std::shared_ptr<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, boost::system::error_code const&>, boost::_bi::list3<boost::_bi::value<IOClientSocket*>, boost::_bi::value<std::shared_ptr<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, boost::arg<1> (*)()> > >::operator()(boost::system::error_code const&, unsigned int, int) ()
#2 0x005ad980 in IOClientSocket::startWriting(std::shared_ptr<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >) ()
#3 0x005aecb8 in boost::asio::detail::completion_handler<boost::_bi::bind_t<void, boost::_mfi::mf1<void, IOClientSocket, std::shared_ptr<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >, boost::_bi::list2<boost::_bi::value<IOClientSocket*>, boost::_bi::value<std::shared_ptr<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > >::do_complete(boost::asio::detail::task_io_service*, boost::asio::detail::task_io_service_operation*, boost::system::error_code const&, unsigned int) ()
#4 0x005a9668 in std::thread::_State_impl<std::_Bind_simple<IOClientSocket::Connect()::{lambda()#2} ()> >::_M_run() ()
#5 0x7674e9dc in ?? () from /usr/lib/arm-linux-gnueabihf/libstdc++.so.6
#6 0x76f95fc4 in start_thread (arg=0x5d9ff430) at pthread_create.c:335
Backtrace stopped: Cannot access memory at address 0x14fcb312
Falls Du/Ihr noch mehr Informationen benötigt, einfach fragen ![:slight_smile: :slight_smile:](https://community.symcon.de/images/emoji/win10/slight_smile.png?v=9)
Gruss aus EU,
Jörg
