Hallo paresy,
dieses Script führt zum Absturz von Symcon.
//ID der I/O Instanz vom Chromoflex RC III.
//Konfiguration: 115200, 8, 1, N
$id = 32594 /*[Chromoflex COM]*/; //I/O Instanz
Copyright 2012, IP-Symcon/meike0_0. Version 1.2.0 - DO NOT MODIFY BELOW THIS LINE!
if($_IPS['SENDER'] == "RunScript")
if(isset($_IPS['Action']))
switch($_IPS['Action'])
case "Initialize":
Initialize();
break;
case "SetColor":
if(!isset($_IPS['Net']))
$_IPS['Net'] = 8;
if(!isset($_IPS['DeviceID']))
$_IPS['DeviceID'] = "000000";
if(!isset($_IPS['R']))
$_IPS['R'] = 0xFF;
if(!isset($_IPS['G']))
$_IPS['G'] = 0xFF;
if(!isset($_IPS['B']))
$_IPS['B'] = 0xFF;
if(!isset($_IPS['D']))
$_IPS['D'] = 0xFF;
if(IPS_SemaphoreEnter($_IPS['SELF'],5000)){}else
$x = "";
$x .= chr($_IPS['Net']); //Network
$x .= HexToStr($_IPS['DeviceID']); //Remote Serial
$x .= chr(GetSequenceNumber());
$x .= chr(0xFF).chr(0xFF).chr(0xFE); //PC Serial
$x .= chr(0x80); //Command: Write
$x .= chr(0x01); //RAM Adress (???)
$x .= chr(0x12); //ProgramPC (???)
$x .= chr(max(1, $_IPS['D'])); //Dimmer (0 = ON, 1 = 0%, 255 = 100%)
$x .= chr(0x00); //Index (???)
$x .= chr(0x01); //Dummy (???)
$x .= chr(0xFF); //Temp (???)
$x .= chr($_IPS['R']); //Red
$x .= chr($_IPS['G']); //Green
$x .= chr($_IPS['B']); //Blue
SPRT_SendText($id, CreatePacket($x));
IPS_Sleep(100);
IPS_SemaphoreLeave($_IPS['SELF']);
break;
case "SetProgram":
$_IPS['Net'] = 8;
if(!isset($_IPS['P']))
$_IPS['P'] = 0;
// if(!isset($_IPS['D']))
// $_IPS['D'] = 0xFF;
switch ($_IPS['P'])
case 0: //Aus
case 1: //Speichern&Aus
case 2: //Fix Color
case 3: //Color Change
case 4: //Med.Color
case 5: //Slow.Color
case 6: //Blob
case 7: //LSD
case 8: //Fire
case 9: //Flashes
case 10: //Bursts
case 11: //User 1
case 12: //User 2
case 13: //User 3
case 14: //Slow Strobo
case 15: //Strobo
case 16: //Fast Strobo
case 17: //Mix
case 18: //Color
$x = "";
// $x .= chr(max(1, $_IPS['D'])); //Dimmer (0 = ON, 1 = 0%, 255 = 100%)
$x .= chr(0x80); //Index (???)
$x .= chr($_IPS['P']); //Temp (???)
$x .= chr(0x00); //Temp (???)
break;
IPS_Sleep(100);
break;
if($_IPS['SENDER'] == "Execute")
Initialize();
IPS_Sleep(200);
IPS_RunScriptEx($_IPS['SELF'], Array("Action"=>"SetColor", "R"=> rand(0, 255), "G" => rand(0, 255), "B" => rand(0, 255)));
function Initialize()
global $id;
SPRT_SetDTR($id, true);
SPRT_SetRTS($id, true);
SPRT_SendText($id, "!n0701\r");
function GetSequenceNumber()
//32-47 Sequence Number (0..15 + 32)
$seq_id = 25812 /*[Objekt #25812 existiert nicht]*/;//CreateVariableByIdent($_IPS['SELF'], "SequenceNumber", "Sequence Number", 1);
$seq = GetValue($seq_id);
$seq = ($seq+1) % 16;
SetValue($seq_id, $seq);
return $seq + 32;
function CreateVariableByIdent($id, $ident, $name, $type)
$vid = @IPS_GetObjectIDByIdent($ident, $id);
if($vid === false)
IPS_SetParent($vid, $id);
IPS_SetName($vid, $name);
IPS_SetIdent($vid, $ident);
IPS_SetInfo($vid, "this variable was created by script #".$_IPS['SELF']);
return $vid;
function CreatePacket($data)
return "!x0000".StrToHex(Chr(strlen($data)+2)).StrToHex($data).StrToHex(MakeCRC($data))."\r\r";
function MakeCRC($data)
// Fast generation of CRC by using a table...
$CRC_TABLE_A = Array(
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
$CRC_TABLE_B = Array(
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
0x43, 0x83, 0x41, 0x81, 0x80, 0x40
$CRC_A = 0xFF;
$CRC_B = 0xFF;
for($i=0; $i<strlen($data); $i++)
$INDEX = $CRC_A ^ Ord($data{$i});
$CRC_A = $CRC_TABLE_A[$INDEX] ^ $CRC_B;
$CRC_B = $CRC_TABLE_B[$INDEX];
return Chr($CRC_B) . Chr($CRC_A);
//Copy&Paste from php.net (http://php.net/manual/de/function.hexdec.php)
function StrToHex($x) {
$s = '';
$p = str_split($x);
foreach($p as $c)
$s .= strtolower(sprintf("%02X",ord($c)));
return($s);
function HexToStr($x) {
$s = '';
$p = explode("
",trim(chunk_split($x,2)));
foreach($p as $h)
$s .= chr(hexdec($h));
return($s);
Hilft das evtl. weiter?
Oli
