Heute Nacht kam es zu einem Absturz, anbei der GDB Trace
03:59:30 | 33787 | VariableManager | [Common\Philips Hue\Lampen\Budda\Zustand] = false
03:59:30 | 28620 | VariableManager | [Common\Philips Hue\Lampen\Budda\Helligkeit] = 100
03:59:30 | 29222 | ScriptEngine | Executed Event 29222 ~ Sender: TimerEvent
[New Thread 0x64dff440 (LWP 21060)]
[New Thread 0x6cfff440 (LWP 21061)]
03:59:41 | 23317 | Connect Control | Einstellungen gespeichert
03:59:41 | 23317 | Connect Control | Warte auf Beendigung des Dispatch Thread...
[New Thread 0x655ff440 (LWP 21062)]
[New Thread 0x65dff440 (LWP 21063)]
03:59:41 | 23317 | Event Control | Wiederverbinden [Connect] erfolgreich
03:59:41 | 23317 | Connect Control | Verbinde...
[New Thread 0x645ff440 (LWP 21064)]
terminate called without an active exception
Program received signal SIGABRT, Aborted.
[Switching to Thread 0x655ff440 (LWP 21062)]
0x769248dc in __GI_raise (sig=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:67
67 ../nptl/sysdeps/unix/sysv/linux/raise.c: Datei oder Verzeichnis nicht gefunden.
(gdb) bt
#0 0x769248dc in __GI_raise (sig=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:67
#1 0x7692865c in __GI_abort () at abort.c:92
#2 0x76ac0164 in __gnu_cxx::__verbose_terminate_handler() () from /usr/lib/arm-linux-gnueabihf/libstdc++.so.6
#3 0x76abdfb0 in ?? () from /usr/lib/arm-linux-gnueabihf/libstdc++.so.6
Cannot access memory at address 0x6ad6
#4 0x76abdfb0 in ?? () from /usr/lib/arm-linux-gnueabihf/libstdc++.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
(gdb)
