I did find a module for the em1010, which apparently is compatible with the conrad 3000 version. The module is written by Thomas Dreßler and found http://www.tdressler.net/ipsymcon/em1010.html.
The module is supposed to work on version 2, there are install instructions stating to copy dll’s in folder modules. This folder is not longer used in version 2.
According to the documentation all dll’s are now in IPS.exe so does this mean that no external modules are supported any longer?
Would this also imply that the SDK no longer supports building dll modules for the 2.x version?
