seit dem letzten Update habe ich sehr oft folgende Fehlermeldung:
9/18/2006 23:40:38.168 | DEBUG | ExecuteThread ID: 1348 | Executing Script: RST_ROOT.ips.php ~ Sender: TimerEvent
9/18/2006 23:40:38.178 | ERROR | ExecuteThread ID: 1348 | ScriptError: RST_ROOT.ips.php ~ Sender: TimerEvent ~ Result: <br />
<b>Fatal error</b>: Call to undefined function GetValueInteger() in <b>C:\IP-Symcon\scripts\RST_ROOT.ips.php</b> on line <b>10</b><br />
9/18/2006 23:40:38.178 | DEBUG | ExecuteThread ID: 1348 | Execution Result: <br />
9/18/2006 23:40:38.178 | DEBUG | ExecuteThread ID: 1348 | Executed, Ret: 0, Successful:False
und dann geht es so weiter:
9/18/2006 23:42:08.398 | WARNING | ExecuteThread ID: 1348 | Error executing Script: Access violation at address 100B493A in module ‚php5ts.dll‘. Write of address 0000000D
9/18/2006 23:42:08.398 | ERROR | ExecuteThread ID: 1348 | ScriptError: RST_ROOT.ips.php ~ Sender: TimerEvent ~ Result:
9/18/2006 23:42:08.398 | DEBUG | ExecuteThread ID: 1348 | Execution Result:
9/18/2006 23:42:08.398 | DEBUG | ExecuteThread ID: 1348 | Executed, Ret: -1, Successful:False
9/18/2006 23:42:18.422 | DEBUG | ExecuteThread ID: 1348 | Executing Script: RST_ROOT.ips.php ~ Sender: TimerEvent
9/18/2006 23:42:18.422 | WARNING | ExecuteThread ID: 1348 | Error executing Script: Access violation at address 100B493A in module ‚php5ts.dll‘. Write of address 0000000D
9/18/2006 23:42:18.422 | ERROR | ExecuteThread ID: 1348 | ScriptError: RST_ROOT.ips.php ~ Sender: TimerEvent ~ Result:
9/18/2006 23:42:18.422 | DEBUG | ExecuteThread ID: 1348 | Execution Result:
9/18/2006 23:42:18.422 | DEBUG | ExecuteThread ID: 1348 | Executed, Ret: -1, Successful:False
9/18/2006 23:42:27.125 | DEBUG | ExecuteThread ID: 276 | Executing Script: FHT_ROOT.ips.php ~ Sender: TimerEvent
9/18/2006 23:42:27.125 | DEBUG | ExecuteThread ID: 1348 | Executing Script: ACTUAL_TIME.ips.php ~ Sender: TimerEvent
9/18/2006 23:42:27.125 | WARNING | ExecuteThread ID: 1348 | Error executing Script: Access violation at address 100B493A in module ‚php5ts.dll‘. Write of address 0000000D
9/18/2006 23:42:27.125 | ERROR | ExecuteThread ID: 1348 | ScriptError: ACTUAL_TIME.ips.php ~ Sender: TimerEvent ~ Result:
9/18/2006 23:42:27.125 | DEBUG | ExecuteThread ID: 1348 | Execution Result:
9/18/2006 23:42:27.125 | DEBUG | ExecuteThread ID: 1348 | Executed, Ret: -1, Successful:False
9/18/2006 23:42:27.125 | DEBUG | ExecuteThread ID: 1348 | Executing Script: SET_DAY_STATUS.ips.php ~ Sender: TimerEvent
9/18/2006 23:42:27.125 | ERROR | ExecuteThread ID: 1348 | ScriptError: SET_DAY_STATUS.ips.php ~ Sender: TimerEvent ~ Result:
9/18/2006 23:42:27.145 | DEBUG | Settings | Error Saving Settings…
9/18/2006 23:42:27.205 | DEBUG | Settings | Error writeing Settings…
9/18/2006 23:42:28.427 | DEBUG | ExecuteThread ID: 1348 | Executing Script: RST_ROOT.ips.php ~ Sender: TimerEvent
9/18/2006 23:42:28.427 | WARNING | ExecuteThread ID: 1348 | Error executing Script: Access violation at address 100B493A in module ‚php5ts.dll‘. Write of address 0000000D
Und da diese Zeile alle 10 Sekunden aufgerufen wird, funktionniert eigentlich nichts mehr ! Dann muss ich IPS neu starten und dann hoffentlich klappt es beim nächsten Versuch !
mfG Franz
