Hallo paresy,
so, hatte vorhin gdb angeschmissen. Innerhalb von Minuten ist das System abgeschmiert. Murphy? Ich hab mal Logs und gdb.txt angehängt. Ich hätte das vorhin nicht schreiben sollen…
Komischerweise ist da wohl das ownet Skript wieder beteiligt,. Siehe auch in der IPSLogger.xxx.xml. Der Fehler ist genau bei den socket_XX Befehlen aufgetaucht.
Werde mal weiter gdb mitlaufen lassen. Mal schauen, ob da noch was kommt.
Anbei nochmal die ownet.php:
// Anmerkung: Apassungen für IPSymcon
// zuletzt geprüft 2017-01-28
VERSION: 2007.01.11 - 17:05 BRST
Copyright (c) 2007 Spadim Technology / Brazil. All rights reserved.
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or (at
your option) any later version.
This program is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
OWFS is an open source project developed by Paul Alfille and hosted at
http://www.owfs.org
mailto:roberto@spadim.com.br
www.spadim.com.br
from php.net
pack($format, ... )
format='i' : signed integer (machine dependent size and byte order)
we will have problems with 64bits ?? using this-> pack / unpack builtin function
from linux sources
#include <arpa/inet.h>
uint32_t (pack format = 'N')
htonl(uint32_t hostlong);
uint16_t (pack format = 'n')
htons(uint16_t hostshort);
uint32_t (pack format = 'n')
ntohl(uint32_t netlong);
ntohs(uint16_t netshort);
from http://www.linuxjournal.com/article/6788
IP's byte order also is big endian.
// Constants for the OWNet class
define('OWNET_DEFAULT_HOST' ,'127.0.0.1');
define('OWNET_DEFAULT_PORT' ,4304);
define('OWNET_LINK_TYPE_SOCKET' ,0);
define('OWNET_LINK_TYPE_STREAM' ,1);
define('OWNET_LINK_TYPE_TCP' ,0);
define('OWNET_LINK_TYPE_UDP' ,1);
Constants for the owserver api message types. from ow.h
enum msg_classification {
msg_error,
msg_nop,
msg_read,
msg_write,
msg_dir,
msg_size, // No longer used, leave here to compatibility
msg_presence,
define('OWNET_MSG_ERROR' ,0);
define('OWNET_MSG_NOP' ,1);
define('OWNET_MSG_READ' ,2);
define('OWNET_MSG_WRITE' ,3);
define('OWNET_MSG_DIR' ,4);
define('OWNET_MSG_SIZE' ,5);
define('OWNET_MSG_PRESENCE' ,6);
define('OWNET_MSG_DIR_ALL' ,7);
define('OWNET_MSG_READ_ANY' ,99999);
if (!defined('TCP_NODELAY'))
define('TCP_NODELAY',1);
if (!defined('IPPROTO_TCP'))
define('IPPROTO_TCP',6);
$OWNET_GLOBAL_CACHE_STRUCTURE=array(); // cache value types length read write....
class OWNet{
protected $link=0;
protected $host='';
protected $port=0;
protected $sock_type=OWNET_LINK_TYPE_TCP;
protected $link_type=OWNET_LINK_TYPE_SOCKET;
protected $link_connected=false;
protected $timeout=0;
protected $use_swig_dir=true;
function __construct($host='',$timeout=5,$use_swig_dir=true){
// just set default configurations
$this->setHost($host);
$this->timeout=abs((double)$timeout);
$this->use_swig_dir=(bool)$use_swig_dir;
function setTimeout($timeout=5){
function getTimeout(){
return($this->timeout);
function setUseSwigDir($use){
$this->use_swig_dir=(bool)$use;
function getUseSwigDir(){
return($this->use_swig_dir);
function setHost($host=''){
// host must be "anything://host:port" or "anything://host" OR 'anything that don't parse_url and get default values'
// use "stream://host:port" or "ow-stream://host:port" to prefer stream instead sockets
$tmp_path =@parse_url($host); // get URL information from host
if (!isset($tmp_path['scheme']))
$tmp_path =@parse_url("tcp://$host");
$this->host = (!isset($tmp_path['host'])?OWNET_DEFAULT_HOST:$tmp_path['host']); // if don't have host get default host
$this->port =(int) (!isset($tmp_path['port'])?OWNET_DEFAULT_PORT:$tmp_path['port']); // if don't have port get default port
$prefer_sock =(isset($tmp_path['scheme'])?
($tmp_path['scheme']!='stream' && $tmp_path['scheme']!='ow-stream' &&
$tmp_path['scheme']!='stream-udp' && $tmp_path['scheme']!='ow-stream-udp')
:true); // check if prefer using streams instead socket
if (strpos($tmp_path['scheme'],'udp')!==false)
$this->sock_type=OWNET_LINK_TYPE_UDP;
else
$this->sock_type=OWNET_LINK_TYPE_TCP;
unset($tmp_path);
if (function_exists('socket_connect') && $prefer_sock){
$this->link_type=OWNET_LINK_TYPE_SOCKET; // prefer socks
}else{
$this->link_type=OWNET_LINK_TYPE_STREAM; // prefer stream
$this->link_connected =false;
return(true);
function getHost(){
// return and URI that can be used with setHost again
if ($this->link_type==OWNET_LINK_TYPE_STREAM)
return('ow-stream'.($this->sock_type==OWNET_LINK_TYPE_UDP?'-udp':'').'://'.$this->host.':'.$this->port); // using streams
return('ow'.($this->sock_type==OWNET_LINK_TYPE_UDP?'-udp':'').'://'.$this->host.':'.$this->port); // using sockets if possible
protected function pack_htonl( $val ){
// builtin function to use htonl, big endian style
$bval =str_pad(decbin(bcadd($val,0,0)),8*4,'0',STR_PAD_LEFT);
$b1 =bindec(substr($bval,0,8));
$b2 =bindec(substr($bval,8,8));
$b3 =bindec(substr($bval,16,8));
$b4 =bindec(substr($bval,24,8));
return(chr($b1).chr($b2).chr($b3).chr($b4));
protected function unpack_ntohl($str){
// builtin function to use ntohl, big endian style, not shure if it's right
$size=strlen($str)/4;
$ret=array();
for($i=0;$i<$size;$i++){
$bval =substr($str,$i*4,4);
$b1 =ord(substr($bval,0,1));
$b2 =ord(substr($bval,1,1));
$b3 =ord(substr($bval,2,1));
$b4 =ord(substr($bval,3,1));
$value =$b4 + ($b3<<8) + ($b2<<16) + ($b1<<24);
$ret[$i]=$value;
return($ret);
private function disconnect(){
// disconnect link
if ($this->link_type==OWNET_LINK_TYPE_SOCKET){ // socket
@socket_set_block($this->link);
if ($this->sock_type==OWNET_LINK_TYPE_TCP)
@socket_shutdown($this->link,2);
@socket_close($this->link);
}else{
@fclose($this->link); // streams
$this->link=NULL;
$this->link_connected=false;
private function connect(){
// connect with sockets or stream
if ($this->link_connected)
return(true); // if connected don't continue
if ($this->sock_type==OWNET_LINK_TYPE_TCP){
$this->link=@socket_create(AF_INET, SOCK_STREAM, SOL_TCP); // create socket
if ($this->link){
@socket_set_block($this->link); // set it to blocking
$ok=@socket_connect($this->link,$this->host,$this->port); // try to connect
if (!$ok){
$errno =@socket_last_error(); // get error when connecting
$errstr =@socket_strerror(socket_last_error());
trigger_error("Can't create socket [ow://".$this->host.":".$this->port."], errno: $errno, error: $errstr",E_USER_NOTICE);
@socket_shutdown($this->link,2); // unload socket
$this->link=NULL;
return(false); // return false on error or can't connect
} // socket created and connected
}else{
$errno =@socket_last_error(); // get error when creating socket
$errstr =@socket_strerror(@socket_last_error());
}else{ // udp
$this->link=@socket_create(AF_INET, SOCK_DGRAM, SOL_UDP); // create socket
if ($this->link){
}else{
trigger_error("Can't create socket [ow-udp://".$this->host.":".$this->port."], errno: $errno, error: $errstr",E_USER_NOTICE);
}else{ // stream
$this->link =@stream_socket_client(
($this->sock_type==OWNET_LINK_TYPE_TCP?'tcp://':'udp://').
$this->host.":".$this->port, $errno, $errstr, $this->timeout); // connect with streams, could be with fsockopen but stream_socket_client is faster (we will use PHP 5+)
if (!$this->link){
trigger_error("Can't create stream [ow-stream".($this->sock_type!=OWNET_LINK_TYPE_TCP?'-udp':'')."://".$this->host.":".$this->port."], errno: $errno, error: $errstr",E_USER_NOTICE);
$this->set_link_options(); // set socket options or stream options
$this->link_connected=true;
return(true); // ok
private function set_link_options(){
// set link options
if (!$this->link_connected)
return(false);
socket_set_block( $this->link); // set blocking mode
socket_set_option( $this->link,SOL_SOCKET, SO_RCVTIMEO, array("sec"=>0, "usec"=>100)); // receive timeout
socket_set_option( $this->link,SOL_SOCKET, SO_SNDTIMEO, array("sec"=>0, "usec"=>100)); // send timeout
socket_set_option($this->link, SOL_SOCKET, SO_REUSEADDR, 1); // reuse address
socket_set_option($this->link, SOL_SOCKET, SO_OOBINLINE, 1); // out off band inline
@socket_set_option($this->link, IPPROTO_TCP, TCP_NODELAY, 1); // no delay can have bug with windows?!
socket_set_option($this->link, SOL_SOCKET, SO_RCVBUF, 8192); // set receive buffer
socket_set_option($this->link, SOL_SOCKET, SO_SNDBUF, 8192); // set send buffer
}else{
stream_set_timeout($this->link ,20); // set timeout
stream_set_blocking($this->link ,1); // set blocking mode
stream_set_write_buffer($this->link ,0); // flush everything directly without buffer (faster than with buffer=8192)
return(true);
private function get_msg($msg_size=24){ // return false on error
// get messagem from server
$num_changed_sockets =0;
$read_data ='';
$last_read =microtime(1);
$t1=intval($this->timeout);
$t2=($this->timeout*1000000)%1000000;
while ($num_changed_sockets<=0){ // can loop forever? owserver must send something! or disconnect!
$read=array($this->link);
$write = NULL;
$except = NULL;
$num_changed_sockets = socket_select($read, $write, $except, $t1,$t2); // use socket_select
else
$num_changed_sockets = stream_select($read, $write, $except, $t1,$t2); // use stream_select
if ($num_changed_sockets===false){ // error handling select
$this->disconnect();
trigger_error("Error handling get_msg#1",E_USER_NOTICE);
return(false); // return false when have error
}elseif($num_changed_sockets>0){ // we can read!
$read_data=socket_read($this->link,$msg_size,PHP_BINARY_READ); // read with sockets
}else{
$ret=socket_recvfrom($this->link,$read_data,$msg_size,$tmp_host,$tmp_port); // read with sockets
if ($ret>0){
$this->host=$tmp_host;
$this->port=$tmp_port;
}else
$read_data=fread($this->link,$msg_size); // read with streams
if ($read_data==''){ // disconnected :'(
trigger_error("Disconnected",E_USER_NOTICE);
}else
break;
}else
break;
if (microtime(1)-$last_read>$this->timeout)
break;
return($read_data); // return data
private function send_msg($string){ // return false on error and true on success, trigger error on disconnection
// send message to server
return(false);
$num_changed_sockets=0;
$write=array($this->link);
$v4 = 0;
$v5 = 1000;
$read = NULL;
$except = NULL;
// $num_changed_sockets = socket_select($read = NULL, $write , $except = NULL, 0,1000); // use socket_select
$num_changed_sockets = socket_select($read, $write , $except, $v4, $v5); // use socket_select
else
// $num_changed_sockets = stream_select($read = NULL, $write , $except = NULL, 0,1000); // use stream_select
$num_changed_sockets = stream_select($read, $write , $except, $v4, $v5); // use stream_select
trigger_error("Error handling send_msg#1",E_USER_NOTICE);
$size=strlen($string);
$sent=0;
while($sent<$size){
// we will not use select, using can be slower, and without work! :D
$ret=socket_write($this->link, $string, strlen($string)); // write and get sent bytes
else
$ret=socket_sendto($this->link, $string, strlen($string),0,$this->host,$this->port); // write and get sent bytes
}else
$ret=fwrite($this->link,$string,strlen($string)); // write and get sent bytes
if ($ret===false){
// error sending
trigger_error("Error writing send_msg#1",E_USER_NOTICE);
$sent+=$ret; // add sent bytes
return(true); // ok everything sent
function read($path,$parse_value=true){
// return NULL on error or no file
// if $parse_value return php parsed value type (boolean,double,string), if not return an string value
return($this->get($path,OWNET_MSG_READ,false,$parse_value)); // return get with right flags
function dir($path){
// return NULL on error or no directory
// return numeric array starting from 0 with directory list
return($this->get($path,OWNET_MSG_DIR_ALL,false,false)); // return get with right flags
function presence($path){
// return true or false on success
return($this->get($path,OWNET_MSG_PRESENCE,false,false)); // return get with right flags
function get($path='/',$get_type=OWNET_MSG_READ,$return_full_info_array=false,$parse_php_type=true){ // return NULL on error
// path = path of file or directory
// get_type = OWNET_MSG_READ_ANY (READ AND DIR)
// OWNET_MSG_READ read an file
// OWNET_MSG_DIR or OWNET_MSG_DIR_ALL read an directory (output is an array)
// OWNET_MSG_PRESENCE check presence output is true or false
// return_full_info_array if true return everything from comunication and unit if variables is an temperature, ['data'] is returned data and ['data_php'] is an parsed data in (double) or (string) types
// parse_php_type if true try to get right data_php variable type
// return NULL on error or not founded
// return an array on OWNET_MSG_DIR or when return_full_info_array=true
// return true or false when OWNET_MSG_PRESENCE
$path=trim($path); // trim path
if ($get_type==OWNET_MSG_READ_ANY){
// getting first read
$ret=$this->get($path,OWNET_MSG_READ,$return_full_info_array,$parse_php_type);
if ($ret!==NULL)
return($ret); // ok we get and result
return($this->get($path,OWNET_MSG_DIR_ALL,$return_full_info_array,$parse_php_type)); // return dir
if ($get_type!=OWNET_MSG_DIR && $get_type!=OWNET_MSG_DIR_ALL){
if (substr($path,strlen($path)-1,1)=='/') // isn't a dir, dir must end with characters != '/'
return(NULL);
$this->disconnect(); // be sure that we are disconnected
$this->connect(); // try to connect
if (!$this->link_connected){
trigger_error("Can't connect get#1",E_USER_NOTICE);
return(NULL);
// get value
if ($get_type==OWNET_MSG_DIR || $get_type==OWNET_MSG_DIR_ALL){ // get right send function
$msg=$this->pack($get_type ,strlen($path)+1,0 );
}elseif ($get_type==OWNET_MSG_PRESENCE){
$msg=$this->pack(OWNET_MSG_PRESENCE ,strlen($path)+1,0 );
}else{
$get_type=OWNET_MSG_READ;
$msg=$this->pack(OWNET_MSG_READ ,strlen($path)+1,8192 );
if ( $this->send_msg($msg)===false ){
trigger_error("Can't write to resource get#1",E_USER_NOTICE);
return(NULL); // error sending
if ( $this->send_msg($path.chr(0))===false){
trigger_error("Can't write to resource get#2",E_USER_NOTICE);
if ($parse_php_type)
global $OWNET_GLOBAL_CACHE_STRUCTURE; // we will use for parse_php_type
// get return
$return=NULL; // set to NULL if nothing returned
while(1){
unset($ret,$data,$tmp_ret,$start,$data_len);
$data='';$tmp_ret='';
$start=microtime(1);
while(1){
$tmp_ret=$this->get_msg(24);
if ($tmp_ret===false){
trigger_error("Can't read from resource get#3",E_USER_NOTICE);
return(NULL);
if (strlen($tmp_ret)>0) $start=microtime(1);
$data.=$tmp_ret;
unset($tmp_ret);
if(strlen($data)>=24 || (microtime(1)-$start)>$this->timeout)
break;
$ret=$this->unpack(substr($data,0,24)); // unpack 24bytes into 6 data
if (count($ret)<6){
if ($get_type==OWNET_MSG_DIR_ALL) // old servers
return($this->get($path,OWNET_MSG_DIR,$return_full_info_array,$parse_php_type));
$data=substr($data,0,24);
trigger_error("Error unpacking data get#1 [".strlen($data)."] ".$data,E_USER_NOTICE);
return(NULL);
// check presence
if (!isset($ret[2]))
return(NULL); // error ?! maybe not (count < 6)
return($ret[2]===0); // ret[2]!=0 => not present
$data=substr($data,24); // if any data was read with more than 24 bytes
if (!isset($ret[1]))
$ret[1]=false; // just to be sure that will not get into $ret parsing
if ($ret[1]>0){
if ($get_type==OWNET_MSG_DIR || $get_type==OWNET_MSG_DIR_ALL) // reading directory use $ret[1] for read data
$data_len=$ret[1];
else
$data_len=$ret[2]; // reading file use $ret[2] for read data
$tmp_ret='';
$start=microtime(1); // set start time for timeout read
if ($data_len>0)
while(1){
$tmp_ret=$this->get_msg($data_len);
trigger_error("Can't read from resource get#4",E_USER_NOTICE); // error receiving
return(NULL); // return NULL on error
$data.=$tmp_ret;unset($tmp_ret);
if(strlen($data)>=$data_len || (microtime(1)-$start)>$this->timeout) // timedout or got every data that we need
break;
if (!$return_full_info_array && strlen($data)!=$data_len){ // if just return value and data < data_len return as an error
trigger_error("Can't read full data get#1",E_USER_NOTICE);
if ($get_type==OWNET_MSG_DIR){ // reading dir
$ret['data'] =$data;
$ret['data_len']=strlen($data);
$ret['data_php']=substr($data,0,$ret[4]); // ret[4] is the right filename size ?! it's work :D
if ($return===NULL)
$return=array(); // se return as an array to get values
if ($return_full_info_array)
$return[]=$ret; // return an array
else
$return[]=$ret['data_php']; // return file name
// continue while...
}else{
$ret['data'] =substr($data,0,$data_len); // data_php length is the same as $ret[2]
$this->disconnect(); // disconnect from server
$type=false; // check type?
if ($parse_php_type && $get_type!=OWNET_MSG_DIR_ALL){
$tmp =explode('/',$path);$c=count($tmp)-1;
if ($c>0){ // must be something like '/dir/file' array('dir', 'file'), count()-1 = 1 > 0
$variavel =$tmp[$c]; // get last two uri args
$ow =$tmp[$c-1];
unset($tmp);
if (preg_match('/([0-9A-F]{2})[\.]{0,1}[0-9A-F]{12}/',$ow,$tmp)){ // check if ow is an OW id ("XX.ZZZZZZZZZZZZ or XXZZZZZZZZZZZZ")
$tmp=$tmp[1];
if (!isset($OWNET_GLOBAL_CACHE_STRUCTURE[$tmp.'/'.$variavel])){ // check if we have structure information
$tmp_v=@$this->get("/structure/$tmp/$variavel",OWNET_MSG_READ,false,false); // get estrutucture information
if ($tmp_v!==NULL){
$tmp_v=explode(',',$tmp_v); // ok :D we will get real php values now!
$OWNET_GLOBAL_CACHE_STRUCTURE[$tmp.'/'.$variavel]=$tmp_v;
$type=$tmp_v;
}else
$type=$OWNET_GLOBAL_CACHE_STRUCTURE[$tmp.'/'.$variavel];
unset($tmp,$tmp_v,$variavel,$ow,$c);
if ($type!==false){
// get real php values
$ret['data_php']=$ret['data'];
if($type[0]=='i'){
$ret['data_php']=bcadd($ret['data_php'],0,0); // integer (using bcmath for bigger precision)
}elseif($type[0]=='u'){
$ret['data_php']=bcadd($ret['data_php'],0,0); // unsigned integer (using bcmath for bigger precision)
// MAJA 2017-01-28 - Tippfehler im Original
// if (bccmp($ret['data_php'],0,0)==-1){
if (bccomp($ret['data_php'],0,0)==-1){
$ret['data_php']=substr($ret['data_php'],1); // be shure that it's unsigned
}elseif(in_array($type[0],array('f','t',chr(152)))){
$ret['data_php']=(double)$ret['data_php']; // using float (double) values, maybe sprinf("%.50f",$value) could get an string representation
if ($return_full_info_array){
if ($type[0]=='t'){ // temperature (last owserver versions... maybe an 'v' for volts and 'A' for amps could be implemented)
// we can't cache cause server may restart or change configurations while we have old cache information, here we will have +- .1 seconds of performace lost, set return full information off if you don't want it
$tmp_v=@$this->get("/settings/units/temperature_scale",OWNET_MSG_READ,false,false); // get server current scale
if ($tmp_v!==NULL) // just for compatible with old owservers
$ret['unit']=$tmp_v; // use unit if return full information
}elseif(in_array($type[0],array('a','b','d'))){
$ret['data_php']=(string)$ret['data_php']; // string (maybe without it could work too, but's it's pretty :D )
}elseif($type[0]=='y'){
$ret['data_php']=($ret['data_php']==1?true:false); // boolean content
} // another contents are parsed as string too
}else{
$ret['data_php']=&$ret['data']; // we will use not parsed values (we use it when getting structure information! or setting $parse_php_type=false)
if ($get_type==OWNET_MSG_DIR_ALL){
$return=& $ret;
break;
return($ret); // return array
}else{
return($ret['data_php']); // return just php parsed value
}else{
break;
$this->disconnect(); // disconnect from server (dir listing)
if ($get_type==OWNET_MSG_DIR_ALL && $return===NULL) // old servers
if ($return!==NULL){
if ($this->use_swig_dir && !$return_full_info_array && $get_type==OWNET_MSG_DIR)
if (is_array($return))
$return=implode(',',$return);
if ($this->use_swig_dir==false && $get_type==OWNET_MSG_DIR_ALL){
$tmp=explode(',',$return['data_php']);
$r=array();
for ($i=0;$i<count($tmp);$i++)
$r[]=array(
0=>$return[0],
1=>$return[1],
2=>$return[2],
3=>$return[3],
4=>$return[4],
5=>$return[5],
'data'=>$return['data'],
'data_len'=>$return['data_len'],
'data_php'=>$tmp[$i]
$return=$r;
unset($tmp,$r);
}else
$return=explode(',',$return);
return($return);
function set($path,$value=''){
// set and value to path checking before if path is readonly or not
$type=false;
if ($c>0){ // try to get information about structure, if file is readonly or not
$ow =$tmp[$c-1];
unset($tmp);
$tmp=$tmp[1];
if ($tmp_v!==NULL){
$OWNET_GLOBAL_CACHE_STRUCTURE[$tmp.'/'.$variavel]=$tmp_v; // ok we will test it
$type=$tmp_v;
}else
$type=$OWNET_GLOBAL_CACHE_STRUCTURE[$tmp.'/'.$variavel]; // very fine, it was cached! :D performace boost
if ($type!==false){
if ($type[3]=='ro'){ // read only file
trigger_error("Read only value set#1 [$path]",E_USER_NOTICE);
unset($type,$tmp,$tmp_v,$variavel,$ow,$c);
$this->connect();
trigger_error("Can't connect set#1",E_USER_NOTICE);
if (!is_string($value))
$value=(string)$value; // be sure that's an string
$msg=$this->pack(OWNET_MSG_WRITE,strlen($path)+1+strlen($value)+1,strlen($value)+1); // pack data
trigger_error("Can't write to resource set#1",E_USER_NOTICE);
return(false); // error sending
if ( $this->send_msg($path.chr(0).$value.chr(0))===false ){
trigger_error("Can't write to resource set#2",E_USER_NOTICE);
return(false); // error sending value
$start=microtime(1); // start timeout counter
while(1){
trigger_error("Can't read from resource set#1",E_USER_NOTICE);
return(false); // error reading return
if(strlen($data)>=24 || (microtime(1)-$start)>$this->timeout) // timed out or got content
break;
$ret=$this->unpack($data); // unpack data return
if (count($ret)<6){
trigger_error("Error unpacking data set#1 [".strlen($data)."] ".$data,E_USER_NOTICE);
$ret[2]=1; // be sure that we will work with error_reporting(E_ALL)
if ($ret[2]!=0)
$ret=false; // return false on error
if ($ret!==false)
return(true); // very fine :)
return($ret); // :(
private function unpack($data){ // unpack returned contents (24 bytes data)
$unpack=$this->unpack_ntohl($data);
return($unpack);
// version= 0, payload_len=1, ret_value=2, format_flags=3, data_len=4, offset=5
private function pack($function,$payload_len,$data_len){ // pack msg information (24 bytes)
$pack= $this->pack_htonl(0).
$this->pack_htonl($payload_len).
$this->pack_htonl($function).
$this->pack_htonl(258).
$this->pack_htonl($data_len).
$this->pack_htonl(0);
return($pack);
explanation:
EVERY FUNCTION TRIGGER AN ERROR! you should use @$ow->function to don't handle errors
$ow=new OWNet($host,$timeout=5,$use_swig_dir=true);
in top of file we have some constants: (line 58)
i don't know what's the default OW port, i'm using today 4304 :)
for OWNet($host) we can use this types of host value:
"scheme://host:port" "scheme://host" "anything that can't be parsed with parseurl"
if port isn't set we get default port, if host isn't set we get default host
if scheme == "stream" or scheme == "ow-stream"
we will prefer to use PHP stream_socket_client functions
else if function socket_create exists we will use socket_connect() with sockets we can set TCP_NODELAY SO_REUSEADDR SO_OOBINLINE(we use it?) SO_RCVBUF SO_SNDBUF
$ow->setHost($host)
is the same thing that new OWNet($host)
$ow->getHost()
get host URI
owstream://host:port if using stream_socket_client
ow://host:port if using sockets
$ow->setTimeout($timeout=5)
set read timeout, default 5
$ow->getTimeout()
get read timeout
$ow->set($path,$value='')
set an value to path
true on success
false on error or if file is readonly
$ow->read($path,$parse_value=true)
return value if parse_value return an php parsed value, if not return an string
$ow->dir($path)
return an dir (see setUserSwigDir and OWNet constructor)
$ow->presence($path)
get presence
$ow->get($path='/',$get_type=OWNET_MSG_READ_ANY,$return_full_info_array=false,$parse_php_type=true)
on error return NULL
get_type can be:
OWNET_MSG_READ (execute OWNET_MSG_READ and if don't find execute OWNET_MSG_DIR)
OWNET_MSG_READ *default
read an file from owserver
OWNET_MSG_DIR
read an dir from owserver
OWNET_MSG_PRESENCE
read presence from owserver (return false or true)
if true return an array with everything that was received from owserver more data_php and unit if file is an temperature value
parse_php_type
try to check what type is an file (temperature, boolean, string, number (double or integer))
$ow->setUseSwigDir($use) // use swig dir style (dir,dir,dir) and not php array (array(dir,dir,dir))
$ow->getUseSwigDir() // get if using swig dir style
END :)
examples:
$ow=new OWNet("tcp://172.16.1.100:4304");
var_dump($ow->get("/",OWNET_MSG_DIR,true));
var_dump($ow->get("/10.E8C1C9000800/temperature",OWNET_MSG_READ,true));
var_dump($ow->get("/10.E8C1C9000800",OWNET_MSG_PRESENCE,true));
var_dump($ow->get("/WRONG VALUE",OWNET_MSG_PRESENCE,true));
var_dump($ow->get("/",OWNET_MSG_DIR,false));
var_dump($ow->get("/10.E8C1C9000800/temperature",OWNET_MSG_READ,false));
var_dump($ow->get("/10.E8C1C9000800",OWNET_MSG_PRESENCE,false));
var_dump($ow->get("/WRONG VALUE",OWNET_MSG_PRESENCE,false));
return:
array(9) {
[0]=> array(9) {
[0]=> int(0)
[1]=> int(42)
[2]=> int(0)
[3]=> int(258)
[4]=> int(5)
[5]=> int(0)
["data"]=> string(42) "bus.0athaðãaPÜa»a0"
["data_len"]=> int(42)
["data_php"]=> string(5) "bus.0"
[1]=> array(9) {
[0]=> int(0)
[1]=> int(42)
[2]=> int(0)
[3]=> int(258)
[4]=> int(8)
[5]=> int(0)
["data"]=> string(42) "settings0"
["data_php"]=> string(8) "settings"
[2]=> array(9) {
[0]=> int(0)
[1]=> int(42)
[2]=> int(0)
[3]=> int(258)
[4]=> int(6)
[5]=> int(0)
["data"]=> string(42) "system0"
["data_php"]=> string(6) "system"
[3]=>
array(9) {
[0]=> int(0)
[1]=> int(42)
[2]=> int(0)
[3]=> int(258)
[4]=> int(10)
[5]=> int(0)
["data"]=> string(42) "statistics0"
["data_php"]=> string(10) "statistics"
[4]=>
array(9) {
[0]=> int(0)
[1]=> int(42)
[2]=> int(0)
[3]=> int(258)
[4]=> int(16)
[5]=> int(0)
["data"]=> string(42) "/10.E8C1C9000800P×aàÑa*»a0"
["data_php"]=> string(16) "/10.E8C1C9000800"
[5]=>
array(9) {
[0]=> int(0)
[1]=> int(42)
[2]=> int(0)
[3]=> int(258)
[4]=> int(16)
[5]=> int(0)
["data"]=> string(42) "/10.54FDED000800P×aàÑa*»a0"
["data_php"]=> string(16) "/10.54FDED000800"
[6]=>
array(9) {
[0]=> int(0)
[1]=> int(42)
[2]=> int(0)
[3]=> int(258)
[4]=> int(16)
[5]=> int(0)
["data"]=> string(42) "/10.6F7EC9000800P×aàÑa*»a0"
["data_php"]=> string(16) "/10.6F7EC9000800"
[7]=>
array(9) {
[0]=> int(0)
[1]=> int(42)
[2]=> int(0)
[3]=> int(258)
[4]=> int(16)
[5]=> int(0)
["data"]=> string(42) "/28.924FE0000000P×aàÑa*»a0"
["data_php"]=> string(16) "/28.924FE0000000"
[8]=>
array(9) {
[0]=> int(0)
[1]=> int(42)
[2]=> int(0)
[3]=> int(258)
[4]=> int(16)
[5]=> int(0)
["data"]=> string(42) "/28.5D59E0000000P×aàÑa*»a0"
["data_php"]=> string(16) "/28.5D59E0000000"
array(10) {
[0]=> int(0)
[1]=> int(8192)
[2]=> int(12)
[3]=> int(0)
[4]=> int(12)
[5]=> int(0)
["data"]=> string(12) " 28.625"
["data_len"]=> int(12)
["data_php"]=> float(28.625)
["unit"]=> string(1) "C"
bool(true)
bool(false)
array(9) {
[0]=> string(5) "bus.0"
[1]=> string(8) "settings"
[2]=> string(6) "system"
[3]=> string(10) "statistics"
[4]=> string(16) "/10.E8C1C9000800"
[5]=> string(16) "/10.54FDED000800"
[6]=> string(16) "/10.6F7EC9000800"
[7]=> string(16) "/28.924FE0000000"
[8]=> string(16) "/28.5D59E0000000"
float(28.625)
bool(true)
gdb.zip (314 KB)
