Symcon EnOcean LAN Gateway
Has the Symcon EnOcean LAN Gateway been discontinued?
Yes, but you can use the „PioTek EnOcean Multigateway“ which is 100% compatible.
Thank you for your reply. Is there any particular reason for this?
Not enough demand :slight_smile: And PioTek has a compatible device for a smaller price and optional PoE.
That seems reasonable. Given the limited demand, PioTek’s compatible device at a lower price, with optional PoE sounds like the more practical choice.
Is it possible to change the Base ID in the PioTek MultiGateway as well?
It even should be possible to use our tool for this.
