Hab ich auch nicht. Wenn ich den ComPort Öffne kommt nichts an. Ich denke es muss erst ein befehl gesendet werden, damit die Daten ankommen.
Hier der ganze log es ComPort wenn ich den Dienst starte:
0.00001478 theowl_be.exe IOCTL_SERIAL_SET_TIMEOUTS Silabser0 SUCCESS RI:0 RM:0 RC:1000 WM:0 WC:1000
0.00000780 theowl_be.exe IOCTL_SERIAL_GET_BAUD_RATE Silabser0 SUCCESS
0.00000657 theowl_be.exe IOCTL_SERIAL_GET_LINE_CONTROL Silabser0 SUCCESS
0.00000575 theowl_be.exe IOCTL_SERIAL_GET_CHARS Silabser0 SUCCESS
0.00000616 theowl_be.exe IOCTL_SERIAL_GET_HANDFLOW Silabser0 SUCCESS
0.00000616 theowl_be.exe IOCTL_SERIAL_GET_BAUD_RATE Silabser0 SUCCESS
0.00000616 theowl_be.exe IOCTL_SERIAL_GET_LINE_CONTROL Silabser0 SUCCESS
0.00000575 theowl_be.exe IOCTL_SERIAL_GET_HANDFLOW Silabser0 SUCCESS
0.00277870 theowl_be.exe IOCTL_SERIAL_SET_BAUD_RATE Silabser0 SUCCESS Rate: 250000
0.00194144 theowl_be.exe IOCTL_SERIAL_SET_RTS Silabser0 SUCCESS
0.00296800 theowl_be.exe IOCTL_SERIAL_SET_DTR Silabser0 SUCCESS
0.00197100 theowl_be.exe IOCTL_SERIAL_SET_LINE_CONTROL Silabser0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
0.00300372 theowl_be.exe IOCTL_SERIAL_SET_CHAR Silabser0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
0.00298196 theowl_be.exe IOCTL_SERIAL_SET_HANDFLOW Silabser0 SUCCESS Shake:1 Replace:40 XonLimit:256 XoffLimit:256
1.00011785 theowl_be.exe IRP_MJ_READ Silabser0 TIMEOUT Length 0:
0.99999877 theowl_be.exe IRP_MJ_READ Silabser0 TIMEOUT Length 0:
0.52954652 theowl_be.exe IRP_MJ_READ Silabser0 SUCCESS Length 11: .IDTCMV001.
0.00186095 theowl_be.exe IOCTL_SERIAL_PURGE Silabser0 SUCCESS Purge: TXCLEAR RXCLEAR
0.00190448 theowl_be.exe IRP_MJ_WRITE Silabser0 SUCCESS Length 1: Z
0.00159076 theowl_be.exe IRP_MJ_READ Silabser0 SUCCESS Length 11: Y....... ..
0.00011949 theowl_be.exe IRP_MJ_READ Silabser0 SUCCESS Length 11: .IDTWAITPCR
0.00161417 theowl_be.exe IOCTL_SERIAL_PURGE Silabser0 SUCCESS Purge: TXCLEAR RXCLEAR
0.00190489 theowl_be.exe IRP_MJ_WRITE Silabser0 SUCCESS Length 1: .
0.99973966 theowl_be.exe IRP_MJ_READ Silabser0 TIMEOUT Length 0:
1.00000000 theowl_be.exe IRP_MJ_READ Silabser0 TIMEOUT Length 0:
1.00000616 theowl_be.exe IRP_MJ_READ Silabser0 TIMEOUT Length 0:
1.00000452 theowl_be.exe IRP_MJ_READ Silabser0 TIMEOUT Length 0:
0.98561745 theowl_be.exe IRP_MJ_READ Silabser0 SUCCESS Length 11: .IDTWAITPCR
0.00145895 theowl_be.exe IOCTL_SERIAL_PURGE Silabser0 SUCCESS Purge: TXCLEAR RXCLEAR
0.00193076 theowl_be.exe IRP_MJ_WRITE Silabser0 SUCCESS Length 1: .
0.99914015 theowl_be.exe IRP_MJ_READ Silabser0 TIMEOUT Length 0:
0.99998973 theowl_be.exe IRP_MJ_READ Silabser0 TIMEOUT Length 0:
0.99998727 theowl_be.exe IRP_MJ_READ Silabser0 TIMEOUT Length 0:
0.00001560 theowl_be.exe IRP_MJ_CLEANUP Silabser0 SUCCESS
0.00657575 theowl_be.exe IRP_MJ_CLOSE Silabser0 SUCCESS
Und hier dazu die Ausgabe im DEBUG Terminal
C:\Program Files\2SE\The OWL USB Connect 2>theowl_be -d
service_debug(): running....
[00a866b1:000000:00000540] main_init(): theowl_be 02.00.15
[00a866c1:000010:00000540] main_opendb(): OK
[00a866c1:000000:00000540] energy_init(>)
[00a866c1:000000:00000540] tse_init(>)
[00a866c1:000000:00000540] tenxhid_init(>)
[00a866d0:00000f:00000540] tenxhid_init(): OK
[00a866d0:000000:00000540] tse_init(): OK [opt = 0]
[00a866d0:000000:00000d48] tse_thread(): started up OK
[00a866d0:000000:00000540] tseuart_init(>)
[00a866d0:000000:00001994] tseuart_thread(): started up OK
[00a866d0:000000:000006c4] tseuart_thread(): started up OK
[00a866d0:000000:00000540] tseuart_init(): OK [opt = 0]
[00a866d0:000000:0000128c] tseuart_thread(): started up OK
[00a866d0:000000:00000af0] tseuart_thread(): started up OK
[00a866d0:000000:00000878] tseuart_thread(): started up OK
[00a866d0:000000:00000540] db_schemachanged(): OK [changed: '' != 'uid,name
,b1_time,b1_cost,b1_type,b2_time,b2_cost,b2_type,b3_time,b3_cost,b3_type,b4_time
,b4_cost,b4_type,b5_time,b5_cost,b5_type,b6_time,b6_cost,b6_type']
[00a866e0:000010:00000540] db_dumpsql(): OK [4 rows[
<dataset>
<rec key="first_run" value="1" />
<rec key="supply_voltage" value="230" />
<rec key="ghg_factor" value="43" />
<rec key="currency_symbol" value="?" />
</dataset>
[00a866e0:000000:00000540] db_dumpsql(): OK [1 rows[
<dataset>
<rec uid="uid0" name="Standard" b1_time="0" b1_cost="1050" b1_type="1" b
2_time="0" b2_cost="-1" b2_type="0" b3_time="0" b3_cost="-1" b3_type="0" b4_time
="0" b4_cost="-1" b4_type="0" b5_time="0" b5_cost="-1" b5_type="0" b6_time="0" b
6_cost="-1" b6_type="0" />
</dataset>
[00a866ef:00000f:00000540] db_dumpsql(): OK [1 rows[
<dataset>
<rec addr="2076738" name="[Enter name here]" model="60" tariff_uid="uid0
</dataset>
[00a866ef:000000:00000540] db_dumpsql(): OK [1 rows[
<dataset>
<rec addr="2076738" year="2010" month="1" day="1" hour="12" min="1" ch1_
amps_avg="0" ch1_kw_avg="0" ghg="43" cost="1250" ch1_amps_min="0" ch1_amps_max="
0" ch1_kw_min="0" ch1_kw_max="0" dt="2010-01-01 12:01:00.000" />
</dataset>
[00a866ff:000010:00000540] energy_init(): OK [built for 10 sensors]
[00a866ff:000000:00001c74] energy_thread(0x04ac8483): started up OK
[00a866ff:000000:00000540] netutl_init(>)
[00a866ff:000000:00000540] netutl_init(): OK
[00a866ff:000000:00000540] ifc_init(>)
[00a866ff:000000:00000540] netutl_startserver(5904, false, true)
[00a866ff:000000:00000540] netutl_startserver(): OK
[00a8670f:000010:00000540] ifc_init(): OK
[00a8670f:000000:00001650] ifc_thread(): started up OK [port = 5904, server
_s = 412]
[00a8670f:000000:00000540] main_init(): OK
[00a8678b:00007c:00001994] tseuart_thread(): dongle online [port 9, serial
number 0x001fb042]
[00a8678b:000000:00001994] tseuart_thread(): port 9 opened at 250000 baud i
n cm160 frame mode
[00a871b9:000a2e:00001c74] INSERT OR IGNORE INTO energy_history VALUES(2076
738, 2012, 8, 26, 20, 14, 0.037333, 8.586667, 43, 1250, 0.037333, 0.037333, 8.58
6667, 8.586667, '2012-08-26 20:14:00.000');
service_handler(): stopping service....
[00a88d53:001b9a:00000540] main_free(>)
[00a88d53:000000:00000540] ifc_free(>)
[00a88d53:000000:00000540] netutl_stopserver(>)
[00a88d53:000000:00001650] netutl_accept(): failed
[00a88d53:000000:00001650] ifc_thread(): shutting down
[00a88d63:000010:00000540] netutl_free(>)
[00a88d63:000000:00000540] energy_free(>)
[00a88d73:000010:00001c74] energy_thread(): shutting down
[00a88d73:000000:00000540] tseuart_free(>)
[00a88e9b:000128:000006c4] tseuart_thread(): shutting down
[00a88e9b:000000:0000128c] tseuart_thread(): shutting down
[00a88e9b:000000:00000af0] tseuart_thread(): shutting down
[00a88e9b:000000:00000878] tseuart_thread(): shutting down
[00a890ae:000213:00001994] tseuart_thread(): shutting down
[00a890bd:00000f:00000540] tse_free(>)
[00a89205:000148:00000d48] tse_thread(): shutting down
[00a89205:000000:00000540] tenxhid_free(>)
[00a89214:00000f:00000540] main_free(<)
